查看: 20995|回复: 19
[求助] MK60DN512ZVLL10 芯片下载问题,搞了好几天了,求助啊
发表于 2013-10-7 19:31:59 | 显示全部楼层 |阅读模式
求大神,求飞思卡尔技术支持
买了10块的K60芯片,现在焊了7块,只有一块能用,其他的都废了,出现了这样的问题,网上找了几天了也没找到解决方法,请各位帮忙看看啦。
开发环境:IAR6.5
下载器:J-LINK和JTAG
芯片是我自己手焊的,焊过之后下载,直接就不能使用,下载出现的情况如下:
首先用JTAG下载器,点击下载,出现如下的界面
下面的LOG是:
Mon Oct 07, 2013 19:26:14: Loaded macro file: D:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Xxxx128K.mac
Mon Oct 07, 2013 19:26:14: Windows NT detected.
Mon Oct 07, 2013 19:26:16: P&E Interface detected - Flash Version 31.21
Mon Oct 07, 2013 19:26:18: Device is KINETIS.
Mon Oct 07, 2013 19:26:18: Mode is In-Circuit Debug.
Mon Oct 07, 2013 19:26:20: CPU reset by debugger.
Mon Oct 07, 2013 19:26:20: Software reset was performed
Mon Oct 07, 2013 19:26:20: ----- Prepare hardware for Flashloader -----
Mon Oct 07, 2013 19:26:20: 1536 bytes downloaded and verified (2.18 Kbytes/sec)
Mon Oct 07, 2013 19:26:20: Warning: Target inconsistency detected in Memory range 0x1FFF0002-0x1FFF0537
Mon Oct 07, 2013 19:26:35: Fatal error: There were warnings during download of FLASH loader, see Log Window   Session aborted!
Mon Oct 07, 2013 19:26:35: Failed to load flash loader: D:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Dxxx128K.out
Mon Oct 07, 2013 19:26:35: Failed to load flash loader: D:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Dxxx128K.flash
然后使用J-LINK下载,点击下载,出现的情况如下:
LOG如下:
Mon Oct 07, 2013 19:30:07: Loaded macro file: D:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Xxxx128K.mac
Mon Oct 07, 2013 19:30:08: JLINK command: ProjectFile = C:\Documents and Settings\Administrator\桌面\test1-hello_world\settings\hello word_Debug.jlink, return = 0
Mon Oct 07, 2013 19:30:08: Device "MK60DN512XXX10" selected (512 KB flash, 128 KB RAM).
Mon Oct 07, 2013 19:30:08: DLL version: V4.58a, compiled Dec  5 2012 18:38:08
Mon Oct 07, 2013 19:30:08: Firmware: J-Link ARM V8 compiled Nov 14 2012 22:34:52
Mon Oct 07, 2013 19:30:08: JTAG speed is initially set to: 32 kHz
Mon Oct 07, 2013 19:30:08: TotalIRLen = 4, IRPrint = 0x01
Mon Oct 07, 2013 19:30:08: Found Cortex-M4 r0p1, Little endian.
Mon Oct 07, 2013 19:30:08: TPIU fitted.
Mon Oct 07, 2013 19:30:08: FPUnit: 6 code (BP) slots and 2 literal slots
Mon Oct 07, 2013 19:30:09: Found Cortex-M4 r0p1, Little endian.
Mon Oct 07, 2013 19:30:09: TPIU fitted.
Mon Oct 07, 2013 19:30:09: FPUnit: 6 code (BP) slots and 2 literal slots
Mon Oct 07, 2013 19:30:10: Hardware reset with strategy 0 was performed
Mon Oct 07, 2013 19:30:10: Initial reset was performed
Mon Oct 07, 2013 19:30:10: Found 1 JTAG device, Total IRLen = 4:
Mon Oct 07, 2013 19:30:10:  #0 Id: 0x4BA00477, IRLen:  4, IRPrint: 0x1 CoreSight JTAG-DP
Mon Oct 07, 2013 19:30:10: ----- Prepare hardware for Flashloader -----
Mon Oct 07, 2013 19:30:10: 1536 bytes downloaded and verified (13.76 Kbytes/sec)
Mon Oct 07, 2013 19:30:10: Warning:
Verify error at address 0x1FFF0002, target byte: 0x00, byte in file: 0x01
Verify error at address 0x1FFF0003, target byte: 0x00, byte in file: 0x20
……………………………………中间省略N行
Verify error at address 0x1FFF00FF, target byte: 0x00, byte in file: 0x20
Mon Oct 07, 2013 19:30:10: Warning: Too many verify errors, only the first 200 are displayed
Mon Oct 07, 2013 19:30:14: Fatal error: There were warnings during download of FLASH loader, see Log Window   Session aborted!
