查看: 3663|回复: 1
MX51 Babbage Linux version 2.6.35.3 otg usb不能识别 求高手解惑
发表于 2013-2-21 10:23:05 | 显示全部楼层 |阅读模式
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: irq status 008c FLR PCD
Jan  1 08:01:47 lucid-desktop kernel: hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: GetStatus port 1 status 14001403 POWER sig=k CSC CONNECT
Jan  1 08:01:47 lucid-desktop kernel: hub 1-0:1.0: port 1, status 0301, change 0001, 1.5 Mb/s
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: GetStatus port 1 status 14001401 POWER sig=k CONNECT
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: GetStatus port 1 status 10001803 POWER sig=j CSC CONNECT
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: GetStatus port 1 status 10001801 POWER sig=j CONNECT
Jan  1 08:01:47 lucid-desktop kernel: last message repeated 3 times
Jan  1 08:01:47 lucid-desktop kernel: hub 1-0:1.0: debounce: port 1: total 125ms stable 100ms status 0x101
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: port 1 reset
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: GetStatus port 1 status 18001205 POWER sig=se0 PE CONNECT
Jan  1 08:01:47 lucid-desktop kernel: usb 1-1: new high speed USB device using fsl-ehci and address 2
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: submit_async 1 urb 99d18080 ep0out len 64, qtd fa0a7060 [qh (null)]
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: irq status 808a Async FLR ERR
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: detected XactErr len 0/8 retry 1
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: detected XactErr len 0/64 retry 1
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: detected XactErr len 0/64 retry 2
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: detected XactErr len 0/64 retry 3
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: detected XactErr len 0/64 retry 4
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: detected XactErr len 0/64 retry 5
Jan  1 08:01:47 lucid-desktop kernel: fsl-ehci fsl-ehci.0: detected XactErr len 0/64 retry 6
设置完地址 后获取设备描述符 失败
发表于 2013-2-21 14:01:15 | 显示全部楼层
RE:MX51 Babbage Linux version 2.6.35.3 otg usb不能识别 求高手解惑
irq status 808a Async FLR ERR,应该是找不到IRQ 808A,这个你注意看一下。
GMT+8, 2025-12-10 09:44 , Processed in 0.074016 second(s), 21 queries , Redis On.
