查看: 2946|回复: 1
WRITEW 命令怎么用--DSC 连接命令(已解决)
    发表于 2013-10-4 15:32:55 | 显示全部楼层 |阅读模式
    我在连接命令文件里先用 WRITEW 0x00000000;
    但是在elf文件的相应地址上,看不到数据,
    大家知道怎么用这个命令吗?
    我想用这个命令在程序空间中写一定数量的常量到flash
    发表于 2013-10-10 16:58:19 | 显示全部楼层
    RE:WRITEW 命令怎么用--DSC 连接命令(正解)
    1)此命令只能写Flash
    2)WRITEW 命令必须写入link command 文件中
    Writing Data Directly to Memory
    You can write data directly to memory using the WRITEx command in the linker
    command file. The WRITEB command writes a byte, the WRITEH command writes two
    bytes, and the WRITEW command writes four bytes. You insert the data at the section’s
    current address.
    this is an example I copied in flash_smd.cmd
    MEMORY {
    .pIntvectorBoot(RWX): ORIGIN = 0x00000000, LENGTH = 0x000000F0 # Reset and cop vectors
    .pFlashConfig (RWX): ORIGIN = 0x00000200, LENGTH = 0x00000008 # Reserved for Flash IFR value
    .ppFlash (RWX): ORIGIN = 0x00000208, LENGTH = 0x0001F1F5 # Primary flash for user code
    .DelayT (RWX): ORIGIN = 0x0001F3FD, LENGTH = 0x00000003 # Bootloading delay time & user code start position
    .pFlash (RWX): ORIGIN = 0x0001F400, LENGTH = 0x00000C00 # Primary flash for bootloader, 3Kwords
    .xRAM_bss (RW) : ORIGIN = 0x00000000, LENGTH = 0x00000800 # 2Kwords for bss
    .xRAM_data (RWX): ORIGIN = 0x00000800, LENGTH = 0x00000200 # 0.5Kwords for global variables
    .xRAM (RW) : ORIGIN = 0x00000A00, LENGTH = 0x00001600 # 5.5Kwords for heaps and stacks
    .pRAM_code (RWX): ORIGIN = 0x00062000, LENGTH = 0x00002000 # 8Kwords for code
    .xRAM_code (RW) : ORIGIN = 0x00002000, LENGTH = 0x00002000 # mirror of .pRAM_code
    .FlashConfig :
    WRITEH(0xFFFF); # 0, back door key
    WRITEH(0xFFFF); # 1, back door key
    WRITEH(0xFFFF); # 2, back door key
    WRITEH(0xFFFF); # 3, back door key
    WRITEH(0xFFFF); # 4, p-flash protection bits
    WRITEH(0xFFFF); # 5, p-flash protection bits
    # WRITEH(0xFFFF); # 6, opt register and security byte
    WRITEH(0xFFBE); # 6, opt register and security byte
    WRITEH(0xFFFF); # 7, eeprom and d-flash protection bits
    } > .pFlashConfig
    GMT+8, 2026-4-2 03:48 , Processed in 0.090665 second(s), 21 queries , Redis On.
