查看: 22290|回复: 12
[已解决] A9四核开发板启动异常(已解决)
发表于 2013-5-30 16:17:54 | 显示全部楼层 |阅读模式
正在使用ARM Cortex-A9飞思卡尔Freescale四核SABER Lite评估板,自带的u-boot.bin文件、uImage文件和rootfs.tar.bz2文件都能正常烧进去,但是启动的时候出现异常,到BusyBox中断,过不去
我知道答案 目前已有11人回答
发表于 2013-5-30 16:58:39 | 显示全部楼层
RE:A9四核开发板启动异常
你能不能提供一下log记录信息?
 楼主| 发表于 2013-5-31 11:37:58 | 显示全部楼层
RE:A9四核开发板启动异常
Control: 10c53c7d  Table: 4fb2c04a  DAC: 00000015
Process kinteractiveup (pid: 1331, stack limit = 0xbfe6a2f0)
Stack: (0xbfe6bec8 to 0xbfe6c000)
bec0:                   00000000 800586c0 800585f8 80a7d020 3b5dc100 001312d0
bee0: 80ac3470 001312d0 00000000 179a7b00 804e56b0 80062f70 ffffffff 3b5dc100
bf00: 001312d0 80065b40 bf9ff240 00000004 ffffffff 80a75ac4 00000004 000f32a0
bf20: 3b5dc100 80065e54 bfe6bf5c 160ece0d bfe6bf58 8c020568 00000003 00000003
bf40: 00060ae0 000f32a0 8c020501 34bedfab bfe6bf78 80079730 0000000a 00000000
bf60: 8c020dd0 80a75abc 80a75abc 80a75b00 bfe6a000 80a75cc0 804e56ac 80ae1578
bf80: 000f32a0 80365bb0 00000000 8036a55c 8c008d90 8003cd90 8003cd90 00000000
bfa0: bfe6bfc4 bff8bf30 00000000 8036a3f4 00000013 00000000 00000000 00000000
bfc0: 00000000 8008e904 80044a24 00000000 00000000 00000000 00000000 00000000
bfe0: bfe6bfe0 bfe6bfe0 bff8bf30 8008e884 80044a24 80044a24 df7af7ff 5fcefbff
[] (clk_get_rate+0x40/0x50) from [] (_clk_arm_set_rate+0xc8/0x330)
[] (_clk_arm_set_rate+0xc8/0x330) from [] (clk_set_rate+0x40/0x60)
[] (clk_set_rate+0x40/0x60) from [] (set_cpu_freq+0x100/0x1fc)
[] (set_cpu_freq+0x100/0x1fc) from [] (mxc_set_target+0xf4/0x220)
[] (mxc_set_target+0xf4/0x220) from [] (__cpufreq_driver_target+0x50/0x64)
[] (__cpufreq_driver_target+0x50/0x64) from [] (cpufreq_interactive_up_task+0x168/0x1b4)
[] (cpufreq_interactive_up_task+0x168/0x1b4) from [] (kthread+0x80/0x88)
[] (kthread+0x80/0x88) from [] (kernel_thread_exit+0x0/0x8)
Code: bad PC value
---[ end trace f779f64afb2571ec ]---
note: kinteractiveup[1331] exited with preempt_count 1
modprobe: module ft5x06_ts not found in modules.dep
^A^H^H^H^H^H^H
U-Boot 2009.08-dirty (Jan 17 2013 - 06:55:57)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Temperature:   25 C, calibration data 0x59b5117d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 29333333Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: MX6Q-SABRELITE:[ POR]
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1
JEDEC ID: 0xbf:0x25:0x41
Reading SPI NOR flash 0xc0000 [0x2000 bytes] -> ram 0x276009b8
SUCCESS
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Card did not respond to voltage select!
