查看: 2245|回复: 2
[其他] 请教这个prm文件为什么不能使用RTC中断呢
发表于 2013-4-26 14:23:00 | 显示全部楼层 |阅读模式
 /* This is a linker parameter file for the mc9s08dz60 */
NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
    Z_RAM                    =  READ_WRITE   0x0080 TO 0x00FF;
    RAM                      =  READ_WRITE   0x0100 TO 0x107F;
    ROM                      =  READ_ONLY    0x1900 TO 0xFFAD;
    ROM1                     =  READ_ONLY    0x1080 TO 0x13FF;
    EEPROM                   =  READ_ONLY    0x1400 TO 0x17FF;
 /* INTVECTS                 =  READ_ONLY    0xFFC0 TO 0xFFFF; Reserved for Interrupt Vectors */
END
PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined above. */
    DEFAULT_RAM                         /* non-zero page variables */
                                        INTO  RAM;
    _PRESTART,                          /* startup code */
    STARTUP,                            /* startup data structures */
    ROM_VAR,                            /* constant variables */
    STRINGS,                            /* string literals */
    VIRTUAL_TABLE_SEGMENT,              /* C++ virtual table segment */
    DEFAULT_ROM,
    COPY                                /* copy down information: how to initialize variables */
                                        INTO  ROM; /* ,ROM1: To use "ROM1" as well, pass the option -OnB=b to the compiler */
    _DATA_ZEROPAGE,                     /* zero page variables */
    MY_ZEROPAGE                         INTO  Z_RAM;
END
STACKSIZE 0x50
VECTOR 0 _Startup /* Reset vector: this is the default entry point for an application. */
这样的一个prm文件为什么使用RTC中断就打不开呢
我在主程序中中断函数名这样写的void interrupt 25 Rtc_Isr(void)
我知道答案 目前已有1人回答
 楼主| 发表于 2013-4-26 14:38:49 | 显示全部楼层
回复:请教这个prm文件为什么不能使用RTC中断呢
也就是rtc的地址0xFFCC这个地方他设置了只读形式、、是这个问题吗?
 楼主| 发表于 2013-4-26 14:40:27 | 显示全部楼层
 不好意思 这个prm发错了 应该是底下这个 是这个prm文件不能进行RTC中断
/* This is a linker parameter file for the DZ60 */
    MSCAN_START              =  NO_INIT      0x1880 TO 0x1880;
    ROM                      =  READ_ONLY    0x1900 TO 0xFFBF;
    EEPROM                   =  NO_INIT      0x1400 TO 0x17FF;
    VECTORS                  =  READ_WRITE    0xFFC0 TO 0xFFFF;
END
    MSCAN                               INTO  MSCAN_START;
    DEFAULT_RAM                         INTO  RAM;
    DEFAULT_ROM, ROM_VAR, STRINGS       INTO  ROM; /* ROM1 In case you want to use ROM1 as well, be sure the option -OnB=b is passed to the compiler. */
    ZeroSeg,
    _DATA_ZEROPAGE, MY_ZEROPAGE         INTO  Z_RAM;
           VECTORS_DATA                                    INTO  VECTORS;
END
STACKSIZE 0x50
ENTRIES
_vectab
END
GMT+8, 2025-10-23 11:47 , Processed in 0.084091 second(s), 23 queries , MemCache On.
