查看: 4688|回复: 3
[CodeWarrior] codewarrior编译时command窗口出现这样的调试信息,这是什么意思?
发表于 2013-1-24 09:13:04 | 显示全部楼层 |阅读模式
codewarrior下载调试时command窗口出现这样的调试信息,这是什么意思?大侠求解!
GDI:   DiExecContinue()==> DI_OK
FP: End run applet (WaitUntilStopped).
GDI:   Reading From Memory Address: 0x0807, count: 1
GDI:   DiMemoryRead()==> DI_OK
GDI:   01
FP: Erase command.
FP: Begin writing Control applet code.
GDI:   Writing To Memory Address: 0x0800, count: 282
GDI:   00 80 00 00 40 00 00 00 0A 64 18 0B 40 00 3C 14 10 1B FA 01 05 0E F9 EC 01 05 63 F9 EA 20 10 07
GDI:   54 07 0F 15 FA 00 89 20 03 62 F9 DB 62 F9 D8 00 20 FD 18 0B FF 01 04 18 0C 01 05 01 05 79 01 02
GDI:   18 0B 02 01 05 18 0B 10 01 02 7C 80 00 18 0B 41 01 06 C6 80 7B 01 05 1F 01 05 30 10 1F 01 05 40
GDI:   FB 86 02 6A F9 A1 15 FA 00 46 20 C3 1F 01 05 40 FB 79 01 02 *** 1F 01 00 7F 01 *** EC F9 8A CD 00
GDI:   08 13 6C FA 00 09 CE 00 64 18 10 26 04 20 9A 00 00 8E 00 3F 23 14 EC D7 49 49 49 CE 00 64 18 10
GDI:   27 EB 8E 00 3F 22 E6 1A E0 40 B7 54 7B 01 00 *** E6 F9 53 C4 20 27 01 *** C6 FE F1 FF 0F 26 01 ***
GDI:   18 0B FF 01 04 18 0C 01 05 01 05 79 01 02 18 0B 02 01 05 18 0B 00 01 03 B6 FF 0E C6 FE 7C FF 0E
GDI:   C6 20 7B 01 06 C6 80 7B 01 05 F6 01 05 C5 30 27 04 18 20 FF 34 1F 01 05 40 FB C6 FE F1 FF 0F 26
GDI:   F0 *** 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
GDI:   DiMemoryWrite()==> DI_OK
GDI:   Reading From Memory Address: 0x0800, count: 282
FP: End writing Control applet code.
FP: Begin writing Control applet parameters.
FP: 0800-3E 80 00 01 40 00 01 00 03 E8
GDI:   Writing To Memory Address: 0x0800, count: 10
GDI:   3E 80 00 01 40 00 01 00 03 E8
GDI:   Reading From Memory Address: 0x0800, count: 10
FP: End writing Control applet parameters.
FP: Run applet (WaitUntilStopped).
GDI:   Writing Register: PC (id:0): 0x080A
GDI:   DiRegisterWrite()==> DI_OK
EXEC_Run();
我知道答案 目前已有2人回答
GDI.txt
48.78 KB, 下载次数: 1, 下载积分: 威望 1
发表于 2013-1-24 10:33:54 | 显示全部楼层
RE:codewarrior编译时command窗口出现这样的调试信息,这是什么意思?
没事,这个是BDM操作命令。
 楼主| 发表于 2013-1-24 17:23:50 | 显示全部楼层
回复:codewarrior编译时command窗口出现这样的调试信息,这是什么意思?
回复第 2 楼 于2013-01-24 10:33:54发表:
没事,这个是BDM操作命令。
,    谢谢大侠!
发表于 2013-1-24 20:54:31 | 显示全部楼层
这个很正常啊,操作正确,程序共282个字节,下载正确,ok啊
GMT+8, 2026-4-16 13:37 , Processed in 0.099269 second(s), 25 queries , Redis On.