mmc0(part 0) is current device
MMC: block number 0x1 exceeds max(0x0)
** Can't read from device 0 **
** Unable to use mmc 0:1 for fatload **
** Bad partition 1 **
mmc1 is current device
reading /6q_bootscript
** Unable to read "/6q_bootscript" from mmc 1:1 **
Loading file "/6q_bootscript" from mmc device 1:1 (xxb1)
233 bytes read
## Executing script at 10008000
Loading file "/boot/uImage" from mmc device 1:1 (xxb1)
3750800 bytes read
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.35-ts-armv7l
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3750736 Bytes =  3.6 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.35-ts-armv7l (root@bslave2-8) (gcc version 4.6.3 (Timesys 20130107) ) #1 SMP PREEMPT Thu Jan 17 06:53:58 EST 2013
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad Sabre-Lite Board
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, silicon rev 1.2
PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 227328
Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p1 rootwait fixrtc
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 640MB 256MB = 896MB total
Memory: 897040k/897040k available, 151536k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
    vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x8003e000   ( 216 kB)
      .text : 0x8003e000 - 0x80a63444   (10390 kB)
      .data : 0x80a64000 - 0x80ac2a80   ( 379 kB)
       .bss : 0x80ac2aa4 - 0x80b0e02c   ( 302 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:496
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
MXC_Early serial console at MMIO 0x21e8000 (options '115200')
bootconsole [ttymxc1] enabled
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725  1300 mV at 1150 mV fast normal
print_constraints: vddcore: 725  1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725  1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000  2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800  1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2800  3150 mV at 3000 mV fast normal
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
IMX usb wakeup probe
bio: create slab  at 0
print_constraints: VDDA: 2500 mV
print_constraints: VDDIO: 3300 mV
machine_constraints_voltage: VDDD: unsupportable voltage constraints
reg-fixed-voltage reg-fixed-voltage.2: Failed to register regulator: -22
reg-fixed-voltage: probe of reg-fixed-voltage.2 failed with error -22
print_constraints: vmmc: 3300 mV
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
add wake up source irq 75
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = c0880000 suspend_iram_base=c08fc000
PM driver module loaded
i.MXC CPU frequency driver
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 1752
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
_regulator_get: get() with no identifier
imx-ipuv3 imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver lcd
mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: ipu1-di1 already in use
mxc_sdc_fb: probe of mxc_sdc_fb.3 failed with error -16
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
console [ttymxc1] enabled, bootconsole disabled
loop: module loaded
Can't recover from RESET HBA!
No sata disk.
m25p80 spi0.0: sst25vf016b (2048 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000100000 : "bootloader"
0x000000100000-0x000000200000 : "kernel"
