查看: 3977|回复: 0
[MQX] 求助:mqx3.8例程中GPIO管脚上升沿中断问题
发表于 2013-5-9 10:08:19 | 显示全部楼层 |阅读模式
飞思卡尔MQX3.8中的GPIO例程中(Freescale MQX 3.8\mqx\examples\gpio),gpio.c中
        GPIO_PIN_STRUCT pins_int[] = {
            BSP_BUTTON1 | GPIO_PIN_IRQ_FALLING,(改为上升沿触发)
            GPIO_LIST_END
        /* opening pins/signals for input */
        if (NULL == (port_file4 = fopen("gpio:read", (char_ptr) &pins_int )))
           printf("Opening file4 GPIO with associated pins failed.\n");
          _task_block();
        /* install gpio interrupt callback */
        ioctl(port_file4, GPIO_IOCTL_SET_IRQ_FUNCTION, (pointer)int_callback);
        while (int_counter < 5);
        fclose(port_file4);
    }改动后,fopen函数中,中断使能后就进入中断了。我怎么修改呢?
是否需要修改bsp或者psp中的函数吗?
那位大侠帮解答一下。。。。
我知道答案 目前已有0人回答
GMT+8, 2025-10-23 09:38 , Processed in 0.090820 second(s), 20 queries , MemCache On.
