查看: 2510|回复: 2
[其他] FlexBus的CS3无信号
发表于 2013-12-4 10:47:18 | 显示全部楼层 |阅读模式
 大家帮忙看一下,初始化时,有对CS0、CS3进行初始化,但是用示波器查看信号时,对CS0片选地址操作时,示波器有控制信号、数据信号输出,但是对CS3片选地址操作时,无任何信号输出。
void Flexbus_setup()
    #define ALT5                    0x05
    #define OFF_CHIP_ACCESS_ALLOW   3
    PORT_MemMapPtr  pctl;
    SIM_MemMapPtr   sim = SIM_BASE_PTR;
    FB_MemMapPtr    fb_ptr = FB_BASE_PTR;
    /* Enable clock to FlexBus module */
    sim->SCGC7 |= SIM_SCGC7_FLEXBUS_MASK;
    sim->SOPT2 |= SIM_SOPT2_FBSL(OFF_CHIP_ACCESS_ALLOW);
        /* configure chip select multiplexers */
    fb_ptr->CSPMCR=0;
    fb_ptr->CSPMCR=FB_CSPMCR_GROUP5(1)|
                    FB_CSPMCR_GROUP4(1)|
                      FB_CSPMCR_GROUP3(0)|
                        FB_CSPMCR_GROUP2(0)|
                          FB_CSPMCR_GROUP1(1);
    pctl = (PORT_MemMapPtr)PORTD_BASE_PTR;
    pctl-&gtCR[6] = PORT_PCR_MUX(ALT5); /* A0 */
    pctl-&gtCR[5] = PORT_PCR_MUX(ALT5); /* A1 */
    pctl-&gtCR[4] = PORT_PCR_MUX(ALT5); /* A2 */
    pctl-&gtCR[3] = PORT_PCR_MUX(ALT5); /* A3 */
    pctl-&gtCR[2] = PORT_PCR_MUX(ALT5); /* A4 */
    pctl-&gtCR[1] = PORT_PCR_MUX(ALT5); /* FB_CS0_b */
    pctl-&gtCR[0] = PORT_PCR_MUX(ALT5); /* ALE*/
    pctl = (PORT_MemMapPtr)PORTC_BASE_PTR;
    pctl-&gtCR[3] = PORT_PCR_MUX(ALT5);  /* FB_CLKOUT */
    //pctl-&gtCR[7] = PORT_PCR_MUX(ALT5);  /* A8 */
    pctl-&gtCR[8] = PORT_PCR_MUX(ALT5);  /* A7 */
    pctl->PCR[9] = PORT_PCR_MUX(ALT5);  /* A6 */
    pctl->PCR[10] = PORT_PCR_MUX(ALT5); /* A5 */
    pctl->PCR[11] = PORT_PCR_MUX(ALT5); /* nWR*/
    pctl->PCR[12] = PORT_PCR_MUX(ALT5); /* D3 */
    pctl->PCR[13] = PORT_PCR_MUX(ALT5); /* D2 */
    pctl->PCR[14] = PORT_PCR_MUX(ALT5); /* D1 */
    pctl->PCR[15] = PORT_PCR_MUX(ALT5); /* D0 */
    //pctl->PCR[18] = PORT_PCR_MUX(ALT5); /* nCS2 */
    pctl->PCR[19] = PORT_PCR_MUX(ALT5); /* nCS3 */
    pctl = (PORT_MemMapPtr)PORTB_BASE_PTR;
    pctl->PCR[19] = PORT_PCR_MUX(ALT5); /* OE */
    pctl->PCR[20] = PORT_PCR_MUX(ALT5); /* D7 */
    pctl->PCR[21] = PORT_PCR_MUX(ALT5); /* D6 */
    pctl->PCR[22] = PORT_PCR_MUX(ALT5); /* D5 */
    pctl->PCR[23] = PORT_PCR_MUX(ALT5); /* D4 */
void Flexbus_init()
    /* CS0 base address */
    fb_ptr->CS[0].CSAR = (uint_32)&MRAM_START_ADDRESS1;
    /* CS0 control (8bit data, 1 wait state, multiplexed mode) */
    fb_ptr->CS[0].CSCR = FB_CSCR_AA_MASK |
                         FB_CSCR_WS(2)   |
                         FB_CSCR_PS(1)   |
                         FB_CSCR_BEM_MASK;
    /* CS0 address mask and enable */
    fb_ptr->CS[0].CSMR = FB_CSMR_BAM(0x00) | FB_CSMR_V_MASK;
    /* CS3 base address */
    fb_ptr->CS[3].CSAR = (uint_32)&MRAM_START_ADDRESS2;
    /* CS3 control (8bit data, 1 wait state, multiplexed mode) */
    fb_ptr->CS[3].CSCR = FB_CSCR_AA_MASK |
                         FB_CSCR_WS(2)   |
                         FB_CSCR_PS(1)   |
                         FB_CSCR_BEM_MASK;
    /* CS3 address mask and enable */
    fb_ptr->CS[3].CSMR = FB_CSMR_BAM(0x00) | FB_CSMR_V_MASK;
请大家指点一下,不胜感谢。
我知道答案 目前已有1人回答
发表于 2013-12-10 09:57:36 | 显示全部楼层
回复:FlexBus的CS3无信号
都有信号的
// author  : cloud_team
// version : 1.0
// date    : 2013-1-31
// company : weikeng
// http    : www.weikeng.com.cn
#include "mkxx10_flexbus.h"
// * 函数名: flexbus_init
// * 简介: flexbus初始化
// * 参数: fb_cs: FB_CS0,FB_CS1,FB_CS2,FB_CS3,FB_CS4,FB_CS5
// * 参数: fb_bam: SST39VF6401B_BAM