vcan: Virtual CAN interface driver
CAN device driver interface
flexcan netdevice driver
flexcan imx6q-flexcan.0: device registered (reg_base=c09a8000, irq=142)
FEC Ethernet Driver
fec_enet_mii_bus: probed
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ARC USBOTG Device Controller driver (1 August 2005)
mousedev: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Thermal calibration data is 0x59b5117d
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
mmc0: new high speed SDHC card at address 0007
mmcblk0: mmc0:0007 SD4GB 3.67 GiB
mmcblk0: p1
usb 2-1: new high speed USB device number 2 using fsl-ehci
caam caam.0: device ID = 0x0a16010000000000
caam caam.0: job rings = 2, qi = 0
alg: No test for authenc(hmac(md5),cbc(aes)) (authenc-hmac-md5-cbc-aes-caam)
caam caam.0: authenc-hmac-md5-cbc-aes-caam
alg: No test for authenc(hmac(sha1),cbc(aes)) (authenc-hmac-sha1-cbc-aes-caam)
caam caam.0: authenc-hmac-sha1-cbc-aes-caam
alg: No test for authenc(hmac(sha224),cbc(aes)) (authenc-hmac-sha224-cbc-aes-caam)
caam caam.0: authenc-hmac-sha224-cbc-aes-caam
alg: No test for authenc(hmac(sha256),cbc(aes)) (authenc-hmac-sha256-cbc-aes-caam)
caam caam.0: authenc-hmac-sha256-cbc-aes-caam
alg: No test for authenc(hmac(md5),cbc(des3_ede)) (authenc-hmac-md5-cbc-des3_ede-caam)
caam caam.0: authenc-hmac-md5-cbc-des3_ede-caam
alg: No test for authenc(hmac(sha1),cbc(des3_ede)) (authenc-hmac-sha1-cbc-des3_ede-caam)
caam caam.0: authenc-hmac-sha1-cbc-des3_ede-caam
alg: No test for authenc(hmac(sha224),cbc(des3_ede)) (authenc-hmac-sha224-cbc-des3_ede-caam)
caam caam.0: authenc-hmac-sha224-cbc-des3_ede-caam
alg: No test for authenc(hmac(sha256),cbc(des3_ede)) (authenc-hmac-sha256-cbc-des3_ede-caam)
caam caam.0: authenc-hmac-sha256-cbc-des3_ede-caam
alg: No test for authenc(hmac(md5),cbc(des)) (authenc-hmac-md5-cbc-des-caam)
caam caam.0: authenc-hmac-md5-cbc-des-caam
alg: No test for authenc(hmac(sha1),cbc(des)) (authenc-hmac-sha1-cbc-des-caam)
caam caam.0: authenc-hmac-sha1-cbc-des-caam
alg: No test for authenc(hmac(sha224),cbc(des)) (authenc-hmac-sha224-cbc-des-caam)
caam caam.0: authenc-hmac-sha224-cbc-des-caam
alg: No test for authenc(hmac(sha256),cbc(des)) (authenc-hmac-sha256-cbc-des-caam)
caam caam.0: authenc-hmac-sha256-cbc-des-caam
caam caam.0: cbc-aes-caam
caam caam.0: cbc-3des-caam
caam caam.0: cbc-des-caam
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 3 ports detected
platform caam_jr.0: registering rng-caam
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
sgtl5000 0-000a: Failed to get supply 'VDDD': -19
print_constraints: 0-000a: 850  1600 mV at 1200 mV normal
sgtl5000 0-000a: sgtl5000 revision 17
asoc: sgtl5000  imx-ssi.1 mapping ok
imx_3stack asoc driver
imx-hdmi-soc-dai: probe of imx-hdmi-soc-dai.0 failed with error -12
ALSA device list:
  #0: sgtl5000-audio
NET: Registered protocol family 26
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
lib80211: common routines for IEEE802.11 drivers
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: vddpu: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:01:21 UTC (81)
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p1): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): recovery complete
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:1.
Freeing init memory: 216K
