查看: 6358|回复: 16
[其他] 哪位老师有ADC的驱动程序呀?能发给我一个吗??
发表于 2012-12-13 00:17:08 | 显示全部楼层 |阅读模式
adc feature:
Up to 10 ENOB (dedicated Single Ended Channels)这是什么意思呀???
• Up to 1MS/s sampling rate 这是每秒采样  1M次???
• Up to 16 single-ended external analog inputs
• Single or continuous conversion (automatic return to idle after single conversion)
• Output Modes: (in right-justified unsigned format)
• 12-bit,
• 10-bit
• 8-bit
• Configurable sample time and conversion speed/power   采样时间可配置是什么意思啊???
• Conversion complete and hardware average complete flag and interrupt
• Input clock selectable from up to four sources
• Asynchronous clock source for lower noise operation with option to output the clock  这句话怎么理解呀???
• Selectable asynchronous hardware conversion trigger 异步硬件触发是怎么触发的呀????
• Selectable voltage reference, Internal, External, or Alternate 参考电压 最后这个 Alternate 怎么理解呀???
• Automatic compare with interrupt for less-than, greater-than or equal-to, within 这个是什么功能啊???
range, or out-of-range, programmable value
• Operation in low power modes for lower noise operation
• Temperature sensor
• Hardware average function
• Self-calibration mode
小弟最近刚接触ADC疑问很多希望能得到大家帮助 ,万分感激!
还有几个疑问:
1,ADC模块有ADC0和ADC1,除了基地址不同寄存器什么的都一样,在驱动里怎么注册这设备呀?注册两个??但看时钟部分就是ADC 一个设备呀???
2,ADC0和ADC1 都有8通道外部接入 一个时间点只有一路转换。可我作为客户要同时接入比如说6路,这六路我都要不断地需要转换的结果,驱动里怎么实现啊????
3,硬件触发 是这样描述的: When hardware trigger is selected, a conversion is initiated following the assertion of a
pulse on Alternate Hardware trigger input along with the assertion of the enable of respective the
hardware Triggers input .  这是什么意思啊???有一个持续的脉冲就能触发了???然后在手动的去打开对应的通道???
大家有样例驱动程序更好,,现在这里多谢大家了!!!
我知道答案 目前已有16人回答
发表于 2012-12-13 10:13:27 | 显示全部楼层
RE:哪位老师有ADC的驱动程序呀?能发给我一个吗??
Hardware  :       EVB9S08DZ60 Board
Author    :      WBR
Version   :      V1.0
Begin Time:      2011.5.30
#include  /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
#include "1302.h"
//#include "lcd.h"
//#include "mscan.h"
//#include "KEY.h"
IO说明:
        1:四路AD输入通道 ADP19(AD1)  ADP11(AD2)  ADP3(AD3) ADP4(AD4)
        2:485通信      DE (PTE2)  TXD1(PTE0)  RXD1(PTE1)
        3:四路光耦输入 DI1(PTG2)  DI2 (PTE5)  DI3 (PTE4)  DI4(PTE3)
        4S1302       SCL(PTF2)  SDA (PTF3) RST (PTG4)
        5:继电器控制   PTA6  PTB5  PTA5  PTC4  PTB6
        6:按键(输入) PTC0  PTB0  PTC1  PTA0  PTC2(SW1~SW5)
        7:CAN          TX(PTE6)  RX(PTE7)
        8CD          RW(PTG3)  RS(PTF0) E(PTF1) RST(PTF7) 背光(PTG5)  DATA(PTD0~PTD7)
#define  DI1  PTGD_PTGD2                  //外触发1-----&gtG2
#define  DI2  PTED_PTED5                  //外触发2-----&gtE5
#define  DI3  PTED_PTED4                  //外触发3-----&gtE4
#define  DI4  PTED_PTED3                  //外触发4-----&gtE3
//********以上为输入IO********//
#define  JDQ1 PTCD_PTCD4                  //继电器1-----&gtC4
#define  JDQ2 PTAD_PTAD5                  //继电器2-----&gtA5
#define  JDQ3 PTBD_PTBD5                  //继电器3-----&gtB5
#define  JDQ4 PTAD_PTAD6                  //继电器4-----&gtA6
#define  JDQ5 PTBD_PTBD6                  //继电器5-----&gtB6
#define DE485 PTED_PTED2                  //485 T R切换-----&gtE2
//#define ID_TX               0x0001      //自定义的CAN发送标识符
//#define ID_RX               0x0002      //自定义的CAN接收标识符
//Bool can_send_enable = FALSE;           //CAN发送标志位,暂定RTC0.5秒发送一次
#define Baud  19200                       //串口波特率9600
#define N 51
#define T 1800                             //运算电量的时间单位1800是半个小时(1800秒)
#define Psum 21600                        //总电量初值,满电量时
extern byte time_buf1[8];                 //1302时钟寄存器
byte ReadTimeFlag = 0;                    //定时器每0.5秒读1302时间的标志位
byte ADSET = 0;                           //发送电流电压功率等数值到显示屏标志位
/*********************变量和函数定义****************************/
word ADCbuffer1[N] = 0;                  //AD转换缓冲
word ADC1,ADC2,ADC3,ADC4;                 //AD转换缓冲
byte ADC1L,ADC1H,ADC2L,ADC2H,ADC3L,ADC3H,ADC4L,ADC4H;
byte Buffer[15];                          //串口接收缓冲
byte ADch_s;                              //AD通道选择
byte ADcount;
//byte Key_value=0;                       //按键
//byte CANbuffer[8];                      //接收到的CAN内容缓冲区数组
word  sum=0;
long  P,P1,Premain;
//word Premain;
word PL,PH;                               //拆分P
