查看: 5848|回复: 2
[已解决] 关于把全局变量从ROM区拷贝到RAM的问题(已解决)
发表于 2013-10-11 22:14:20 | 显示全部楼层 |阅读模式
我们都知道,全局变量是烧在ROM区的,在芯片启动以后,全局变量是手动从ROM区拷贝到RAM区的,既然全局变量是可以修改值得,那么我们在程序中用到的全局变量应该是拷贝到RAM区中的全局变量,但是烧写的时候是烧在ROM中的,那么程序是怎么定位到RAM区中的(从ROM到RAM的拷贝手动的,程序应该从源地址ROM中取值,而不是RAM中)?
我知道答案 目前已有1人回答
    发表于 2013-10-12 08:59:18 | 显示全部楼层
    RE:关于把全局变量从ROM区拷贝到RAM的问题
    变量只能定义在RAM中,常量可以定义在ROM中,因为ROM中的数据不能改动,除非你用FLASH的擦写命令来进行修改。
    发表于 2013-10-14 14:41:17 | 显示全部楼层
    回复:关于把全局变量从ROM区拷贝到RAM的问题
     不知道你用的是什么编译工具?CodeWarrior还是IAR?飞思卡尔例程中提供了数据从ROM拷贝到RAM的代码。
    void
    common_startup(void)
    #if (defined(CW))
        extern char __START_BSS[];
        extern char __END_BSS[];
        extern uint32 __DATA_ROM[];
        extern uint32 __DATA_RAM[];
        extern char __DATA_END[];
    #endif
        /* Declare a counter we'll use in all of the copy loops */
        uint32 n;
        /* Declare pointers for various data sections. These pointers
         * are initialized using values pulled in from the linker file
        uint8 * data_ram, * data_rom, * data_rom_end;
        uint8 * bss_start, * bss_end;
        /* Addresses for VECTOR_TABLE and VECTOR_RAM come from the linker file */
        extern uint32 __VECTOR_TABLE[];
        extern uint32 __VECTOR_RAM[];
        /* Copy the vector table to RAM */
        if (__VECTOR_RAM != __VECTOR_TABLE)
            for (n = 0; n < 0x410; n++)
                __VECTOR_RAM[n] = __VECTOR_TABLE[n];
        /* Point the VTOR to the new copy of the vector table */
        write_vtor((uint32)__VECTOR_RAM);
        /* Get the addresses for the .data section (initialized data section) */
    #if (defined(CW))
            data_ram = (uint8 *)__DATA_RAM;
       data_rom = (uint8 *)__DATA_ROM;
       data_rom_end  = (uint8 *)__DATA_END; /* This is actually a RAM address in CodeWarrior */
       n = data_rom_end - data_ram;
        #elif (defined(IAR))
    data_ram = __section_begin(".data");
    data_rom = __section_begin(".data_init");
    data_rom_end = __section_end(".data_init");
    n = data_rom_end - data_rom;
    #endif
    /* Copy initialized data from ROM to RAM */
    while (n--)
    *data_ram++ = *data_rom++;
        /* Get the addresses for the .bss section (zero-initialized data) */
    #if (defined(CW))
    bss_start = (uint8 *)__START_BSS;
    bss_end = (uint8 *)__END_BSS;
    bss_start = __section_begin(".bss");
    bss_end = __section_end(".bss");
    #endif
        /* Clear the zero-initialized data section */
        n = bss_end - bss_start;
        while(n--)
          *bss_start++ = 0;
    /* Get addresses for any code sections that need to be copied from ROM to RAM.
    * The IAR tools have a predefined keyword that can be used to mark individual
    * functions for execution from RAM. Add "__ramfunc" before the return type in
    * the function prototype for any routines you need to execute from RAM instead
    * of ROM. ex: __ramfunc void foo(void);
    #if (defined(IAR))
    uint8* code_relocate_ram = __section_begin("CodeRelocateRam");
    uint8* code_relocate = __section_begin("CodeRelocate");
    uint8* code_relocate_end = __section_end("CodeRelocate");
    /* Copy functions from ROM to RAM */
    n = code_relocate_end - code_relocate;
    while (n--)
    *code_relocate_ram++ = *code_relocate++;
    #endif
    GMT+8, 2026-4-15 01:18 , Processed in 0.093692 second(s), 23 queries , Redis On.