init started: BusyBox v1.20.2 (2013-01-17 06:57:51 EST)
Setting hotplug handler: [ OK ]
Creating device files:
 楼主| 发表于 2013-5-31 11:41:00 | 显示全部楼层
RE:A9四核开发板启动异常
u-Boot没什么问题,经常运行到最后一行不能继续,10次能有那么2、3次正常起动,即使正常启动进行一些操作,跑跑就废了。
 楼主| 发表于 2013-5-31 11:43:13 | 显示全部楼层
RE:A9四核开发板启动异常
这是另一种情况
Flags: Nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 1000404a  DAC: 00000015
Process kinteractiveup (pid: 1331, stack limit = 0xbfc2c2f0)
Stack: (0xbfc2ded0 to 0xbfc2e000)
dec0:                                     800585f8 80a7d020 3b5dc100 001312d0
dee0: 80ac3470 001312d0 00000000 179a7b00 804e56b0 80062f70 ffffffff 3b5dc100
df00: 001312d0 80065b40 bf9ff240 00000004 ffffffff 80a75ac4 00000004 000f32a0
df20: 3b5dc100 80065e54 bfc2df5c 0858ddc9 bfc2df58 8c020568 00000003 00000003
df40: 00060ae0 000f32a0 8c020501 28ae8f8a bfc2df78 80079730 00000007 00000000
df60: 8c020dd0 80a75abc 80a75abc 80a75b00 bfc2c000 80a75cc0 804e56ac 80ae1578
df80: 000f32a0 80365bb0 00000000 8036a55c 8c008d90 8003cd90 8003cd90 00000000
dfa0: 00000013 bff8bf30 00000000 8036a3f4 00000013 00000000 00000000 00000000
dfc0: 00000000 8008e904 80044a24 00000000 00000000 00000000 00000000 00000000
dfe0: bfc2dfe0 bfc2dfe0 bff8bf30 8008e884 80044a24 80044a24 00000000 00000000
[] (_clk_arm_set_rate+0x1cc/0x330) from [] (clk_set_rate+0x40/0x60)
Code: e595202c e5963040 e082a00a e59f013c (e59a1004)
---[ end trace 01c1bacda1dd3636 ]---
Creating device files: Auto-mount of [/media/mmcblk0p1] successful
[ OK ]
 楼主| 发表于 2013-5-31 11:44:51 | 显示全部楼层
RE:A9四核开发板启动异常
Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 4fa5004a  DAC: 00000015
Process mdev (pid: 1346, stack limit = 0xba1902f0)
Stack: (0xba191dc8 to 0xba192000)
1dc0:                   8bf46424 ba191e0c 00000000 ba190000 00000000 800fa444
1de0: ba191eb0 800fb4bc bc068998 80105abc ba238015 00001051 13101ae9 00000005
1e00: ba23800f ba311b40 bc068990 ba311b40 bc068908 bc140730 bc081088 ba191eb0
1e20: 00000041 ba238000 ba190000 ba191f38 ba190000 00000000 00052adc 800fc53c
1e40: ba191e68 80104114 00000000 ba191ef8 8bf46420 8bf46440 00000001 00000000
1e60: 00000001 800fba04 00000000 000c9500 80a75d14 00000001 ba191eb0 ba238000
1e80: ffffff9c ba191f38 ba190000 00000000 00052adc 800fd0ec ba238000 00000001
1ea0: 00000003 ffffff9c ba191f38 800fe1ec ba311b40 bc068990 13101ae9 00000005
1ec0: ba32101a bffc3820 bc017770 bc140730 00000015 00000002 00000000 00000001
1ee0: 00000005 ba321000 ba191f80 80100928 00000000 ba311dc0 bfa38b70 00000000
1f00: 801007e8 8013f718 000018d1 00000000 ba191f50 000c9500 00000003 000000c3
1f20: 800440c4 800fe244 00000000 ba191f48 00000236 800f51e0 bc140730 ba311b40
1f40: ba191f48 7ebbfa00 000c9500 800f53e0 ba311dc0 bc140754 801007e8 801009c4
1f60: 000000a8 00000000 00008000 ba311dc0 800440c4 ba190000 00000000 80100b1c
1f80: 000bd238 000bd218 00007f58 ffffffea 00000000 000bd178 000bd17c 000bd190
1fa0: 00000001 80043f40 00000001 000c9500 000c9500 7ebbfa00 7ebbfa00 000c9500
1fc0: 00000001 000c9500 00000003 000000c3 00000003 00051f30 000ac008 00052adc
1fe0: 000a9600 7ebbf9e4 0008841c 2ac72518 200f0010 000c9500 4fffc811 4fffcc11
[] (_raw_spin_unlock+0x8/0x3c) from [] (rt_mutex_slowlock+0xe0/0x138)
[] (rt_mutex_slowlock+0xe0/0x138) from [] (0xba191f38)
Code: e49de004 eaee5cf0 f57ff05f e3a03000 (e5803000)
---[ end trace a0675042bee55886 ]---
[FAIL]
 楼主| 发表于 2013-5-31 11:46:11 | 显示全部楼层
