查看: 3018|回复: 3
[求助] 请教K10进入休眠问题
发表于 2013-8-7 14:59:09 | 显示全部楼层 |阅读模式
 我的代码如下,初始化时我分别调用以下两个初始化函数:
MC_Init();
LLWU_Init();    //设定PTA4/LLWU_P3 作为唤醒输入
然后工作中我调用了下面这个函数,能进入休眠:
enter_vlls1();
但我通过按键将PTA4脚拉低时,无法唤醒芯片,请问我的程序哪里有问题呢?
正常工作时PTA4脚能够触发IO中断,所以GPIO中断设置应该没问题。
void MC_Init(void)
        /*Enable all operation modes because this is a write once register*/
    SMC-&gtMPROT =  SMC_PMPROT_AVLLS_MASK |
                                  SMC_PMPROT_ALLS_MASK   |
                                  SMC_PMPROT_AVLP_MASK;
void LLWU_Init(void)
        uint8 temp;
        NVIC_EnableIRQ(LLW_IRQn);                  /*        开启LLW中断                                                */
        /* 设定PTA4/LLWU_P3作为唤醒输入,下降沿唤醒,关闭内部模块唤醒功能           */
        temp = LLWU-&gtE1;
        temp |= LLWU_PE1_WUPE3(2);
        LLWU->F1 |= LLWU_F1_WUF3_MASK;   // write one to clear the flag
    LLWU-&gtE1 = temp;
    LLWU->ME = 0;  //Set up modules to wakeup up
        SIM->SCGC5|=SIM_SCGC5_PORTA_MASK;
        NVIC_EnableIRQ(PORTA_IRQn);                //开启PORTA中断
        PORTA-&gtCR[4]&=~(PORT_PCR_MUX_MASK);
        PORTA-&gtCR[4]|=PORT_PCR_MUX(ALT1)|   //配置PORT口的MUX位为GPIO模式
                                 PORT_PCR_PS_MASK         |
                                 PORT_PCR_PE_MASK  |
                                 PORT_PCR_PFE_MASK |
                                 PORT_PCR_IRQC(10) ;        //外部中断触发设置
void PORTA_IRQHandler(void)                //PORTA中断程序
    PORTA->ISFR|=PORT_ISFR_ISF_MASK;                   //清除标志位
 __asm void waitforint()
    WFI
void enter_vlls1(void)
        MCG->C6 &= ~MCG_C6_CME0_MASK;                //External clock monitor is disabled.
        /* Write to PMPROT to allow all possible power modes */
    /* Set the VLLSM field to 0b100 for VLLS1 mode - Need to retain state of LPWUI bit 8 */
    SMC-&gtMCTRL = (SMC-&gtMCTRL & SMC_PMCTRL_RUNM_MASK ) |
                  SMC_PMCTRL_STOPM(0x4) ; // retain LPWUI
    SMC->VLLSCTRL =  SMC_VLLSCTRL_VLLSM(1);           // set VLLSM = 0b01
    /* Now execute the stop instruction to go into VLLS1 */
    waitforint();
我知道答案 目前已有2人回答
    发表于 2013-8-14 17:33:03 | 显示全部楼层
    RE:请教K10进入休眠问题
    To avoid unwanted transitions on the pins, software must reinitialize the I/O pins to their pre-low-power mode entry states before releasing the hold.
    In Stop mode, the PORT can be configured to exit the Low-Power mode via an asynchronous wakeup signal if an enabled interrupt is detected.
    通过上面2个说明在进入STOP模式之前,要先将IO配置为低功耗模式。
     楼主| 发表于 2013-8-16 10:55:06 | 显示全部楼层
    RE:请教K10进入休眠问题
    请问是要将所有模块的IO都配置成低功耗模式吗?
    发表于 2013-8-16 17:11:23 | 显示全部楼层
    RE:请教K10进入休眠问题
    楼主有试过使用中断从正常停止模式唤醒吗?
    GMT+8, 2025-10-12 23:39 , Processed in 0.086211 second(s), 23 queries , MemCache On.