byte P0L,P0H,P1L,P1H;                     //拆分PH,PL
byte RR = 1;                              //RR = 1;读屏的19号地址;RR = 2读屏的20号地址开始的时间;
byte PAGE7,PAGE8;                         //进入设置时间页面和电量页面设置计数;
byte T20;
word TENT;
byte WF,RF;                               //写读FLASH的标志位,同时也是计算电量的标志位
byte *p;
//中值滤波程序
void filter()
   static byte count,i,j;
   word value_buf[N];
   word temp;
   sum=0;
   for(count=0;count16;
                    PL = P&0xffff;
                    P1H = PH>>8;
                    P1L = PH&255;
                    P0H = PL>>8;
                    P0L = PL&255;
                    P1 += P ;
                    i++;
              if(i>T)                           //半小时候写一次FLASH,进行一次电量计算
                  i = 0;
                  WF = 1;                       //半小时置位读写FLASH,和计算电量标志
                    asm(nop);
                    ADch_s = 3;
                    ADCSC1=0x63;
                if(ADcount == 3)
                    filter();
                    ADC3= (sum/(N-2));
                    ADC3H =  (sum/(N-2))>>8;
                    ADC3L =  (sum/(N-2))&255;
                    ADch_s = 4;
                    ADCSC1=0x64;
                if(ADcount == 4)
                    filter();
                    ADC4= (sum/(N-2));
                    ADC4H =  (sum/(N-2))>>8;
                    ADC4L =  (sum/(N-2))&255;
                    ADch_s = 19;
                    ADCSC1=0x73;
                if(RR ==2)
              DE485 = 1;
              Delay(2);
              SCI1send (0x01);          //站号
              SCI1send (0x52);          //读命令
              SCI1send (0x14);          //20号地址判断ENT键状态
              SCI1send (0x01);          //1个地址
              SCI1send (0x68);
              Delay(1);                 //必须加段延时确保数据发送出去
              DE485 = 0;                //485切换到接收状态
              asm(nop);
         if(RR ==3)
              DE485 = 1;
              Delay(2);
              SCI1send (0x57);          //写命令
              SCI1send (0x14);          //20号地址清零
              SCI1send (0x01);          //1个长度
              SCI1send (0x00);          //18号地址
              SCI1send (0x00);
              SCI1send (0x6D);
              Delay(50);
              RR =4;
         if(RR ==4)                     //读时间
              DE485 = 1;
              Delay(5);
              SCI1send (0x0B);          //11号地址
              SCI1send (0x06);          //6个地址
              SCI1send (0x64);
              //asm(nop);
       if(WF)
           WF = 0;
           if(Pchange ==0)                    //如果是放电状态
                if(!PowerL){
                P1 = P1/T/2;                  //半个小时的实际电量
                Premain  =  Premain -P1;
                mw8 =  Premain*100/Psum;     //
                if(mw8>8);
                mw6L = ((aa&0xffff)&255);
                p=( unsigned char *)(0x1400);  //指定地址
                *p=0x01;
                FCMD=0X40;                    //擦除命令
                FSTAT_FCBEF=1;                //启动命令
                asm{
                    NOP
                    NOP
                    NOP
                    NOP
                while(FSTAT_FCCF==0);        //等待完成
//*********************剩余电量的低8位(mw6L)写入 EEPROM 0X1400
                if(FSTAT_FACCERR==1)
                FSTAT_FACCERR=1;
                p=(byte *)(0x1400);            //指定地址
                *p = mw6L;
                FCMD=0x20;
                FSTAT_FCBEF=1;
                Delay(2);
                /*asm
                    NOP
                    NOP
                    NOP
                    NOP
//*********************剩余电量的高8位(mw6H)写入 EEPROM 0X1401
                FSTAT_FACCERR=1;
                p=(byte *)(0x1401);            //指定地址
                *p = mw6H;
                FCMD=0x20;
                FSTAT_FCBEF=1;
                Delay(2) ;
                /*asm
                    NOP
                    NOP
                    NOP
                    NOP
                asm(nop);
               P1 = 0;
           if(Pchange ==0xff)                       //如果是充电状态
                Premain  =  Premain +P1;
                if(mw8>50)                           //
                     Failure = Failure&0xfb;        //清电量过低标志
