查看: 2551|回复: 1
[已解决] PWM 不能正常工作(已解决)
发表于 2013-7-23 17:07:55 | 显示全部楼层 |阅读模式
LDD_TDeviceData* PWM1_Init(LDD_TUserData *UserDataPtr)
  /* Allocate device structure */
  PWM1_TDeviceData *DeviceDataPrv;
  /* {MQXLite RTOS Adapter} Driver memory allocation: Dynamic allocation is simulated by a pointer to the static object */
  DeviceDataPrv = &DeviceDataPrv__DEFAULT_RTOS_ALLOC;
  DeviceDataPrv->UserDataPtr = UserDataPtr; /* Store the RTOS device structure */
  DeviceDataPrv->EnUser = TRUE;        /* Set the flag "device enabled" */
  DeviceDataPrv->RatioStore = 0x01U;   /* Ratio after initialization */
  DeviceDataPrv->LinkedDeviceDataPtr = TU1_Init((LDD_TUserData *)NULL);
  if (DeviceDataPrv->LinkedDeviceDataPtr == NULL) { /* Is initialization of TimerUnit unsuccessful? */
    /* Deallocation of the device structure */
    /* {MQXLite RTOS Adapter} Driver memory deallocation: Dynamic allocation is simulated, no deallocation code is generated */
    return NULL;                       /* If so, then the PWM initialization is also unsuccessful */
  /* Registration of the device structure */
  PE_LDD_RegisterDeviceStructure(PE_LDD_COMPONENT_PWM1_ID,DeviceDataPrv);
  return ((LDD_TDeviceData *)DeviceDataPrv); /* Return pointer to the device data structure */
这个参数传什么呢?我传的是NULL;但是没现象
各位大神看哪里有问题,下面附件是我的工程
我知道答案 目前已有0人回答
Interface.rar
3.24 MB, 下载次数: 5, 下载积分: 威望 1
 楼主| 发表于 2013-7-26 14:27:41 | 显示全部楼层
回复:PWM 不能正常工作(正解)
我自己回复吧!这个问题我已经解决了。传NULL是可以的。感觉专家软件是挺简单的,但是可控性很差得自己去修改。
GMT+8, 2025-9-17 04:53 , Processed in 0.102008 second(s), 23 queries , MemCache On.
