查看: 11833|回复: 2
[求助] i.mx6+adv7441a问题
发表于 2013-8-23 18:27:34 | 显示全部楼层 |阅读模式
 我在i.mx6Q上IPU2上的CSI1接ADV7441A,使用16位CSI总线,行同步,场同步,像素时钟,DE信号,
出现如下错误信息:
and run ./mxc_v4l2_tvin.out -ow 100 -oh 100
get below result:
start time = 33 s, 476123 us
ERROR:  v4l2 capture: mxc mxc_v4l_dqueue timeout enc_counter 0
VIDIOC_DQBUF failed.
adv7441a 1-0021: adv7441a:ioctl_s_power.
相关代码如下:
   1.
static iomux_v3_cfg_t mx6q_sabresd_csi1_sensor_pads[]  = {
    /* IPU2 tvin  */
     MX6Q_PAD_EIM_DA0__IPU2_CSI1_D_9,
     MX6Q_PAD_EIM_DA1__IPU2_CSI1_D_8,
     MX6Q_PAD_EIM_DA2__IPU2_CSI1_D_7,
     MX6Q_PAD_EIM_DA3__IPU2_CSI1_D_6,
     MX6Q_PAD_EIM_DA4__IPU2_CSI1_D_5,
     MX6Q_PAD_EIM_DA5__IPU2_CSI1_D_4,
     MX6Q_PAD_EIM_DA6__IPU2_CSI1_D_3,
     MX6Q_PAD_EIM_DA7__IPU2_CSI1_D_2,
     MX6Q_PAD_EIM_DA8__IPU2_CSI1_D_1,
     MX6Q_PAD_EIM_DA9__IPU2_CSI1_D_0,
     MX6Q_PAD_EIM_EB2__IPU2_CSI1_D_19,
     MX6Q_PAD_EIM_D16__IPU2_CSI1_D_18,
     MX6Q_PAD_EIM_D18__IPU2_CSI1_D_17,
     MX6Q_PAD_EIM_D19__IPU2_CSI1_D_16,
     MX6Q_PAD_EIM_D20__IPU2_CSI1_D_15,
     MX6Q_PAD_EIM_D26__IPU2_CSI1_D_14,
     MX6Q_PAD_EIM_D27__IPU2_CSI1_D_13,
     MX6Q_PAD_EIM_D28__IPU2_CSI1_D_12,
     MX6Q_PAD_EIM_D21__IPU2_CSI1_D_11,
     MX6Q_PAD_EIM_D22__IPU2_CSI1_D_10,
     MX6Q_PAD_EIM_D23__IPU2_CSI1_DATA_EN,
     MX6Q_PAD_EIM_D17__IPU2_CSI1_PIXCLK,
    MX6Q_PAD_EIM_EB3__IPU2_CSI1_HSYNC,
    MX6Q_PAD_EIM_D29__IPU2_CSI1_VSYNC,
    MX6Q_PAD_EIM_D30__GPIO_3_30,            /* adc int  */
     MX6Q_PAD_EIM_D31__GPIO_3_31,            /* tvin reset , low  */
2.
static struct fsl_mxc_capture_platform_data  capture_data[] = {
        .csi = 1,
        .ipu = 1,
        .mclk_source = 0,
        .is_mipi = 0,
         .csi = 0,
        .ipu =  0,
        .mclk_source =  0,
        .is_mipi =  0,
3.
static void mx6q_csi1_io_init(void)
     mxc_iomux_v3_setup_multiple_pads(mx6q_sabresd_csi1_sensor_pads,
         ARRAY_SIZE(mx6q_sabresd_csi1_sensor_pads));
    /* tvin reset */
    gpio_request(SABRESD_TVIN_REST,  "tvin-rest");
     gpio_direction_output(SABRESD_TVIN_REST, 1);
    gpio_direction_output(SABRESD_TVIN_REST,  0);
    msleep(10);
    /* For  MX6Q:
     * GPR1 bit19 and bit20  meaning:
     * Bit19:       0 -  Enable mipi to IPU1 CSI0
      *                      virtual channel is fixed to 0
     *              1 - Enable parallel interface to  IPU1 CSI0
     * Bit20:       0 -  Enable mipi to IPU2 CSI1
      *                      virtual channel is fixed to 3
     *              1 - Enable parallel interface to  IPU2 CSI1
     * IPU1 CSI1 directly  connect to mipi csi2,
     *       virtual channel is fixed to 1
     *  IPU2 CSI0 directly connect to mipi csi2,
     *      virtual channel is fixed to  2
     * For MX6DL:
     * GPR13 bit 0-2 IPU_CSI0_MUX
     *   000 MIPI_CSI0
     *   100 IPU CSI0
     if (cpu_is_mx6q())
         mxc_iomux_set_gpr_register(1, 20, 1, 1);
    else if (cpu_is_mx6dl())
        mxc_iomux_set_gpr_register(13, 0, 3,  4);
我需要如何设置i.mx6里面CSI相关的寄存器,
比如说CSI0 Sensor Configuration Register(IPUx_CSI0_SENS_CONF)
里面有YUV422 (YUYV...)还是YUV422 (UYVY...)?
            BT.1120 DDR还是BT.1120 SDP?progressive还是interlaced mode?
            Pixel clock input是pixel clock is directly applied to internal circuitry还是pixel clock is inverted before applied to internal circuitry
           等等。
ADV7441A输出波形如下,我需要如何设置i.mx6
时钟与数据
时钟与DE
时钟与场同步
时钟与行同步
我知道答案 目前已有2人回答
发表于 2014-2-11 09:43:19 | 显示全部楼层
RE:i.mx6+adv7441a问题
我也是差不多的问题,我的是VGA->ADV7181C,现在也是同样的问题提示
发表于 2014-12-9 17:20:06 | 显示全部楼层
我遇到的问题是ov5640的摄像头通过并口的方式连接在IPU2 的csi1接口上面,通过测试程序把camera的数据显示到LCD中,但是lcd一直是花屏,不知道你有没有遇到过。
GMT+8, 2026-4-2 01:05 , Processed in 0.097634 second(s), 26 queries , Redis On.