                     PowerL = 0;                    //
                if(Premain>Psum)
                    Premain = Psum;                 //充到最大值了
                aa = Premain;
                mw6H = ((aa&0xffff)>>8);
                //mw6H  = aa;
                //mw6L = 0;
//**********************先擦除才能写************************
                *p=0x01;
                FCMD=0X40;                    //擦除命令
                asm{
                    NOP
                    NOP
                    NOP
                    NOP
                FSTAT_FACCERR=1;
                *p = mw6L;
                FCMD=0x20;
                FSTAT_FCBEF=1;
                asm
                    NOP
                    NOP
                    NOP
                    NOP
                FSTAT_FACCERR=1;
                *p = mw6H;
                FCMD=0x20;
                FSTAT_FCBEF=1;
                asm
                    NOP
                    NOP
                    NOP
                    NOP
                asm(nop);
                P1 = 0;
       if(ReadTimeFlag)
          ReadTimeFlag = 0;
          if(RR ==1)
              Delay(10);
              DE485 = 1;
              Ds1302_Read_Time();
              asm(nop);
              SCI1send (0x00);          //首地址
              SCI1send (0x12);          //18个地址
              SCI1send (ADC1H);         //MW0高位           电压
              SCI1send (ADC1L);         //MW0低位
              SCI1send (0x00);          //MW1
              SCI1send (0x00);
              SCI1send (ADC2H);         //MW2              电流
              SCI1send (ADC2L);
              SCI1send (0x00);          //MW3
              SCI1send (0x00);
              SCI1send (P0H);           //MW4                功率
              SCI1send (P0L);
              SCI1send (P1H);           //MW5
              SCI1send (P1L);
              SCI1send (mw6H);          //MW6
              SCI1send (mw6L);
              SCI1send (0x00);          //MW7
              SCI1send (0x00);
              SCI1send (0x00);          //MW8
              SCI1send (mw8);
              SCI1send (0x00);          //MW9
              SCI1send (0x00);
              SCI1send (0x00);          //MW10
              SCI1send (Pchange);
              SCI1send (0x00);
              SCI1send (time_buf1[1]);
              SCI1send (0x00);
              SCI1send (time_buf1[2]);
              SCI1send (0x00);
              SCI1send (time_buf1[3]);
              SCI1send (0x00);
              SCI1send (time_buf1[4]);
              SCI1send (0x00);
              SCI1send (time_buf1[5]);
              SCI1send (0x00);
              SCI1send (time_buf1[6]);
              SCI1send (0x00);                //MW17
              SCI1send (Failure);
              SCI1send (0x6a+Pchange+Failure+mw6L+mw6H+mw8+ADC1L+ADC1H+ADC2L+ADC2H+P0H+P0L+P1H+P1L+time_buf1[1]+time_buf1[2]+time_buf1[3]+time_buf1[4]+time_buf1[5]+time_buf1[6]);
              asm(nop);
              Delay(10);
              SCI1send (0x13);          //19号地址判断在哪个页面
              SCI1send (0x67);
              asm(nop);
//定时器1中断函数   中断向量号11   250毫秒定时
void interrupt 11 TPM1_ISR(void)
  static byte i,j,k;
  if((TPM1SC & 0x80)==0x80)
                  TPM1SC_TOF=0;
                  ADSET = 1;
   i++;
   if(!PAGE7)                    //
      j = 0;
   else
      j++;
      if(j>PAGE7)                  //大于5秒
          j  = 0;
          RR = 2;                 //转判断ENT键是否按下程序
          PAGE7 = 0;
  if(!TENT)
      k = 0;
else
    k++;
    if(k>TENT)
        k = 0;
        T20 = 1;                  //如果ENT键1分钟内没有按下则跳转到2界面(显示电压,电流)
        TENT = 0;
if(!PAGE8)                    //
      k = 0;
   else
      k++;
      if(k>PAGE8)                  //大于5秒
          k  = 0;
          PAGE7 = 0;
  if(!TENT)
      k = 0;
else
    k++;
    if(k>TENT)
        k = 0;
        TENT = 0;
if(i>3)
       i = 0;
       ReadTimeFlag = 1;
//串口接收中断  VectorNumber_Vsci1rx   中断向量号17
interrupt VectorNumber_Vsci1rx  void  SCI_RE(void)
  static byte j;
  static byte i;
        byte Rcv;
        if(SCI1S1_RDRF)                                 //串口接收中断标志位
