查看: 3353|回复: 2
[MQX] MQX运行需要多大内存
发表于 2013-5-4 20:37:36 | 显示全部楼层 |阅读模式
各位搞过MQX的大侠,请问,MQX实时操作系统运行时需要提供多大的RAM?
我知道答案 目前已有1人回答
发表于 2013-5-6 21:47:52 | 显示全部楼层
RE:MQX运行需要多大内存
Small code density – The Freescale MQX RTOS was designed for speed and size efficiency in embedded systems. The RTOS delivers true real-time performance, with context switch and low-level interrupt routines hand-optimized in assembly, and can be configured to take as little as 12 KB of ROM and 2.5K RAM on CFV2, including kernel, 2 task applications,1 LW Semaphore, interrupt stack, queues, and memory manager.
实际上肯定还有应用程序,还有各种协议栈,比这个要高,
 楼主| 发表于 2013-6-8 22:29:22 | 显示全部楼层
回复:MQX运行需要多大内存
回复第 2 楼 于2013-05-06 21:47:52发表:
非常感谢
GMT+8, 2026-4-5 00:28 , Processed in 0.080212 second(s), 23 queries , Redis On.
