查看: 2298|回复: 2
[已解决] P&E工具使用(已解决)
发表于 2013-9-2 13:04:55 | 显示全部楼层 |阅读模式
 This is accomplished by P&E's ICD (In-Circuit Debugger) software on the host PC by generating the following reset
sequence:
1. Reset is driven low (to processor).
2. Shifting activity appears on TCLK, TDI and TDO. (PC software instructs the processor to enable debug
mode).
3. Reset is released by Multilink and will go high.
4. Shifting activity appears on TCLK, TDI and TDO. (Debug activity).
Note that if the device does not enter debug mode, the ICD debugger issues the error message “Cannot enter
background mode.” If you receive this message, you should first refer to the troubleshooting section of this
document. You should then check your hardware with a scope, logic analyzer or logic probe.
First check for power on,
then check to make sure the processor oscillator is running.
Finally, look for the startup sequence given above.---》上面的流程可以用示波器检测对应外部引脚看到结果?这些流程不是P&E工具ICD软件自动完成的么,可以步进检测么?怎么理解这句?
我知道答案 目前已有1人回答
发表于 2013-9-2 15:18:44 | 显示全部楼层
回复:P&E工具使用(正解)
这些流程是P&E ICD工具自动完成的,一般情况下客户是不用关心ICD 工具是如何使芯片进入debug模式的。
如果出现不能进入debug模式的问题,客户可以参考上述步骤来检查是否是电路问题。
 楼主| 发表于 2013-9-2 17:04:38 | 显示全部楼层
回复:P&E工具使用
回复第 2 楼 于2013-09-02 15:18:44发表:
弄了半天,那句然来是废话啊,谢谢您的回答,纠结。。。
GMT+8, 2025-10-12 23:08 , Processed in 0.083523 second(s), 22 queries , MemCache On.
