查看: 2919|回复: 4
[其他] MCF51AC128汇编时候出现的问题
发表于 2013-2-14 22:58:25 | 显示全部楼层 |阅读模式
芯片复位后无法跳到规定的指令段0X410运行,0X04原本是指向复位后PC的值的结果为0,代码如下
//中断向量文件
    .text
 * Exception Vector Table
VECTOR_TABLE:
_VECTOR_TABLE:
INITSP:          .long    __SP_INIT                    /* Initial SP            */
INITPC:          .long    _asm_startmeup              /* Initial PC            */
vector002:    .long    asm_exception_handler    /* Access Error            */
vector003:    .long    asm_exception_handler    /* Address Error        */
vector004:    .long    asm_exception_handler    /* Illegal Instruction    */
vector005:    .long    asm_exception_handler    /* Reserved                */
vector006:    .long    asm_exception_handler    /* Reserved                */
vector007:    .long    asm_exception_handler    /* Reserved                */
vector008:    .long    asm_exception_handler    /* Privilege Violation    */
vector009:    .long    asm_exception_handler    /* Trace                */
vector010:    .long    asm_exception_handler    /* Unimplemented A-Line    */
vector011:    .long    asm_exception_handler    /* Unimplemented F-Line    */
vector012:    .long    asm_exception_handler    /* Debug Interrupt        */
vector013:    .long    asm_exception_handler    /* Reserved                */
vector014:    .long    asm_exception_handler    /* Format Error            */
vector015:    .long    asm_exception_handler    /* Unitialized Int.        */
vector016:    .long    asm_exception_handler    /* Reserved                */
vector017:    .long    asm_exception_handler    /* Reserved                */
vector018:    .long    asm_exception_handler    /* Reserved                */
vector019:    .long    asm_exception_handler    /* Reserved                */
vector020:    .long    asm_exception_handler    /* Reserved                */
vector021:    .long    asm_exception_handler    /* Reserved                */
vector022:    .long    asm_exception_handler    /* Reserved                */
vector023:    .long    asm_exception_handler    /* Reserved                */
vector024:    .long    asm_exception_handler    /* Spurious Interrupt    */
vector025:    .long    asm_exception_handler    /* Autovector Level 1    */
vector026:    .long    asm_exception_handler    /* Autovector Level 2    */
vector027:    .long    asm_exception_handler    /* Autovector Level 3    */
vector028:    .long    asm_exception_handler    /* Autovector Level 4    */
vector029:    .long    asm_exception_handler    /* Autovector Level 5    */
vector030:    .long    asm_exception_handler    /* Autovector Level 6    */
vector031:    .long    asm_exception_handler    /* Autovector Level 7    */
vector032:    .long    asm_exception_handler    /* TRAP #0                */
vector033:    .long    asm_exception_handler    /* TRAP #1                */
vector034:    .long    asm_exception_handler    /* TRAP #2                */
vector035:    .long    asm_exception_handler    /* TRAP #3                */
vector036:    .long    asm_exception_handler    /* TRAP #4                */
vector037:    .long    asm_exception_handler    /* TRAP #5                */
vector038:    .long    asm_exception_handler    /* TRAP #6                */
vector039:    .long    asm_exception_handler    /* TRAP #7                */
vector040:    .long    asm_exception_handler    /* TRAP #8                */
vector041:    .long    asm_exception_handler    /* TRAP #9                */
vector042:    .long    asm_exception_handler    /* TRAP #10                */
vector043:    .long    asm_exception_handler    /* TRAP #11                */
vector044:    .long    asm_exception_handler    /* TRAP #12                */
vector045:    .long    asm_exception_handler    /* TRAP #13                */
vector046:    .long    asm_exception_handler    /* TRAP #14                */
vector047:    .long    asm_exception_handler    /* TRAP #15                */
vector048:    .long    asm_exception_handler    /* Reserved                */
vector049:    .long    asm_exception_handler    /* Reserved                */
vector050:    .long    asm_exception_handler    /* Reserved                */
vector051:    .long    asm_exception_handler    /* Reserved                */
vector052:    .long    asm_exception_handler    /* Reserved                */
vector053:    .long    asm_exception_handler    /* Reserved                */
vector054:    .long    asm_exception_handler    /* Reserved                */
vector055:    .long    asm_exception_handler    /* Reserved                */
vector056:    .long    asm_exception_handler    /* Reserved                */
vector057:    .long    asm_exception_handler    /* Reserved                */
vector058:    .long    asm_exception_handler    /* Reserved                */
vector059:    .long    asm_exception_handler    /* Reserved                */
vector060:    .long    asm_exception_handler    /* Reserved                */
vector061:    .long    asm_exception_handler    /* Reserved                */
vector062:    .long    asm_exception_handler    /* Reserved                */
vector063:    .long    asm_exception_handler    /* Reserved                */
vector064:    .long    asm_exception_handler    /* IRQ_Pin                */
vector065:    .long    asm_exception_handler    /* Low_Voltage        */
vector066:    .long    asm_tpm1_ch0_handler    /* TPM1_ch0           */