// * 参数: fb_base_addr: SST39VF6401B_BASE_ADDRESS
// * 返回值: 无
// * 作者: cloud team
void flexbus_init(u8 fb_cs,u16 fb_bam,u32 fb_base_addr)
  SIM_MemMapPtr SIM = SIM_BASE_PTR;
  FB_MemMapPtr  FB = FB_BASE_PTR;
  SIM->SOPT2 |= SIM_SOPT2_FBSL(3);
  SIM->SCGC7 |= SIM_SCGC7_FLEXBUS_MASK;
  //fb clock divider 1
  //100MHz/(1+1)==50MHz
  //默认设置为core频率的一半
  //SIM->CLKDIV1 |= SIM_CLKDIV1_OUTDIV3(1);
  SIM->CLKDIV1 |= SIM_CLKDIV1_OUTDIV3(4);
  //at reset,no chip-select other than FB_CS0 can be used until CSMR0[V] is 1b.
  //afterward,the FB_CS[5:0] singles function as programmed.
  FB->CS[0].CSMR = 1;
  //FB_CSMR0 =1;
  //FB_CSCR0 =1;
  //设置基址地址
  FB->CS[fb_cs].CSAR = fb_base_addr;
  //设置基址地址掩码
  FB->CS[fb_cs].CSMR = FB_CSMR_BAM(fb_bam) | FB_CSMR_V_MASK;
  //FB_CSCR1  = FB_CSCR_BLS_MASK
  //          | FB_CSCR_PS(2)
  //          | FB_CSCR_AA_MASK;
  FB->CS[fb_cs].CSCR = FB_CSCR_BLS_MASK | FB_CSCR_PS(2) | FB_CSCR_AA_MASK;
  //FB->CS[fb_cs].CSCR = FB_CSCR_BLS_MASK | FB_CSCR_PS(0) | FB_CSCR_AA_MASK;
void flexbus_set_mode(u8 fb_cs,u16 fb_bls,u32 fb_ps)
  //设置对齐方式
  //设置数据端口大小
  //自动应答使能
  FB->CS[fb_cs].CSCR = fb_bls | FB_CSCR_PS(fb_ps) | FB_CSCR_AA_MASK;
// version : 1.0
// date    : 2013-1-31
#ifndef MKXX10_FLEXBUS_H
#define MKXX10_FLEXBUS_H
#include "mkxx.h"
//片选信号
#define FB_CS0             0
#define FB_CS1             1
#define FB_CS2             2
#define FB_CS3             3
#define FB_CS4             4
#define FB_CS5             5
#define FB_PS_32BIT        0
#define FB_PS_8BIT         1
#define FB_PS_16BIT        2
#define FB_BLS_LEFT        0
#define FB_BLS_RIGHT       FB_CSCR_BLS_MASK
//#define FB_PS_32BIT        3
void flexbus_init(u8 fb_cs,u16 fb_bam,u32 fb_base_addr);
void flexbus_set_mode(u8 fb_cs,u16 fb_bls,u32 fb_ps);
#endif
// version : 1.0
// date    : 2013-1-31
#include "sst39vf6401b.h"
#include "mkxx10_port.h"
#include
void flexbus_sram_init(u8 fb_cs,u16 fb_bam,u32 fb_base_addr)
  //SIM_MemMapPtr SIM = SIM_BASE_PTR;
  //设置基址地址
  //设置基址地址掩码
  //          | FB_CSCR_PS(2)
                     | FB_CSCR_ASET(0x1) | FB_CSCR_WS(0x1)| FB_CSCR_BEM_MASK;
                     //| FB_CSCR_RDAH(1);
// * 函数名: sst39vf6401b_init
// * 简介: 并行flash初始化
// * 参数: 无
// * 返回值: 无
// * 作者: cloud team
void sst39vf6401b_init(void)
  //打开时钟
  port_open_clock(PORTB_CLOCK);
  port_open_clock(PORTC_CLOCK);
  port_open_clock(PORTD_CLOCK);
  port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_6);       //  fb_ad[0]
  port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_5);       //  fb_ad[1]
  port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_4);       //  fb_ad[2]
  port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_3);       //  fb_ad[3]
  port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_2);       //  fb_ad[4]
  //port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_1);       //  fb_ad[0]
  //port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_0);       //  fb_ad[0]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_10);      //  fb_ad[5]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_9);       //  fb_ad[6]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_8);       //  fb_ad[7]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_7);       //  fb_ad[8]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_6);       //  fb_ad[9]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_5);       //  fb_ad[10]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_4);       //  fb_ad[11]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_2);       //  fb_ad[12]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_1);       //  fb_ad[13]
