查看: 6597|回复: 1
[其他] bootloader of AN2295SW_Rev1\an2295sw\src\MCF52259
发表于 2013-9-26 16:15:18 | 显示全部楼层 |阅读模式
 你好!
我想为MCF52259建立一个BOOTLOADER,用FREESCALEAN2295SW_Rev1\an2295sw\src\MCF52259文件,用CW10.2工具,我不知道怎样做可使BOOTLOADER 启动用CW10.2建立的MQX应用程序,试着做了以下工作,但没成功,请大虾指导:
1,把建立好的BOOTLOADER文件.S19用工具写人52259内部FLASH,再试度用AN2295SW_Rev1\an2295sw\masters\release\win_hc08sprg.exeMQX的应用程序写人52259,
https://www.nxpic.org.cn/file:///C:/Users/chen-ky/AppData/Local/Temp/msohtml1/01/clip_image002.jpg
但只要用Erase就清空了52259中的BOOTLOADER,没法写APP了。
2,我想把BOOTLOADER APP合在一起,用工具AN2295SW_Rev1\an2295sw\masters\release\win_blsrconv.exe,可是不能合并,
https://www.nxpic.org.cn/file:///C:/Users/chen-ky/AppData/Local/Temp/msohtml1/01/clip_image004.jpg
LCF文件为:
KEEP_SECTION {.vectortable}
# Memory ranges
MEMORY {
   vectorrom    (RX)  : ORIGIN = 0x00000000, LENGTH = 0x00000400
   cfmprotrom  (RX)  : ORIGIN = 0x00000400, LENGTH = 0x00000020
   code           (RX)  : ORIGIN = 0x0007c000, LENGTH = 0x00003FFF
   vectorram    (RWX) : ORIGIN = 0x20000000, LENGTH = 0x00000400
   userram       (RWX) : ORIGIN = 0x20000400, LENGTH = 0x00005C00
SECTIONS {
# Heap and Stack sizes definition
   ___heap_size   = 0x1000;
   ___stack_size     = 0x1000;
# MCF52259 Derivative Memory map definitions from linker command files:
# __IPSBAR, __RAMBAR, __RAMBAR_SIZE, __FLASHBAR, __FLASHBAR_SIZE linker
# symbols must be defined in the linker command file.
# Memory Mapped Registers (IPSBAR= 0x40000000)
   ___IPSBAR         = 0x40000000;
# 32 Kbytes Internal SRAM
   ___RAMBAR         = 0x20000000;
   ___RAMBAR_SIZE    = 0x0000FFFF;
# 512 KByte Internal Flash Memory
   ___FLASHBAR       = 0x00000000;
   ___FLASHBAR_SIZE  = 0x00080000;
   ___SP_AFTER_RESET = ___RAMBAR + ___RAMBAR_SIZE - 4;
  .userram   : {} > userram
  .code     : {} > code
  .vectorram : {} > vectorram
   .vectors :
      exceptions_c.obj(.vectortable)
      . = ALIGN (0x4);
   } > vectorrom
   .cfmprotect :
      *(.cfmconfig)
      . = ALIGN (0x4);
   } > cfmprotrom
   .text :
      *(.text)
      . = ALIGN (0x4);
      *(.rodata)
      . = ALIGN (0x4);
      ___ROM_AT = .;
      ___DATA_ROM = .;
   } >> code
   .data : AT(___ROM_AT)
      ___DATA_RAM = .;
      . = ALIGN(0x4);
      *(.exception
      . = ALIGN(0x4);
      __exception_table_start__ = .;
      EXCEPTION
      __exception_table_end__ = .;
      ___sinit__ = .;
       STATICINIT
      __START_DATA = .;
      *(.data)
      . = ALIGN (0x4);
      __END_DATA = .;
      __START_SDATA = .;
      *(.sdata)
      . = ALIGN (0x4);
      __END_SDATA = .;
      ___DATA_END = .;
      __SDA_BASE = .;
      . = ALIGN (0x4);
   } >> userram
   .bss :
      ___BSS_START = .;
      __START_SBSS = .;
      *(.sbss)
      . = ALIGN (0x4);
      *(SCOMMON)
      __END_SBSS = .;
      __START_BSS = .;
      *(.bss)
      . = ALIGN (0x4);
      *(COMMON)
      __END_BSS = .;
      ___BSS_END = .;
      . = ALIGN(0x4);
   } >> userram
   .custom :
      ___HEAP_START  = .;
      ___heap_addr = ___HEAP_START;
      ___HEAP_END     = ___HEAP_START + ___heap_size;
      ___SP_END    = ___HEAP_END;
      ___SP_INIT    = ___SP_END + ___stack_size
      . = ALIGN (0x4);
   } >> userram
   ___VECTOR_RAM     = ADDR(.vectorram);
   __SP_INIT    = ___SP_INIT
   _romp_at = ___ROM_AT + SIZEOF(.data);
   .romp : AT(_romp_at)
      __S_romp = _romp_at;
      WRITEW(___ROM_AT);
      WRITEW(ADDR(.data));
      WRITEW(SIZEOF(.data));
      WRITEW(0);
      WRITEW(0);
      WRITEW(0);
请求邦助,谢谢!
我知道答案 目前已有0人回答
发表于 2013-9-26 16:37:24 | 显示全部楼层
回复:bootloader of AN2295SW_Rev1\an2295sw\src\MCF52259
您好,你这个问题问的非常专业,所以我们建议您写邮件到support@freescale.com。那里有很多coldfire的专家能够给你提供技术支持。
GMT+8, 2025-10-28 13:42 , Processed in 0.087530 second(s), 22 queries , MemCache On.
