查看: 2245|回复: 2
[已解决] 哪位大侠帮忙把下面这段代码变换到gcc的代码?(已解决)
发表于 2013-12-10 15:45:47 | 显示全部楼层 |阅读模式
最近,想将ucos移植到KL15Z64上,于是从网上找到了别的M0芯片的代码。不过这个代码是在KEIL下编译通过的。
直接移到codewarrior10.x下,编译报错,后来发现是二者的编译器不同,其中的伪指令集是不同的,本人对这块不懂,
哪位好心人帮忙转换一下?下面是代码(哪位有移植好的ucos,就更好了):
    EXTERN  OSRunning                                           ; External references
    EXTERN  OSPrioCur
    EXTERN  OSPrioHighRdy
    EXTERN  OSTCBCur
    EXTERN  OSTCBHighRdy
    EXTERN  OSIntNesting
    EXTERN  OSIntExit
    EXTERN  OSTaskSwHook
    EXPORT  OS_CPU_SR_Save                                      ; Functions declared in this file
    EXPORT  OS_CPU_SR_Restore
    EXPORT  OSStartHighRdy
    EXPORT  OSCtxSw
    EXPORT  OSIntCtxSw
    AREA |.text|, CODE, READONLY, ALIGN=2
    THUMB
    REQUIRE8
    PRESERVE8
;保存和恢复中断屏蔽寄存器子函数定义
OS_CPU_SR_Save
        MRS     R0, PRIMASK                 ; Set prio int mask to mask all (except faults)
        CPSID   I
        BX      LR
OS_CPU_SR_Restore
        MSR     PRIMASK, R0
        BX      LR
;启动多任务
OSStartHighRdy
    LDR     R0, __OS_TaskSwHook                                 ; OSTaskSwHook();
    BLX     R0
    LDR     R0, __OS_Running                                    ; OSRunning = TRUE;
    MOVS    R1, #1
    STRB    R1, [R0]
        ; SWITCH TO HIGHEST PRIORITY TASK:
    LDR     R0, __OS_TCBHighRdy                                 ;   Get highest priority task TCB address,
    LDR     R1, [R0]                                            ;   Get stack pointer,
    LDR     R2, [R1]
    MSR     MSP, R2                                             ;   Switch to the new stack,
    POP    {R0-R7}                                              ;   Pop new task's R8-R11 (into R0-R3), R4-R7
    MOV     R8,  R0
    MOV     R9,  R1
    MOV     R10, R2
    MOV     R11, R3
        ; NORMAL FUNCTION RETURN (see Note #2)
    ADD     SP, #0x10
    POP    {R0-R3}                                              ;   Pop new task's R12, PC, LR, PSR into (R0, R1, R2, R3, respectively)
    MOV     R12, R0
    MOV     LR,  R1
    MSR     PSR, R3
    PUSH   {R2}                                                 ;   Save PC
    SUB     SP, #0x1C
    POP    {R0-R3}                                              ;   Pop new task's R0-R3
    ADD     SP, #0x0C
    CPSIE   I                                                   ;   Enable interrupts
    POP    {PC}                                                 ;   Pop new task's PC
;任务级别下的任务切换
OSCtxSw
    CPSID   I
    SUB     SP,#0x10
    PUSH    {R0-R3}
    ADD     SP,#0x20
    MRS     R3, PSR
    MOV        R2, LR
    MOV        R1, LR
    MOV     R0, R12
    PUSH    {R0-R3}
    SUB     SP, #0x10
    MOV     R0, R8
    MOV     R1, R9
    MOV     R2, R10
    MOV     R3, R11
    PUSH    {R0-R7}
    MRS     R0, MSP
    LDR     R1, __OS_TCBCur                                     ; OSTCBCur->OSTCBStkPtr = SP;
    LDR     R1, [R1]
    STR     R0, [R1]
    BLX     R0
    LDR     R0, __OS_PrioCur                                    ; OSPrioCur = OSPrioHighRdy;
    LDR     R1, __OS_PrioHighRdy
    LDRB    R2, [R1]
    STRB    R2, [R0]
    LDR     R0, __OS_TCBCur                                     ; OSTCBCur  = OSTCBHighRdy;
    LDR     R1, __OS_TCBHighRdy
    LDR     R2, [R1]
    STR     R2, [R0]
    LDR     R0, [R2]                                            ; SP = OSTCBHighRdy->OSTCBStkPtr;
    MSR     MSP, R0
        ; RESTORE TASK's CONTEXT
    MOV     R8,  R0
    MOV     R9,  R1
    MOV     R10, R2
    MOV     R11, R3
    ADD     SP, #0x10
    MOV     R12, R0
    MOV     LR,  R1
    MSR     PSR, R3
    PUSH   {R2}                                                 ;   Save PC
    SUB     SP, #0x1C
    ADD     SP, #0x0C
    POP    {PC}
    NOP
;中断级别下的任务切换
OSIntCtxSw
    CPSID   I
    SUB     SP,#0x10
    PUSH    {R0-R3}
    ADD     SP,#0x20
    MRS     R3, PSR
    MOV        R2, LR
    MOV        R1, LR
    MOV     R0, R12
    PUSH    {R0-R3}
    SUB     SP, #0x10
    MOV     R0, R8
    MOV     R1, R9
    MOV     R2, R10
    MOV     R3, R11
    PUSH    {R0-R7}
    MRS     R0, MSP
    LDR     R1, [R1]
    STR     R0, [R1]
    BLX     R0
    LDRB    R2, [R1]
    STRB    R2, [R0]
    LDR     R2, [R1]
    STR     R2, [R0]
    MSR     MSP, R0
    MOV     R8,  R0
    MOV     R9,  R1
    MOV     R10, R2
    MOV     R11, R3
    ADD     SP, #0x10
    MOV     R12, R0
    MOV     LR,  R1
    MSR     PSR, R3
    PUSH   {R2}                                                 ;   Save PC
    SUB     SP, #0x1C
    ADD     SP, #0x0C
    POP    {PC}
    NOP
;全局变量定义
__OS_TaskSwHook
    DCD     OSTaskSwHook
__OS_IntExit
    DCD     OSIntExit
__OS_IntNesting
    DCD     OSIntNesting
__OS_PrioCur
    DCD     OSPrioCur
__OS_PrioHighRdy
    DCD     OSPrioHighRdy
__OS_Running
    DCD     OSRunning
__OS_TCBCur
    DCD     OSTCBCur
__OS_TCBHighRdy
    DCD     OSTCBHighRdy
    END
我知道答案 目前已有1人回答
发表于 2013-12-10 17:31:52 | 显示全部楼层
RE:哪位大侠帮忙把下面这段代码变换到gcc的代码?
这个问题看上去比较复杂!
    发表于 2014-2-7 15:18:05 | 显示全部楼层
    回复:哪位大侠帮忙把下面这段代码变换到gcc的代码?
    楼主你好,这个问题建议你去飞思卡尔官网提交一个技术服务请求。
    [url=https://www.freescale.co
    m/zh-Hans/webapp/servicerequest.create_SR.framework]www.freescale.com/zh-Hans/webapp/servicerequest.create_SR.framework[/url]
    (请使用英文描述一下你的问题,这样国内外工程师都能够帮助到你)
    GMT+8, 2025-10-12 17:20 , Processed in 0.092681 second(s), 23 queries , MemCache On.
