查看: 2568|回复: 3
[求助] KM3x: Kinetis KM 1 or 2 Phase Electricity Meter MCU for Metrology
发表于 2013-3-28 10:51:01 | 显示全部楼层 |阅读模式
 The new Kinetis KM metering MCUs leverage the successful Kinetis MCU family based on the ARM® Cortex™-M0+ core. The Kinetis KM series supports low-cost, highly integrated solutions for 1 or 2 phase electricity meters with high accuracy analog front end. This metering front end integrates a high accuracy sigma delta ADC.
The Kinetis KM metering MCUs have dedicated peripherals to address specific regional specifications for a range of smart energy and smart metering applications. Full metrology software including time or filter based is seamlessly integrated as well as FFT.
[size=1em]
特性
[url=https://www.freescale.co
m/zh-Hans/webapp/sps/site/prod_summary.jsp?code=KM3x&webpageId=134825875385271595FA7D&nodeId=01624698C9FA7D&fromPage=tax#]MCU[/url]
  • High-performance ARM® Cortex™-M0 core, up to 50 MHz of core clock frequency
  • 128 KB/64 KB single array flash
  • Supports v6-M Instruction Set Architecture (ISA) including all 16-bit v7-M instructions plus a number of 32-bit thumb-2 instructions
  • PLL to generate clocks for AFE
    • Input range: 31.25 kHz to 39.0625 kHz
    • Output range: 11.72 MHz to 14.65 MHz
  • FLL to generate core, system and flash clocks
    • Output Range: 20 MHz to 50 MHz
  • Flexible modes of operation
  • Two internal trim-able clock references
    • 32 kHz
    • 4 MHz
m/zh-Hans/webapp/sps/site/prod_summary.jsp?code=KM3x&webpageId=134825875385271595FA7D&nodeId=01624698C9FA7D&fromPage=tax#]Analog Front End[/url]
  • 24-bit sigma delta ADC with 94 dB SNR
  • Programmable gain amplifier with gains from 1 to 32 with low temperature drift
  • High precision internal voltage reference with low temperature drift
m/zh-Hans/webapp/sps/site/prod_summary.jsp?code=KM3x&webpageId=134825875385271595FA7D&nodeId=01624698C9FA7D&fromPage=tax#]Security[/url]
  • Tamper detection with time stamping
  • Random number generator, memory protection unit
m/zh-Hans/webapp/sps/site/prod_summary.jsp?code=KM3x&webpageId=134825875385271595FA7D&nodeId=01624698C9FA7D&fromPage=tax#]Interfaces[/url]
  • LCD segment driver up to 288 (8x36)
  • High accuracy RTC +5 ppm over temperature range
  • 4x UART, 2x SPI, 2x IIC
m/zh-Hans/webapp/sps/site/prod_summary.jsp?code=KM3x&webpageId=134825875385271595FA7D&nodeId=01624698C9FA7D&fromPage=tax#]Operating Voltage and Temperature Range[/url]
  • Voltage range 1.71 volts - 3.6 volts (without AFE)
  • Voltage range 2.7 volts - 3.6 volts (with AFE)
  • Temperature range -40°C to 85°C
推荐文档
  • KNTSKM3XFS: Photon Kinetis KM Metering MCUs - Fact Sheet
我知道答案 目前已有2人回答
发表于 2013-4-10 13:49:25 | 显示全部楼层
RE:KM3x: Kinetis KM 1 or 2 Phase Electricity Meter MCU for Metrology
什么时候有样片呀?
发表于 2013-4-15 21:30:38 | 显示全部楼层
还没出来吧 ADI的也有24位AD的M3
发表于 2013-8-7 11:19:33 | 显示全部楼层
目前还没有正事的发布。
GMT+8, 2025-10-13 01:48 , Processed in 0.089991 second(s), 24 queries , MemCache On.