        {                                               //清标志位
                SCI1S1_RDRF = 0;                              //接收数据送缓存
                Rcv = SCI1D;
//*********************读页面数值*****************************
          if(RR == 1)
                    if(Rcv == 0x13)
                                    j = 1;
                                    Buffer[0]=Rcv;
                    else
                                    if(j < 5)                                  //5个字节
                                              Buffer[j] = Rcv;
                                                    j++;
                    if((Buffer[3]==0x07)&&(Buffer[4]==0x1c))        //如果检测到是第7页面则处理数据
                        PAGE7 =20;                                  //如果停在7页面设置一个计数器,5秒时间内如果还在则认为在修改时间
                        TENT = 240;                                 //2分钟内ENT键没有按下,则跳转到2页面;
                    if(Buffer[3]!=0x07)                             //如果跳转到别的界面,马上清零
                        PAGE7 = 0;
                        TENT = 0;
                        RR = 1;                                     //回到正常状态
                   if((Buffer[3]==0x08)&&(Buffer[4]==0x1d))         //如果检测到是第8页面则处理数据
                        PAGE8 =20;                                  //5秒中内停留 表示正在设置初始电量值;
                        //TENT = 100;                                //
//****************判断ENT键按下与否*******************************   ENT键按下的话20站号变成1
         if(RR ==2)
             if(Rcv == 0x14)
                                    j = 1;
                                    Buffer[0]=Rcv;
                    else
                                    if(j < 5)                             //5个字节
                                              Buffer[j] = Rcv;
                                                    j++;
                   if((Buffer[3]==0x01)&&(Buffer[4]==0x17))              //ENT键已经按下
                         RR = 3;
//******************************读取要修改的时间*******************************
         if(RR ==4)                                 //此时ENT已经清零
                      Buffer[j]=Rcv;
                      if(!i)
                          if(Buffer[j]== 0x0b)              //接收到11
                              Buffer[0] =0x0b;
                              j=1;                        //才开始类加
                    if(Buffer[1]== 0x06)
                          i = 1;
                if(i)
                     if(j< 15)
                        Buffer[j] = Rcv;
                        j++;
                     if(j==15)
                         i = 0;
                     if(Buffer[14]==(Buffer[3]+Buffer[5]+Buffer[7]+Buffer[9]+Buffer[11]+Buffer[13]+0x12))
                           RR = 0;
                           time_buf1[1] = Buffer[3] ;
                           time_buf1[2] = Buffer[5] ;
                           time_buf1[3] = Buffer[7] ;
                           time_buf1[4] = Buffer[9] ;
                           time_buf1[5] = Buffer[11];
                           time_buf1[6] = Buffer[13];
        if(1)
//ADC转换完成中断服务程序   VectorNumber_Vadc中断向量号23
interrupt VectorNumber_Vadc void ADC_ISR(void)
  static byte count;
        switch(ADch_s)
            case 19:
            ADCbuffer1[count]=ADCRL;
            count++;
            if (count > N-1){
              count = 0;
              ADCSC1=0x00;
              ADcount = 1;
            break;
            case 11:
            count++;
            if (count > N-1){
              count = 0;
              ADCSC1=0x00;
             ADcount = 2;
            break;
            case 3:
            count++;
            if (count > N-1){
              count = 0;
              ADCSC1=0x00;
              ADcount = 3;
            break;
            case 4:
            count++;
            if (count > N-1){
              count = 0;
              ADCSC1=0x00;
              ADcount = 4;
            break;
            default:break;
          asm(nop);                               //在此设置一个断点,观测ad_h和ad_l的变化
 楼主| 发表于 2012-12-13 10:36:29 | 显示全部楼层
我的处理器是ARM A5和M4双核的 ADC难道是集成在M4里的???ADC的feature和拉普兰多笔记里的差不多 寄存器地址都一样, 我在写ADC的driver 驱动要在linux底层实现 ,注册成misc设备 很多可配置项用IOCTL接口配置 怎么这里的driver那么怪呀???
