楼主: 洋葱圈
[分享] [2013年4月5日更新]【拉普兰德K60底层库】OSKinetis_V2.2(驱动库、30+例程、函数手册)
发表于 2012-12-14 10:58:38 | 显示全部楼层
RE:【拉普兰德K60底层库】OSKinetis_V2.0(含驱动、29个例程、函数手册)
K60芯片,停止模式我明白了。
发表于 2012-12-14 11:00:04 | 显示全部楼层
K60芯片,停止模式我明白了。
发表于 2012-12-14 11:08:02 | 显示全部楼层
回复:【拉普兰德K60底层库】OSKinetis_V2.0(含驱动、29个例程、函数手册)
LPLD:
库函数中ADC的.c和.h
101 void ADC_Config_Alt(ADC_MemMapPtr adcmap, tADC_ConfigPtr ADC_CfgPtr)
102 {
103 ADC_CFG1_REG(adcmap) = ADC_CfgPtr->CONFIG1;
在配置ADC的feature ,ADC_CfgPtr->CONFIG1为结构体中的uint8_t CONFIG1; 寄存器支持:byte enabled registers。
我的问题
ADC_CFG1_REG这个是宏还是函数?在写寄存器吧?这个函数在哪定义的???以及void ADC_Config_Alt函数里的大部分做相同工作的函数都在哪定义的??.h里我没有找到
技术文档里是这么写,我就不翻译了哈。
34.4.5.3 Aborting conversions
Any conversion in progress is aborted when:
• Writing to SC1A register while it is actively controlling a conversion, aborts the
current conversion. In software trigger mode (ADTRG=0), a write to SC1A register
initiates a new conversion (if the ADCH field in SC1A is equal to a value other than
all 1s). Writing to any of the SC1(B-n) registers while that specific SC1(B-n) register
is actively controlling a conversion aborts the current conversion.The SC1(B-n)
registers are not used for software trigger operation and therefore writes to the
SC1(B-n) registers do not initiate a new conversion.
• A write to any ADC register besides the SC1A:SC1n registers occurs. This indicates
a mode of operation change has occurred and the current conversion is therefore
invalid.
• The MCU is reset or enters Low Power Stop modes.
• The MCU enters Normal Stop mode with ADACK not enabled.
When a conversion is aborted, the contents of the data registers, Rn, are not altered. The
data registers continue to be the values transferred after the completion of the last
successful conversion. If the conversion was aborted by a reset or Low Power Stop
modes, RA and R n return to their reset states.
发表于 2012-12-14 11:14:14 | 显示全部楼层
adc16.c中 34行 uint8 ADC_Cal(ADC_MemMapPtr adcmap),ADC_MemMapPtr这个结构体在哪???
 楼主| 发表于 2012-12-14 12:35:51 | 显示全部楼层
回复第 28 楼 于2012-12-14 10:43:47发表:
LPLD:
库函数中ADC的.c和.h
102 {
我的问题
不用关心ADC_Config_Alt内部如何定义,ADC_CfgPtr结构体的变量一一对应ADC的寄存器。请参考函数手册。
发表于 2012-12-14 13:41:56 | 显示全部楼层
我需要这些定义和函数实现,可以给我一份吗?
 楼主| 发表于 2012-12-14 18:38:48 | 显示全部楼层
回复第 36 楼 于2012-12-14 13:41:56发表:
帖子中有下载
 楼主| 发表于 2012-12-15 20:53:07 | 显示全部楼层
没积分啦,赶紧顶贴赚几个。
发表于 2012-12-15 21:14:57 | 显示全部楼层
好东西,谢楼主!
 楼主| 发表于 2012-12-16 11:06:13 | 显示全部楼层
回复第 39 楼 于2012-12-15 21:14:57发表:
好东西,谢楼主!
GMT+8, 2025-10-28 15:00 , Processed in 0.105331 second(s), 27 queries , MemCache On.
