查看: 2771|回复: 1
[CodeWarrior] codewarrior5.1的PE配置eeprom问题
发表于 2013-3-14 10:07:36 | 显示全部楼层 |阅读模式
 在用pe配置eeprom出现
ERROR: Compiler option -CpPPAGE=0x15 (address of PPAGE register) or -CpPPAGE=RUNTIME must be set to compile the generated code correctly (current target settings, Compiler for HC12, Options, Code Generation tab, PPAGE register is used for paging). After compiler option change, run Code design to apply the change in Processor Expert. For details, see Help of the component.
求解是什么问题?谢谢!
我知道答案 目前已有0人回答
    发表于 2013-3-14 14:53:56 | 显示全部楼层
    RE:codewarrior5.1的PE配置eeprom问题
    编译器配置错误,请点击查看帮助是什么问题导致的。
    GMT+8, 2026-4-16 15:29 , Processed in 0.089389 second(s), 22 queries , Redis On.
