查看: 4648|回复: 3
[求助] ltib -m config命令不能通过
发表于 2013-10-11 13:52:24 | 显示全部楼层 |阅读模式
imx6在 Installing and Building LTIB步骤输入命令ltib -m config不能通过,有如下LOG错误信息,
 Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
 /opt/freescale/ltib/usr/src/rpm/BUILD/mtd-utils
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
 main::build_host_rpms:1392
  main::host_checks:1447
   main:554
请高手指点,如何才能执行通过,谢谢
我知道答案 目前已有2人回答
 楼主| 发表于 2013-10-18 16:02:32 | 显示全部楼层
RE:ltib -m config命令不能通过
终于把问题解决了
发表于 2013-11-5 13:35:45 | 显示全部楼层
你好,我也遇到了一样的问题,请问你是怎么解决的,谢谢
 楼主| 发表于 2013-11-21 15:03:37 | 显示全部楼层
把需要的包装上去,在重新编译之前手动删掉编译记录,就OK了。
GMT+8, 2025-12-1 21:38 , Processed in 0.084418 second(s), 23 queries , Redis On.
