查看: 4162|回复: 3
[求助] 求助,k60烧写是出现问题!!!
发表于 2013-10-27 16:01:17 | 显示全部楼层 |阅读模式
 Error executing task K60DN512Z.
Error:  Couldn't write flash driver to target.  Can not read target memory at location: 0x0000000020000000.Please make sure that the chip selects are properly configured.
The CWPP response code is: ARM GDI Protocol Adapter : An error occurred while trying to write memory. The Debugger can not write m
emory..thread exit: Running, 0x0, 0x0, cpuARMLittle, Unknown (state, tid, pid, cpu, target)
An error occurred while trying to write memory. The Debugger can not write memory.(ARM GDI Protocol Adapter)
Error: Couldn't write flash driver to target.Can not read target memory at location: 0x0000000020000000.
emory..
我知道答案 目前已有2人回答
 楼主| 发表于 2013-10-27 16:04:27 | 显示全部楼层
回复:求助,k60烧写是出现问题!!!
ARM GDI Protocol Adapter : An error occurred while trying to write memory. The Debugger can not write memory.
发表于 2013-10-28 11:24:06 | 显示全部楼层
RE:求助,k60烧写是出现问题!!!
配置错误,0x0000000020000000是RAM,不是flash。
发表于 2013-10-28 13:30:22 | 显示全部楼层
回复:求助,k60烧写是出现问题!!!
回复第 2 楼 于2013-10-27 16:04:27发表:
build coniguration 要选 FLASH, 这样才可以下在到FLASH 里。
GMT+8, 2026-4-22 00:02 , Processed in 0.098268 second(s), 24 queries , Redis On.
