查看: 2384|回复: 1
新手求助,S08SH32使用外部晶振,频率不对
发表于 2013-8-20 22:20:39 | 显示全部楼层 |阅读模式
S08SH32,外接3.6864M晶振,程序如下
void init()
    // Clock
    // ICSC2 should be written before ICSC1
    // because it contains an option for choosing an oscillator or external crystal
    // by setting/clearing the EREFS bit respectively
    ICSC2=0b01111111;
    ICSC1=0b10000000;
    // waiting for crystal initial
    while(ICSSC_IREFST!=0);
    while(ICSSC_CLKST!=0b10);
    while(ICSSC_OSCINIT!=1);
    // SYS
    SOPT1=0b11000011;    // WDT=1.024 s, Stop Mode Disabled, SDA=PTA2, BKGD=PTA4, RST=PTA5
    SOPT2=0b00000001;    // COP=1Khz, Normal COP, TPM1CH0=PTC0
    SPMSC1=0b0100001;    // Disable LVD, Bandgap Enable
    SPMSC2=0;            // no use
    // IRQ
    IRQSC=0;            // disabled
    // Interrupt
    // IO
    PTADD=0x0C;
    PTAD=0xFF;
    PTAPE=0xF3;
    PTASE=0xFF;
    PTADS=0xFF;
    PTASC=0;
    PTAPS=0;
    PTAES=0;
    PTBDD=0x0E;
    PTBD=0xFF;
    PTBPE=0xF1;
    PTBSE=0xFF;
    PTBDS=0xFF;
    PTBSC=0;
    PTBPS=0;
    PTBES=0;
    PTCDD=0x01;
    PTCD=0xFF;
    PTCPE=0x82;
    PTCSE=0xFF;
    PTCDS=0xFF;
    GNGC=0;
    // MTIM
    MTIMMOD=0;
    MTIMCLK=0x08;
    MTIMSC=0x60;
void main(void) {
    DisableInterrupts;
    __RESET_WATCHDOG();    /* feeds the dog */
    init();
    EnableInterrupts;
    for(;;) {
    } /* loop forever */
interrupt VectorNumber_Vmtim void ISR_of_systick(void)
    static char c=0;
        char j=MTIMSC;
        MTIMSC_TOF=0;
        if(c)
            c=0;
            LED_HB=0;
        else
            c=1;
            LED_HB=1;
3.6864M晶振,1/2 BUS,MTIM 256分频自由运行,每次中端改变口线状态。
每次中断应该是35.55mS。
但是抓波形,时间是71.11mS。
不知道是哪里设置的不对,请高手指点下
 楼主| 发表于 2013-8-20 23:59:30 | 显示全部楼层
RE:新手求助,S08SH32使用外部晶振,频率不对
搞明白了
bus是cpu时钟1/2,我有多加了一个2分频,所以时间不对
GMT+8, 2026-4-12 02:30 , Processed in 0.078661 second(s), 21 queries , Redis On.