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_0);       //  fb_ad[14]
  port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_18);      //  fb_ad[15]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_17);      //  fb_ad[16]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_16);      //  fb_ad[17]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_11);      //  fb_ad[18]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_10);      //  fb_ad[19]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_9);       //  fb_ad[20]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_8);       //  fb_ad[21]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_7);       //  fb_ad[22]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_6);       //  fb_ad[23]
  //port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_15);      //  fb_ad[24]
  //port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_14);      //  fb_ad[25]
  //port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_13);      //  fb_ad[26]
  //port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_12);      //  fb_ad[27]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_23);      //  fb_ad[28]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_22);      //  fb_ad[29]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_21);      //  fb_ad[30]
  //port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_20);      //  fb_ad[31]
  port_pin_type_flexbus_a(PORTD_BASE_PTR,PORT_PIN_8);      //  fb_a[16]
  port_pin_type_flexbus_a(PORTD_BASE_PTR,PORT_PIN_9);      //  fb_a[17]
  port_pin_type_flexbus_a(PORTD_BASE_PTR,PORT_PIN_10);     //  fb_a[18]
  port_pin_type_flexbus_a(PORTD_BASE_PTR,PORT_PIN_11);     //  fb_a[19]
  port_pin_type_flexbus_a(PORTD_BASE_PTR,PORT_PIN_12);     //  fb_a[20]
  port_pin_type_flexbus_a(PORTD_BASE_PTR,PORT_PIN_13);     //  fb_a[21]
  port_pin_type_flexbus_a(PORTD_BASE_PTR,PORT_PIN_14);     //  fb_a[22]
  //control signals
  port_pin_type_flexbus(PORTB_BASE_PTR,PORT_PIN_19);       // fb_oe_b
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_11);       // fb_rw_b
  port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_1);        // fb_cs0_b
  port_pin_type_flexbus(PORTD_BASE_PTR,PORT_PIN_0);        // fb_ale
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_19);       //fb_cs3_b
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_18);
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_17);       //fb_be31_24
  port_pin_type_flexbus(PORTC_BASE_PTR,PORT_PIN_16);       //fb_be23_16
  flexbus_init(FB_CS0,SST39VF6401B_BAM,SST39VF6401B_BASE_ADDRESS);
  //左对齐,数据宽度为16bit
  //flexbus_set_mode(FB_CS0,FB_BLS_LEFT,FB_PS_16BIT);
  //SRAM
  flexbus_sram_init(FB_CS3,SRAM_BAM,SRAM_BASE_ADDRESS);
  FB_CSPMCR = FB_CSPMCR_GROUP1(0)|FB_CSPMCR_GROUP2(2) | FB_CSPMCR_GROUP3(2)|FB_CSPMCR_GROUP5(1);
//100M的主频:一个时钟周期是10ns
void sst39vf6401b_delay_cycles(unsigned long i)
  while(i--)
    __no_operation();
发表于 2013-12-10 17:40:12 | 显示全部楼层
RE:FlexBus的CS3无信号
学习了!!!
GMT+8, 2025-10-29 19:04 , Processed in 0.110826 second(s), 22 queries , MemCache On.