    发表于 2012-12-13 11:49:40 | 显示全部楼层
    回复:哪位老师有ADC的驱动程序呀?能发给我一个吗??
    首先,应该明确一下芯片。
    adc feature:
    Up to 10 ENOB (dedicated Single Ended Channels)最高10个单独采集通道
    • Up to 1MS/s sampling rate最高采样频率是1MS/s
    • 12-bit,
    • 10-bit
    • 8-bit
    • Configurable sample time and conversion speed/power   可以配置采样时间和转换速率、功耗
    • Asynchronous clock source for lower noise operation with option to output the clock输出时钟是 异步时钟低噪音操作
    • Selectable asynchronous hardware conversion trigger 选择异步硬件转换触发
    • Selectable voltage reference, Internal, External, or Alternate Alternate 是替补参考时钟
    • Automatic compare with interrupt for less-than, greater-than or equal-to, within 自动完成中断,可以是内在的 less-than, greater-than or equal-to
    还有几个疑问:
    1,ADC模块有ADC0和ADC1,除了基地址不同寄存器什么的都一样,在驱动里怎么注册这设备呀?注册两个??但看时钟部分就是ADC 一个设备呀???请问用的是什么系统?
    2,ADC0和ADC1 都有8通道外部接入一个时间点只有一路转换。可我作为客户要同时接入比如说6路,这六路我都要不断地需要转换的结果,驱动里怎么实现啊????使用多通道采集
    当选择开启硬件触发,转换是在Alternate 硬件触发输入随着各自的硬件触发输入激活的脉冲下降沿开始的。
    这句话大概是这个意思,可能翻译的也不太准确。
     楼主| 发表于 2012-12-13 13:15:55 | 显示全部楼层
    1,linux内核底层驱动,linux系统吧
    2,多通道采集???每一时间点只有一个通道在转换啊,,怎么实现多通道采集???
    3,硬件触发 是指被接入的脉冲信号触发???我接入的滑动变阻器,不能产生触发所需要的脉冲???结果是貌似没能触发,数据寄存器里一直没被写入数据
     楼主| 发表于 2012-12-13 13:22:10 | 显示全部楼层
    1,硬件触发模式中,是外部接入脉冲,达到触发条件,才会初始化一个转换吗?用滑动变阻器能触发吗???希望您解释一下何所谓硬件触发???
    2,如果用户需要同时接入多通道,比如8通道。而且用户对这8个通道都是需要随时读取数据的,驱动里怎么实现啊???我在写linux地层的ADC驱动
     楼主| 发表于 2012-12-13 13:38:27 | 显示全部楼层
    ADC的驱动中的feature
    用户要是同时接入16路,而且需要随时读取每路的值,在驱动力怎么实现啊??
    单次或者连续转换 是用户可以调函数来配置吗?
    • 12-bit,
    • 10-bit
    • 8-bit
    这三个sample ,speed,power也都是用户天用函数可配置吗?
    这一条是什么意思啊???异步时钟作为ADC的工作时钟来降噪?异步时钟是哪来的呀???外部接入的???还是ADC自己产生的??output the clock是什么意思啊???ADC会产生异步时钟输出???
    • Selectable asynchronous hardware conversion trigger with hardware channel select
    硬件触发了通道后,还要在软件里打开对应的通道吧???
    这一条很迷惑,完全不知是什么功能??
    发表于 2012-12-13 14:09:27 | 显示全部楼层
    1、linux驱动的话,建议还是看一下linux的例程,肯定有多通道采集的
    2、触发方式,这个应该是达到最低电压才会触发吧,我看说明是这样理解的
    3、请问你用的是什么芯片
     楼主| 发表于 2012-12-13 15:34:56 | 显示全部楼层
    谢谢您!
    1,linux例程在哪啊???能发给我一份吗??
    2,硬件触发条件是最低电压???手册里是这样描述的:
    您能帮我看看是什么意思吗?
    3,我用的芯片是公司未发布的一款A5和M4双核的ARM处理器,集成了一个ADC,估计是集成在M4上,ADC的feature和《M4笔记》第七章描述的ADC几乎一样,只不过我的驱动要写在linux内核地层,要注册misc设备,提供IOCTL函数等,
    您能把linux的例程发给我吗???
    4,很多feature都是可配置可选择的,那些配置和选择是要用户通过函数来配置吗???驱动不能把feature写死吧??
     楼主| 发表于 2012-12-14 11:01:54 | 显示全部楼层
    管理员 安:
    有linux例程的资源吗???
    GMT+8, 2025-10-29 05:29 , Processed in 0.112964 second(s), 29 queries , MemCache On.
