查看: 3580|回复: 4
[已解决] 哪个函数才是TPM中断?(已解决)
发表于 2013-8-20 09:42:32 | 显示全部楼层 |阅读模式
/* The Interrupt Vector Table */
void (* const InterruptVector[])() __attribute__ ((section(".vectortable"))) = {
    /* Processor exceptions */
    (void(*)(void)) &_estack,
    __thumb_startup,
    NMI_Handler,
    HardFault_Handler,
    0,
    0,
    0,
    0,
    0,
    0,
    0,
    SVC_Handler,
    0,
    0,
    PendSV_Handler,
    SysTick_Handler,
    /* Interrupts */
    DMA0_IRQHandler, /* DMA Channel 0 Transfer Complete and Error */
    DMA1_IRQHandler, /* DMA Channel 1 Transfer Complete and Error */
    DMA2_IRQHandler, /* DMA Channel 2 Transfer Complete and Error */
    DMA3_IRQHandler, /* DMA Channel 3 Transfer Complete and Error */
    MCM_IRQHandler, /* Normal Interrupt */
    FTFL_IRQHandler, /* FTFL Interrupt */
    PMC_IRQHandler, /* PMC Interrupt */
    LLW_IRQHandler, /* Low Leakage Wake-up */
    I2C0_IRQHandler, /* I2C0 interrupt */
    I2C1_IRQHandler, /* I2C1 interrupt */
    SPI0_IRQHandler, /* SPI0 Interrupt */
    SPI1_IRQHandler, /* SPI1 Interrupt */
    UART0_IRQHandler, /* UART0 Status and Error interrupt */
    UART1_IRQHandler, /* UART1 Status and Error interrupt */
    UART2_IRQHandler, /* UART2 Status and Error interrupt */
    ADC0_IRQHandler, /* ADC0 interrupt */
    CMP0_IRQHandler, /* CMP0 interrupt */
    FTM0_IRQHandler, /* FTM0 fault, overflow and channels interrupt */
    FTM1_IRQHandler, /* FTM1 fault, overflow and channels interrupt */
    FTM2_IRQHandler, /* FTM2 fault, overflow and channels interrupt */
    RTC_Alarm_IRQHandler, /* RTC Alarm interrupt */
    RTC_Seconds_IRQHandler, /* RTC Seconds interrupt */
    PIT_IRQHandler, /* PIT timer all channels interrupt */
    Default_Handler, /* Reserved interrupt 39/23 */
    USBOTG_IRQHandler, /* USB interrupt */
    DAC0_IRQHandler, /* DAC0 interrupt */
    TSI0_IRQHandler, /* TSI0 Interrupt */
    MCG_IRQHandler, /* MCG Interrupt */
    LPTimer_IRQHandler, /* LPTimer interrupt */
    Default_Handler, /* Reserved interrupt 45/29 */
    PORTA_IRQHandler, /* Port A interrupt */
    PORTD_IRQHandler /* Port D interrupt */
这是codewarrior生成的kl05的中断向量表,其中哪个函数才是TPM的中断函数?
发表于 2013-8-20 10:53:29 | 显示全部楼层
回复:哪个函数才是TPM中断?
TPM是定时器的一种统称,建议多看看RM。
 楼主| 发表于 2013-8-20 11:27:10 | 显示全部楼层
回复:哪个函数才是TPM中断?
回复第 2 楼 于2013-08-20 10:53:29发表:
不对吧,TPM只不过是定时器其中的一种,在KL05中有很多定时器的,如RTC,LPTMR,PIT,TPM,watchdog.
 楼主| 发表于 2013-8-20 11:32:30 | 显示全部楼层
回复:哪个函数才是TPM中断?
找到了,是
发表于 2013-8-20 17:37:27 | 显示全部楼层
RE:哪个函数才是TPM中断?(已解决)
找到就好,感谢你对飞思卡尔产品的关注。
GMT+8, 2025-10-12 23:37 , Processed in 0.094105 second(s), 25 queries , MemCache On.