vector067:    .long    asm_exception_handler    /* TPM1_ch1           */
vector068:    .long    asm_exception_handler    /* TPM1_ch2           */
vector069:    .long    asm_exception_handler    /* TPM1_ovfl           */
vector070:    .long    asm_exception_handler    /* TPM2_ch0           */
vector071:    .long    asm_exception_handler    /* TPM2_ch1           */
vector072:    .long    asm_exception_handler    /* TPM2_ch2           */
vector073:    .long    asm_exception_handler    /* TPM2_ovfl           */
vector074:    .long    asm_exception_handler    /* SPI2               */
vector075:    .long    asm_exception_handler    /* SPI1               */
vector076:    .long    asm_exception_handler    /* SCI1_err            */
vector077:    .long    asm_exception_handler    /* SCI1_rx             */
vector078:    .long    asm_exception_handler    /* SCI1_tx            */
vector079:    .long    asm_exception_handler    /* IICx               */
vector080:    .long    asm_exception_handler    /* KBIx               */
vector081:    .long    asm_exception_handler    /* ADC                */
vector082:    .long    asm_exception_handler    /* ACMPx               */
vector083:    .long    asm_exception_handler    /* SCI2_err            */
vector084:    .long    asm_exception_handler    /* SCI2_rx             */
vector085:    .long    asm_exception_handler    /* SCI2_tx             */
vector086:    .long    asm_exception_handler    /* RTC                */
vector087:    .long    asm_exception_handler /* TPM3_ch0           */
vector088:    .long    asm_exception_handler /* TPM3_ch1           */
vector089:    .long    asm_exception_handler /* TPM3_ch2           */
vector090:    .long    asm_exception_handler /* TPM3_ch3           */
vector091:    .long    asm_exception_handler /* TPM3_ch4           */
vector092:    .long    asm_exception_handler /* TPM3_ch5           */
vector093:    .long    asm_exception_handler /* TPM3_ovrfl          */
vector094:    .long    asm_exception_handler /* Reserved           */
vector095:    .long    asm_exception_handler /* Reserved           */
vector096:    .long    asm_exception_handler /* Level 7 SWI         */
vector097:    .long    asm_exception_handler /* Level 6 SWI         */
vector098:    .long    asm_exception_handler /* Level 5 SWI         */
vector099:    .long    asm_exception_handler /* Level 4 SWI         */
vector100:    .long    asm_exception_handler /* Level 3 SWI         */
vector101:    .long    asm_exception_handler /* Level 2 SWI         */
vector102:    .long    asm_exception_handler /* Level 1 SWI         */
    .end
//主程序masm.asm
  .extern   ___SP_INIT
  .global _asm_function
  .global _main
  .global _Init_Timer
  .global _wait
  .global _asm_startmeup
  .include "derivative.inc"
    .text
    .function "_asm_startmeup",_asm_startmeup,_asm_startmeup_end-_asm_startmeup
 _asm_startmeup:
  /* disable interrupts */
  move.w        #0x2700,SR
  /* setup the stack pointer */
  lea           ___SP_INIT,A7
  /* setup A6 dummy stackframe */
  movea.l       #0,A6
  link          A6,#0
_main:
       bsr.l    _Init_Timer
       clr.l    D4             /* Initialize timeouts (0=off) */
       clr.l    D5
       clr.l    D6
       move.b   #$03,D0
       move.b   D0,SOPT1
       move.b   #$F,D4         /* Schedule a timeout1 event ~ 160ms @ 4MHz Bus Frequency */
       move.b   #$FF,D0
       move.b   D0,PTFDD       /* Set DEMOQE led ports as outputs */
       move.b   #$0,D0
       move.b   D0,PTFD
       move.b   #$C0,D0
       move.b   D0,PTEDD
       move.b   #$20,D0
       move.b   D0,PTBD
       move.b   #$3F,D0
       move.b   D0,PTCD
       move.b   #$C0,D0
       move.b   D0,PTED
  /* enable interrupts */
       move     SR,D0
       andi.l   #0xF8FF,D0
       move     D0,SR
_wait:
  bra _wait
* Init_Timer - Turns on timer 1 channel 0 for an Output      *
*              Compare in approximately 10ms. The timer      *
*              interrupt service routine continually sets    *
*              the next interrupt to occur 10ms later.       *
_Init_Timer:
       move.b   #$06,D0
       move.b   D0,TPM1SC      /* Timer 1 - Cleared + Stopped.
                                  Clicks once every 64 BUS Cycles
                                        Bus Clock Selected */
       move.b   #$54,D0
       move.b   D0,TPM1C0SC    /* Timer 1 Channel 0
                                  Set for Output Compare operation. */
       move.b   #$02,D0
       move.b   D0,TPM1C0VH    /* Set Output Compare to happen 622T clicks ($26e) */
       move.b   #$6e,D0
       move.b   D0,TPM1C0VL    /* after we start the timer. (~10ms). The
                                  timer interrupt will set OC for another ~10ms. */
       move.b   #$0E,D0
       move.b   D0,TPM1SC      /* Start the timer */
       rts
_asm_startmeup_end:
    .end
/* This source is (C)opyright 2003, P&E Microcomputer Systems, Inc.
   Visit us at http://www.pemicro.com */
 楼主| 发表于 2013-2-14 22:59:22 | 显示全部楼层
RE:MCF51AC128汇编时候出现的问题
复位后一直跳到0X0处指向代码,是完全用汇编编写的程序
发表于 2013-2-16 09:21:00 | 显示全部楼层
应该是你的定时中断的找不到跳转的函数。
 楼主| 发表于 2013-2-20 18:34:32 | 显示全部楼层
回复:MCF51AC128汇编时候出现的问题
回复第 3 楼 于2013-02-16 09:21:00发表:
应该是你的定时中断的找不到跳转的函数。
我看0000H 0004H都是FF,这样应该是编译生成的代码没下载到指定地方才是
发表于 2013-2-21 09:33:21 | 显示全部楼层
说明编译的时候并没有将中断跳转地址填写进去,看一下你的中断入口函数那填写是否正确。
GMT+8, 2026-4-16 15:31 , Processed in 0.085966 second(s), 25 queries , Redis On.
