查看: 2948|回复: 2
[分享] KL25 AD转换结果不对
发表于 2013-9-12 20:51:24 | 显示全部楼层 |阅读模式
 使用KL25 内部的AD模块,但转换出来的结果总是不对,乱七八糟的值,求指教!
void ADC0_InitCfg(void)
  SIM_SCGC6 |=  SIM_SCGC6_ADC0_MASK;
  ADC0_CFG1 = ADC_CFG1_ADIV(3)
            | ADC_CFG1_ADLSMP_MASK
            | ADC_CFG1_MODE(3)
            | ADC_CFG1_ADICLK(0);
  ADC0_CFG2 = ADC_CFG2_ADHSC_MASK
            | ADC_CFG2_ADLSTS(0);
  ADC0_SC3 = ADC_SC3_AVGE_MASK
           | ADC_SC3_AVGS(0)
           | ADC_SC3_ADCO_MASK;
  ADC0_SC1A = ADC_SC1_ADCH(31) & (~ADC_SC1_AIEN_MASK);
  ADC0_SC1B = ADC_SC1_ADCH(31) & (~ADC_SC1_AIEN_MASK);
unsigned char ADC0_Calibration(void)
  unsigned short cal_var;
  ADC0_SC2 &=  ~ADC_SC2_ADTRG_MASK ;                            // Enable Software Conversion Trigger for Calibration Process    - ADC0_SC2 = ADC0_SC2 | ADC_SC2_ADTRGW(0);
  ADC0_SC3 &= ( ~ADC_SC3_ADCO_MASK & ~ADC_SC3_AVGS_MASK );      // set single conversion, clear avgs bitfield for next writing
  ADC0_SC3 |= ( ADC_SC3_AVGE_MASK | ADC_SC3_AVGS(3) );    // Turn averaging ON and set at max value ( 32 )
  ADC0_SC3 = ADC_SC3_CAL_MASK ;                                // Start CAL
  while ( !(ADC0_SC1A & ADC_SC1_COCO_MASK ) );                  // Wait calibration end
  if ((ADC0_SC3 & ADC_SC3_CALF_MASK) == ADC_SC3_CALF_MASK )
   return 1;                                                   // Check for Calibration fail error and return
  // Calculate plus-side calibration
  cal_var = 0x00;
  cal_var =  ADC0_CLP0;
  cal_var += ADC0_CLP1;
  cal_var += ADC0_CLP2;
  cal_var += ADC0_CLP3;
  cal_var += ADC0_CLP4;
  cal_var += ADC0_CLPS;
  cal_var = cal_var/2;
  cal_var |= 0x8000;                                            // Set MSB
  ADC0_PG = ADC_PG_PG(cal_var);
  // Calculate minus-side calibration
  cal_var = 0x00;
  cal_var =  ADC0_CLM0;
  cal_var += ADC0_CLM1;
  cal_var += ADC0_CLM2;
  cal_var += ADC0_CLM3;
  cal_var += ADC0_CLM4;
  cal_var += ADC0_CLMS;
  ADC0_MG = ADC_MG_MG(cal_var);
  ADC0_SC3 &= ~ADC_SC3_CAL_MASK ; /* Clear CAL bit */
  return 0;
int main(void)
  float result;
  unsigned char i;
  unsigned char m,n;
  ADC0_InitCfg();
  ADC0_Calibration();
  ADC0_InitCfg();
  ADC0_SC1A = ADC_SC1_ADCH(8) | ADC_SC1_AIEN_MASK;
  //ADC0_SC1B = ADC_SC1_ADCH(8) | ADC_SC1_AIEN_MASK;
  PITDelay_ms(1);
  while(1)
    if( (ADC0_SC1A & ADC_SC1_COCO_MASK) )
      result = ADC0_RA;
      result = ((result * 33) / 655360) * 100;
      m = (unsigned int)(result) / 100;
      n = (unsigned int)(result) % 100;
      printf("%d.%dV \n",m,n);
    for(i=0;i
发表于 2013-9-13 12:07:22 | 显示全部楼层
RE:KL25 AD转换结果不对
你可以参考一下TWR-KL25Z板子的电路图。除了软件的问题还有硬件电路的原因。
软件你可以参考KL25例程:
http://cache.freescale.com/files/32bit/software/KL25_SC.exe
 楼主| 发表于 2013-9-13 15:00:58 | 显示全部楼层
回复:KL25 AD转换结果不对
回复第 2 楼 于2013-09-13 12:07:22发表:
软件你可以参考KL25例程:
我是使用B0口作为AD输入的,再加上一个可调节电源,有什么问题吗?
GMT+8, 2025-10-12 17:49 , Processed in 0.080392 second(s), 20 queries , MemCache On.