Mon Oct 07, 2013 19:30:14: Failed to load flash loader: D:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Dxxx128K.out
Mon Oct 07, 2013 19:30:14: Failed to load flash loader: D:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Dxxx128K.flash
我知道答案 目前已有19人回答
 楼主| 发表于 2013-10-7 19:38:23 | 显示全部楼层
RE:MK60DN512ZVLL10 芯片下载问题,搞了好几天了,求助啊
目前已经能够保证排除的问题:
1、PCB的问题,因为焊了6块,其中一块儿能用,即使是电路有问题,如果我只焊了普通的复位电路,也应该是能用的,但是也不能下载,故排除了PCB的问题;
2、工程选项的设置问题,相同的设置下载其他的芯片没有任何的问题,故工程选项的设置不会有问题;
 楼主| 发表于 2013-10-7 19:51:42 | 显示全部楼层
下面是我采用J-LINK ARM进行调试的结果:
1、点击Target-Connect结果如下:
Application log started
- J-Flash ARM V4.36i (J-Flash compiled Nov 11 2011 09:31:35)
- JLinkARM.dll V4.36i (DLL compiled Nov 11 2011 09:31:01)
Reading flash device list [D:\Program Files\SEGGER\JLinkARM_V436i\ETC\JFlash\Flash.csv] ...
- List of flash devices read successfully (927 Devices)
Reading MCU device list [D:\Program Files\SEGGER\JLinkARM_V436i\ETC\JFlash\MCU.csv] ...
- List of MCU devices read successfully (1040 Devices)
Opening project file [D:\Program Files\SEGGER\JLinkARM_V436i\Samples\JFlash\ProjectFiles\MK60N512.jflash] ...
- Project opened successfully
Connecting ...
- Connecting via USB to J-Link device 0
- J-Link firmware: V1.20 (J-Link ARM V8 compiled Nov 14 2012 22:34:52)
- JTAG speed: 100 kHz (Fixed)
- Initializing CPU core (Init sequence) ...
    - Initialized successfully
- JTAG speed: 4000 kHz (Fixed)
- Connected successfully
之后Check Blank,显示如下的窗口:
(截图贴不上,内容如下:)
RAM check failed @ address 0x1FFFC000.
Write: 0x03020100 07060504
Read: 0x0000000 00000000
(0 bytes of RAM have been checked successfully)
Failed to check blank target.
 楼主| 发表于 2013-10-7 19:53:35 | 显示全部楼层
点击 erase sectors 和 erase chip出现的提示框和check blank 是一样的
 楼主| 发表于 2013-10-7 19:59:35 | 显示全部楼层
使用K60也有一年多了,这次改进了一版PCB,竟然出现了这样的问题,十一都扔这上面了,哪位明天上班看到了帮忙想想办法啊,6块芯片躺尸中,要哭了啊
 楼主| 发表于 2013-10-8 11:46:42 | 显示全部楼层
今天又进行了新的测试,将7块儿芯片中好的一块和另外一块有问题的芯片交换了PCB,结果是好的还是好的,不行的还是有问题的,所以,可以确定就是芯片的问题了,但是这个问题究竟是什么还不是很确定,期待大神求解
发表于 2013-10-8 16:22:48 | 显示全部楼层
用万用表量下复位脚的电压,
小于0.8V 就有可能芯片锁了
焊接温度最好300度
 楼主| 发表于 2013-10-8 18:34:12 | 显示全部楼层
回复:MK60DN512ZVLL10 芯片下载问题,搞了好几天了,求助啊
回复第 8 楼 于2013-10-08 16:22:48发表:
用万用表量下复位脚的电压,
小于0.8V 就有可能芯片锁了
焊接温度最好300度
嗯,测过芯片引脚的,是小于0.8V,焊接的温度因为在300度的情况下焊锡无法融化,因此才采用了其他的烙铁来焊。
但是其中一块,我拆了又焊,还是好的啊。
就是芯片被锁的这种情况怎么解锁啊,找到的几个解锁方法也都实验过了,不行啊
  • 签到天数: 105 天
    发表于 2013-10-8 18:51:33 | 显示全部楼层
    你将复位脚接个上拉再烧试试···
     楼主| 发表于 2013-10-8 19:08:07 | 显示全部楼层
    回复第 10 楼 于2013-10-08 18:51:33发表:
    你将复位脚接个上拉再烧试试···
    额,复位引脚本身就是上拉的啊
    附上我的复位电路
    左边接的是电源。
    GMT+8, 2025-10-24 20:53 , Processed in 0.123414 second(s), 29 queries , MemCache On.