RE:A9四核开发板启动异常
Unable to handle kernel NULL pointer dereference at virtual address 000001b4
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 80004000
[00000000] *pgd=00000000
Internal error: Oops: 80000007 [#2] PREEMPT SMP
Modules linked in:
CPU: 0    Tainted: G      D      (3.0.35-ts-armv7l #1)
PC is at 0x0
LR is at __slab_free+0x7c/0x1e0
pc : []    lr : []    psr: 60000093
sp : ba28fea8  ip : 00000000  fp : 00000118
r10: ba28e000  r9 : ba28e000  r8 : 800bdacc
r7 : bfeab360  r6 : 80000093  r5 : bff59e00  r4 : 8bffd560
r3 : 00000001  r2 : 400000c1  r1 : 8bffd560  r0 : 00000000
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 4a0d804a  DAC: 00000015
Process mmcqd/0 (pid: 1260, stack limit = 0xba28e2f0)
Stack: (0xba28fea8 to 0xba290000)
fea0:                   80a75cc0 8bffdbc0 ba04de00 00000000 80a75cc0 00000000
fec0: 0bfcc000 800ebd30 ba23b000 800bdacc 00000000 ba1b6bc0 bfeab360 ba04de00
fee0: 00020000 ba23b400 00000000 ba23b53c ba28ff44 800bdacc bfeab360 02224420
ff00: ba04de00 8021ea90 00000000 00000000 bfeab360 00000000 ba23b000 8021edd8
ff20: bfeab360 ba23b40c ba23b638 803772c0 ba23bc00 00000000 00000000 80070e28
ff40: 00100100 00000000 bffc77b8 ba23b000 ba23b40c ba23b400 ba23b400 00000000
ff60: 00000000 ba23b414 bfeab360 803774ec ba28e000 00000001 bfeab360 ba23b40c
ff80: ba04de00 00000000 ba28e000 00000001 00000000 ba23b414 bfeab360 803782a4
ffa0: 00000000 bffa3da0 ba23b40c 80378248 00000013 00000000 00000000 00000000
ffc0: 00000000 8008e904 80044a24 00000000 ba23b40c 00000000 00000000 00000000
ffe0: ba28ffe0 ba28ffe0 bffa3da0 8008e884 80044a24 80044a24 00000000 00000000
[] (__slab_free+0x7c/0x1e0) from [] (kmem_cache_free+0xf0/0xfc)
[] (kmem_cache_free+0xf0/0xfc) from [] (mempool_free+0x5c/0x8c)
[] (mempool_free+0x5c/0x8c) from [] (__blk_put_request+0x6c/0xc4)
[] (__blk_put_request+0x6c/0xc4) from [] (__blk_end_request+0x30/0x38)
[] (__blk_end_request+0x30/0x38) from [] (mmc_blk_issue_rw_rq+0x220/0x2d8)
[] (mmc_blk_issue_rw_rq+0x220/0x2d8) from [] (mmc_blk_issue_rq+0x174/0x314)
[] (mmc_blk_issue_rq+0x174/0x314) from [] (mmc_queue_thread+0x5c/0x100)
[] (mmc_queue_thread+0x5c/0x100) from [] (kthread+0x80/0x88)
Code: bad PC value
---[ end trace 00251a93b9992a4f ]---
note: mmcqd/0[1260] exited with preempt_count 2
pgd = ba260000
[000001b4] *pgd=4fb8c831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#3] PREEMPT SMP
Modules linked in:
CPU: 2    Tainted: G      D      (3.0.35-ts-armv7l #1)
PC is at ext3_iget+0x7c/0x404
LR is at __wait_on_bit+0xb0/0xb8
pc : []    lr : []    psr: 60000013
sp : bfbdddb8  ip : 00000000  fp : 00000001
r10: 00000001  r9 : bffc3780  r8 : 00000000
r7 : bc0730c0  r6 : bfde8a00  r5 : 8c331600  r4 : bc0bea88
r3 : 00000000  r2 : 0000a1ff  r1 : 00000000  r0 : 00000000
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 4a26004a  DAC: 00000015
Process S03-modules (pid: 1550, stack limit = 0xbfbdc2f0)
Stack: (0xbfbdddb8 to 0xbfbde000)
dda0:                                                       00000000 bc0730c0
ddc0: 00000600 00000019 bc0bb220 000318b7 bc0dc6f0 bc054770 00000000 8014d410
dde0: bc0dc6f0 8c3b10a0 bc0dc6f0 bc0bb220 bfbddeb0 800fa630 bfbdde58 bfbddeb0
de00: bfbdde6c 800fad0c bc0dc714 bfbddeb8 bfdea860 bc0dc6f0 00000000 bfbddeb0
de20: 00000051 ba1cd000 bfbdc000 bfbddf38 bfbdc000 00000000 bfbdde58 800fc60c
