查看: 2627|回复: 2
[求助] [求助]PDB模块不会使用
    发表于 2013-6-19 13:47:55 | 显示全部楼层 |阅读模式
    谁能提供一个完整的使用PDB模块设计的微秒级延时代码?非常感谢!
    我知道答案 目前已有1人回答
    发表于 2013-6-19 22:44:24 | 显示全部楼层
    回复:[求助]PDB模块不会使用
    在飞思卡尔官方例程代码中有关于PDB触发ADC采样的的例程代码,其中关于PDB的初始化代码如下,你可以参照修改。
    void pdb_init(void)
    int i;
    //use ptd10 11 to indicate program status
    //enable ptd10 11 as rgpio funciton
    PORTD_PCR11  = PORT_PCR_MUX(1)|PORT_PCR_DSE_MASK;
    PORTD_PCR10  = PORT_PCR_MUX(1)|PORT_PCR_DSE_MASK;
    //enable ptd10 11 as output
    GPIOD_PDDR  |= 0xC00;
    //output 0
    GPIOD_PDOR =0;
      //-------------------------pdb setup---------------------------------
    //1.Set to software trigger input
    //2.Enable pdb module
    //3.Prescale set to 0
    //4. LDMOD = 0: load immediately after setting LDOK
    //5. enable PDB sequence error interrupt
    //Only enable pdb module then you can write in all channel delay value
    PDB0_SC = 0x00000000;
    // NOTE: PDB must be enabled before writting to buffered registers
    // otherwise, it will be always previous value.
    //Enable PDB
    PDB0_SC |= PDB_SC_PDBEN_MASK;
    PDB0_SC |= PDB_SC_TRGSEL(0xF);
      //Enable continuous mode
    PDB0_SC |= PDB_SC_CONT_MASK;
    //Enable pre-trigger out to ADC0/1
    PDB0_CH0C1 = PDB_C1_TOS(3)|PDB_C1_EN(3);
    PDB0_CH1C1 = PDB_C1_TOS(3)|PDB_C1_EN(3);
    //Set CH0 DLY0/1
    PDB0_CH0DLY0 = 0;
    PDB0_CH0DLY1 = 3648;    // delay the conversion time = 76us
    //Set CH1 DLY0/1
    PDB0_CH1DLY0 = 0;
    PDB0_CH1DLY1 = 3648;    // delay the conversion time = 76us
    //Set PDB_MOD to 156us corresponding to sampling frequency Fs=6.4KHz
    PDB0_MOD = 7488;
    //Set interrupt delay value
    PDB0_IDLY = 7488;
    //Load delay value
    PDB0_SC |= PDB_SC_LDOK_MASK;
    //Enable interrupt
    PDB0_SC |= PDB_SC_PDBIE_MASK;
    PDB0_SC |= PDB_SC_PDBEIE_MASK;
    //Set software trigger
    PDB0_SC |= PDB_SC_SWTRIG_MASK;
     楼主| 发表于 2013-6-25 11:00:33 | 显示全部楼层
    RE:[求助]PDB模块不会使用
    谢谢版主!!!!!!!!!
    GMT+8, 2026-4-15 23:29 , Processed in 0.074128 second(s), 24 queries , Redis On.
