查看: 2307|回复: 7
[已解决] 关于创建任务的问题?(已解决)
发表于 2013-9-24 11:26:38 | 显示全部楼层 |阅读模式
如下例程,我创建了hello_task为MQX_TIME_SLICE_TASK,时间片为10
hello_task任务中count是不是每隔10ms就自动加1呀???
如果我理解的对的话,那例程怎么不执行呀????
const TASK_TEMPLATE_STRUCT  MQX_template_list[] =
   /* Task Index,   Function,    Stack,  Priority,  Name,        Attributes,          Param, Time Slice */
    { SERVER_TASK,  server_task, 1000,   8,         "server",    MQX_AUTO_START_TASK, 0,     0 },
    { CLIENT_TASK,  client_task, 1000,   8,         "client",    0,                   0,     0 },
    { HELLO_TASK,    hello_task, 1000,   8,         "client",    MQX_TIME_SLICE_TASK, 0,     10 },
    { 0 }
uint_32  count = 0;
void  hello_task
        uint_32 param
    count++;
if(count>10){
   count = 0;
    _task_block();
void server_task
      uint_32 param
   SERVER_MESSAGE_PTR msg_ptr;
   _mqx_uint          i;
   _queue_id          server_qid;
   boolean            result;
   _task_id           task_id;
    uint_32           time;
   _mqx_uint highest_priority;
   /* open a message queue */
   server_qid = _msgq_open(SERVER_QUEUE, 0);
   if (server_qid == 0) {
      printf("\nCould not open the server message queue\n");
      _task_block();
   /* create a message pool */
   message_pool = _msgpool_create(sizeof(SERVER_MESSAGE),
      NUM_CLIENTS, 0, 0);
   if (message_pool == MSGPOOL_NULL_POOL_ID) {
      printf("\nCount not create a message pool\n");
      _task_block();
   /* create the client tasks */
   for (i = 0; i < NUM_CLIENTS; i++) {
      task_id = _task_create(0, CLIENT_TASK, (uint_32)i);
      if (task_id == 0) {
         printf("\nCould not create a client task\n");
         _task_block();
    task_id = _task_create(0, HELLO_TASK, 0);
   if (task_id == 0) {
       _task_block();
   while (TRUE) {
      msg_ptr = _msgq_receive(server_qid, 0);
      if (msg_ptr == NULL) {
         printf("\nCould not receive a message\n");
         _task_block();
      printf(" %c \n", msg_ptr->DATA[0]);
      /* return the message */
      msg_ptr->HEADER.TARGET_QID = msg_ptr->HEADER.SOURCE_QID;
      msg_ptr->HEADER.SOURCE_QID = server_qid;
      result = _msgq_send(msg_ptr);
      if (result != TRUE) {
         printf("\nCould not send a message\n");
         _task_block();
void client_task
      uint_32 index
   _queue_id          client_qid;
   boolean            result;
   client_qid  = _msgq_open((_queue_number)(CLIENT_QUEUE_BASE +
      index), 0);
   if (client_qid == 0) {
      printf("\nCould not open a client message queue\n");
      _task_block();
   while (TRUE) {
      /*allocate a message*/
      msg_ptr = (SERVER_MESSAGE_PTR)_msg_alloc(message_pool);
         printf("\nCould not allocate a message\n");
         _task_block();
      msg_ptr->HEADER.SOURCE_QID = client_qid;
      msg_ptr->HEADER.TARGET_QID = _msgq_get_id(0, SERVER_QUEUE);
      msg_ptr->HEADER.SIZE = sizeof(MESSAGE_HEADER_STRUCT) +
         strlen((char_ptr)msg_ptr->DATA) + 1;
      msg_ptr->DATA[0] = ('A'+ index);
      printf("Client Task %ld\n", index);
         _task_block();
      /* wait for a return message */
      msg_ptr = _msgq_receive(client_qid, 0);
         _task_block();
       /* free the message */
      _msg_free(msg_ptr);
我知道答案 目前已有6人回答
发表于 2013-9-24 11:43:54 | 显示全部楼层
回复:关于创建任务的问题?
你创建的是round robin的任务, 需要在user_config.h  中添加 #define MQX_HAS_TIME_SLICE 1 , 并且重新编译BSP 与PSP
 楼主| 发表于 2013-9-24 12:02:53 | 显示全部楼层
回复:关于创建任务的问题?
我已经设置了,是否还要设置默认时间片值吗?如何设置 ?感谢大侠 ·!!!
发表于 2013-9-24 12:27:46 | 显示全部楼层
RE:关于创建任务的问题?
你需要使用连续的优先级, 8,9,10 等等
发表于 2013-9-24 12:31:02 | 显示全部楼层
RE:关于创建任务的问题?(正解)
优先级必须大于7, 最小为8,且需要连续
发表于 2013-9-24 12:48:48 | 显示全部楼层
RE:关于创建任务的问题?
还有, 你创建任务是用  MQX_AUTO_START_TASK | MQX_TIME_SLICE_TASK, 让OS 启动后自动执行这个任务
 楼主| 发表于 2013-9-24 13:18:28 | 显示全部楼层
回复:关于创建任务的问题?
这些我都做了,如何得到时间片的默认值呢?感谢!
发表于 2013-9-24 13:46:48 | 显示全部楼层
RE:关于创建任务的问题?
你创建任务时可以设置time slice,  默认值请参考mqx_cnfg.h
GMT+8, 2025-10-12 17:22 , Processed in 0.108585 second(s), 28 queries , MemCache On.