de40: bfbdde68 ba1e8160 ba260ab0 00000000 bfdea85c bfbddeb8 bffc3780 bc0bb198
de60: 00000022 800fba04 00000000 bc0dc6f0 80a75d14 00000001 bfbddeb0 ba1cd000
de80: ffffff9c bfbddf38 bfbdc000 00000000 ffffffff 800fd0ec ba1cd000 00000001
dea0: 00000001 ffffff9c bfbddf38 800fe1ec bffc3780 bc054770 0193b520 00000004
dec0: ba1cd009 bffc3780 bc017b28 bc0dc6f0 00000001 00000002 00000000 00000000
dee0: bfbdc000 00000000 000ace34 00000007 80a793f0 2ac3a504 bfbddfb0 00000001
df00: 000ace64 00000000 ffffffff 8003e420 bfbddf50 000acdcc 00000001 000000c3
df20: 800440c4 800fe244 00000000 bff0bd28 80a75d14 800f51e0 bfab4a80 bfab4a88
df40: 0000000a 7eb7f080 000acdcc 800f53e0 bfab4a80 800ef6b8 bffc36e0 bfab4a80
df60: bff0bd20 bfab4a80 00000000 bff0bd20 800440c4 bfbdc000 00000000 800ef590
df80: 00000003 bfab4a80 bfab4ac0 800ef64c 00000010 000ac374 00000002 0000040f
dfa0: 7eb7f140 80043f40 7eb7f140 000acdcc 000ace64 7eb7f080 7eb7f080 000ace64
dfc0: 7eb7f140 000acdcc 00000001 000000c3 00000001 000ace64 00000002 ffffffff
dfe0: 000a9600 7eb7f064 00048f98 2ac3a518 00000010 000ace64 00000000 00000000
[] (ext3_iget+0x7c/0x404) from [] (ext3_lookup+0x88/0xf0)
[] (ext3_lookup+0x88/0xf0) from [] (d_alloc_and_lookup+0x44/0x64)
[] (d_alloc_and_lookup+0x44/0x64) from [] (do_lookup+0x284/0x2f8)
[] (do_lookup+0x284/0x2f8) from [] (path_lookupat+0x124/0x698)
[] (path_lookupat+0x124/0x698) from [] (do_path_lookup+0x1c/0x5c)
[] (do_path_lookup+0x1c/0x5c) from [] (user_path_at_empty+0x50/0x94)
[] (user_path_at_empty+0x50/0x94) from [] (user_path_at+0x14/0x1c)
[] (user_path_at+0x14/0x1c) from [] (vfs_fstatat+0x3c/0x6c)
[] (vfs_fstatat+0x3c/0x6c) from [] (sys_stat64+0x14/0x30)
[] (sys_stat64+0x14/0x30) from [] (ret_fast_syscall+0x0/0x30)
Code: e1d510b2 e5841004 e1d531b8 e5843008 (e59c01b4)
---[ end trace 00251a93b9992a50 ]---
Segmentation fault
 楼主| 发表于 2013-5-31 11:47:47 | 显示全部楼层
RE:A9四核开发板启动异常
pgd = 80004000
Internal error: Oops: 80000007 [#1] PREEMPT SMP
Modules linked in:
CPU: 0    Not tainted  (3.0.35-ts-armv7l #1)
PC is at 0x0
LR is at __schedule+0x70/0x6c0
sp : bfc1bee4  ip : 8003cf40  fp : 00000001
r10: 00000000  r9 : bfc1a000  r8 : bfc1a000
r7 : 8c008f40  r6 : bfabd800  r5 : 800ebd30  r4 : 0bfcc000
r3 : 00000000  r2 : bfc1bec0  r1 : 60000013  r0 : 00000000
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 4a16004a  DAC: 00000015
Process mmcqd/0 (pid: 1261, stack limit = 0xbfc1a2f0)
Stack: (0xbfc1bee4 to 0xbfc1c000)
bee0:          bfabdc14 bfc1bf9c 804e106c bfb0e580 00000001 bfb0e584 8021e4b8
bf00: bfb0e580 00000000 00000000 8021e55c 00000000 00000000 8003cf40 8003cf40
bf20: 8003c1b4 8003cf40 60000013 00000000 00000001 00000003 00000000 00000001
bf40: bfc1bf6c 800685a8 00000000 bfabd800 bfabdc0c bfabd800 bfabdc0c bfabdc00
bf60: bfabdc00 bfb0e580 bfb0e580 00000000 bfc1a000 00000001 00000000 bfabdc0c
bf80: bfb0e580 00000000 bfc1a000 00000001 00000000 bfabdc14 00000000 80378324
bfa0: 00000000 bffa3da0 bfabdc0c 80378248 00000013 00000000 00000000 00000000
bfc0: 00000000 8008e904 80044a24 00000000 bfabdc0c 00000000 00000000 00000000
bfe0: bfc1bfe0 bfc1bfe0 bffa3da0 8008e884 80044a24 80044a24 00000000 00000000
Code: bad PC value
---[ end trace b2b91d6b2c953887 ]---
note: mmcqd/0[1261] exited with preempt_count 1
 楼主| 发表于 2013-5-31 11:48:33 | 显示全部楼层
RE:A9四核开发板启动异常
Creating device files: Unable to handle kernel paging request at virtual address 7ffebc40
Unable to handle kernel paging request at virtual address 00004010
pgd = 80004000
[00004010] *pgd=00000000
Internal error: Oops: 817 [#1] PREEMPT SMP
Modules linked in:
CPU: 1    Not tainted  (3.0.35-ts-armv7l #1)
PC is at _clk_arm_set_rate+0x144/0x330
LR is at _clk_arm_set_rate+0x11c/0x330
pc : []    lr : []    psr: 80000093
sp : bfa63ed0  ip : 00000080  fp : 80a7cdf4
r10: f40cadfc  r9 : 60000013  r8 : 3b5dc100
r7 : 00000001  r6 : 80a7adfc  r5 : 00018d00  r4 : 3b5dc100
r3 : 00004000  r2 : 00004000  r1 : 00000000  r0 : 80ac2ff8
Control: 10c53c7d  Table: 4fa8c04a  DAC: 00000015
Process kinteractiveup (pid: 1331, stack limit = 0xbfa622f0)
Stack: (0xbfa63ed0 to 0xbfa64000)
3ec0:                                     800585f8 80a7d020 3b5dc100 001312d0
3ee0: 80ac3470 001312d0 00000000 179a7b00 804e56b0 80062f70 ffffffff 3b5dc100
3f00: 001312d0 80065b40 bf9ff240 00000004 ffffffff 80a75ac4 00000004 000f32a0
3f20: 3b5dc100 80065e54 bfa63f5c 0099b4f9 bfa63f58 8c020568 00000003 00000003
3f40: 00060ae0 000f32a0 8c020501 21010bb5 bfa63f78 80079730 00000006 00000000
3f60: 8c020dd0 80a75abc 80a75abc 80a75b00 bfa62000 80a75cc0 804e56ac 80ae1578
3f80: 000f32a0 80365bb0 00000000 8036a55c 8c008d90 8003cd90 8003cd90 00000000
3fa0: bfa63fc4 bff8bf30 00000000 8036a3f4 00000013 00000000 00000000 00000000
3fc0: 00000000 8008e904 80044a24 00000000 00000000 00000000 00000000 00000000
3fe0: bfa63fe0 bfa63fe0 bff8bf30 8008e884 80044a24 80044a24 00000000 00000000
[] (_clk_arm_set_rate+0x144/0x330) from [] (clk_set_rate+0x40/0x60)
Code: e34f240c e2471001 e1a03002 e5807000 (e5821010)
---[ end trace 3553466c9378d737 ]---
pgd = 80004000
[7ffebc40] *pgd=4fffc811, *pte=00000000, *ppte=00000000
Modules linked in:
CPU: 3    Tainted: G      D      (3.0.35-ts-armv7l #1)
PC is at 0x7ffebc40
 楼主| 发表于 2013-5-31 11:49:28 | 显示全部楼层
RE:A9四核开发板启动异常
Creating device files: Internal error: Oops - undefined instruction: 0 [#1] PREEMPT SMP
Unable to handle kernel paging request at virtual address 5f697860
pgd = 80004000
[5f697860] *pgd=00000000
Modules linked in:
CPU: 3    Not tainted  (3.0.35-ts-armv7l #1)
PC is at 0xbfd370e8
LR is at do_DataAbort+0x34/0x9c
pc : []    lr : []    psr: 200f0113
sp : ba0b1f10  ip : 80a79100  fp : 7eaa783c
r10: 00000000  r9 : ba0b1fb1  r8 : 00000000
r7 : ba0b1fb0  r6 : 00000000  r5 : 80a79170  r4 : 00000017
r3 : bfd370e0  r2 : ba0b1fb0  r1 : 00000017  r0 : 00000000
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
Control: 10c53c7d  Table: 4fe7804a  DAC: 00000015
Process mdev (pid: 1346, stack limit = 0xba0b02f0)
Stack: (0xba0b1f10 to 0xba0b2000)
1f00:                                     bffc1000 8bffa420 bffc1000 8013e53c
1f20: 40000000 bffc1000 bfd28840 bfa33ed0 00000000 bc01f550 bc147590 80104114
1f40: 00000002 ba2ef780 bc147590 bc01f550 00000000 800f2b40 00000020 00000000
[FAIL]1f60: ba2ef780 bffd2ee0 00000000 ba2ef780 bffd2ee0 00000000 ba2ef780 800ef590
1f80: 00000006 bffd2ee0 bffd2f20 800ef64c 00000000 00000006 00000005 0000040f
1fa0: 00000007 00000108 00000001 80043ec4 2ac914c8 000c5218 00000040 00000000
1fc0: 000c5218 2ac914c8 00000108 00000001 00000000 00000005 00000000 7eaa783c
1fe0: 2ac9102c 7eaa75d0 2abb3628 2abd46b8 600f0010 ffffffff 00000000 00000000
[] (do_DataAbort+0x34/0x9c) from [] (ret_from_exception+0x0/0x10)
Exception stack(0xba0b1fb0 to 0xba0b1ff8)
1fa0:                                     2ac914c8 000c5218 00000040 00000000
Code: 00000000 00000000 bfa23720 80a79170 (ff8c0000)
Internal error: Oops: 80000005 [#2] PREEMPT SMP
Modules linked in:
CPU: 1    Tainted: G      D      (3.0.35-ts-armv7l #1)
---[ end trace b1dd40e2f4ed2f29 ]---
PC is at 0x5f697860
LR is at clk_get_rate+0x40/0x50
pc : []    lr : []    psr: 200000b3
sp : bfa53e60  ip : 00000000  fp : 804e56b0
r10: bfa53f3c  r9 : 80a75cc0  r8 : 804e56ac
r7 : 60000013  r6 : 800491b0  r5 : 00000001  r4 : 80ac2d10
r3 : 5f697861  r2 : 00000000  r1 : 20000013  r0 : 80a7c020
Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment kernel
Control: 10c53c7d  Table: 4a28004a  DAC: 00000015
Process kinteractiveup (pid: 1331, stack limit = 0xbfa522f0)
Stack: (0xbfa53e60 to 0xbfa54000)
3e60: 80056854 80056860 80056854 80062e70 00000001 800491c4 bfa52000 800a2954
3e80: 8003edf8 bff09c00 80002001 00000000 00000000 00000000 00000000 00000000
3ea0: ba117040 ffffffff 80aad550 00000000 bfa53f3c 00000001 bfa53f3c 80049328
3ec0: 800492e0 80093b74 80ae14d4 80ae14bc 00000000 00000001 ffffffff 80093cc8
3ee0: 00000000 001312d0 00000000 bfa53f3c bf9ff240 00000001 80a75ac4 00000004
3f00: 80a75b00 80093cfc 00000000 00000004 ffffffff 803663f4 00000002 8c020000
3f20: bfa53f3c 80065ef4 bfa53f5c 363e5274 00000000 00000004 00000003 00000001
3f40: 00060ae0 000f32a0 8c020501 1accc0db bfa53f78 80079730 00000006 00000000
3f60: 8c020dd0 80a75abc 80a75abc 80a75b00 bfa52000 80a75cc0 804e56ac 80ae1578
3fa0: bfa53fc4 bff8bf30 00000000 8036a3f4 00000013 00000000 00000000 00000000
3fe0: bfa53fe0 bfa53fe0 bff8bf30 8008e884 80044a24 80044a24 00000000 00000000
[] (clk_get_rate+0x40/0x50) from [] (_clk_twd_get_rate+0xc/0x14)
[] (_clk_twd_get_rate+0xc/0x14) from [] (clk_get_rate+0x40/0x50)
[] (clk_get_rate+0x40/0x50) from [] (twd_update_frequency+0x14/0x48)
[] (twd_update_frequency+0x14/0x48) from [] (smp_call_function_single+0x194/0x1d0)
[] (smp_call_function_single+0x194/0x1d0) from [] (twd_cpufreq_transition+0x48/0x58)
[] (twd_cpufreq_transition+0x48/0x58) from [] (notifier_call_chain+0x44/0x84)
[] (notifier_call_chain+0x44/0x84) from [] (__srcu_notifier_call_chain+0x44/0x60)
[] (__srcu_notifier_call_chain+0x44/0x60) from [] (srcu_notifier_call_chain+0x18/0x20)
[] (srcu_notifier_call_chain+0x18/0x20) from [] (cpufreq_notify_transition+0xa0/0xe0)
[] (cpufreq_notify_transition+0xa0/0xe0) from [] (mxc_set_target+0x194/0x220)
[] (mxc_set_target+0x194/0x220) from [] (__cpufreq_driver_target+0x50/0x64)
Code: bad PC value
---[ end trace b1dd40e2f4ed2f2a ]---
ov5642_read_reg:write reg error:reg=300a
ov5642_probe:cannot find camera
modprobe: module tsc2004 not found in modules.dep
modprobe: module egalax_ts not found in modules.dep
Setting timezone and system clock: [OK]
Starting system logging.
Configuring network interfaces: done
Finding touchscreen using legacy method:[FAIL]
Finding mouse:[FAIL]
Framebuffer fb0
Resolution 1024 768
Screen resolution: 1024 x 768
XGA display
Search for input device eGalax Touch Screen
Mouse device is Auto
cat: can't open '/etc/ts.dev': No such file or directory
Starting demo...
Starting demo...
BusyBox v1.20.2 (2013-01-17 06:57:51 EST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
GMT+8, 2025-12-1 16:08 , Processed in 0.109028 second(s), 30 queries , Redis On.
