楼主: wcxfairy
[已解决] MKL05Z32VLC4问题求教(已解决)
    无聊
    2018-2-11 10:31
     楼主| 发表于 2013-12-19 13:19:51 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    请问是不是我晶振连接的问题呢?原理图是这样的,麻烦大神帮我看一下啊!实在是搞不出来啊,起码现在用的官方例程都没法进入主函数运行。
    KL05.pdf
    208.14 KB, 下载次数: 22
    发表于 2013-12-19 14:03:39 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    <div style="padding:5px;border:1px dashed #ccc;">回复第 9 楼 于2013-12-19 09:40:37发表:
    我的外部晶振现在接的是8MHz,程序就是用的附件里面的,现在在程序里面对应的CLOCK_SETUP=1;执行
        #elif (CLOCK_SETUP == 1)
        #define CPU_XTAL_CLK_HZ                 8000000u /* Value of the external crystal or oscillator clock frequency in Hz */
        #define CPU_INT_SLOW_CLK_HZ             32768u   /* Value of the slow internal oscillator clock frequency in Hz  */
        #define CPU_INT_FAST_CLK_HZ             4000000u /* Value of the fast internal oscillator clock frequency in Hz  */
        #define DEFAULT_SYSTEM_CLOCK            40000000u /* Default System clock value */
        #define DEFAULT_BUS_CLOCK               20000000u /* Default bus clock value */
        #define DEFAULT_MCGFLLCLK               40000000u /* Default FLL out clock value */
    程序没有进入主函数运行,发现程序一直停留在
      /* SIM_SCGC5: PORTA=1 */
      SIM_SCGC5 |= (uint32_t)0x0200UL;     /* Enable clock gate for ports to enable pin routing */
      /* SIM_CLKDIV1: OUTDIV1=1,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,OUTDIV4=1,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0 */
      SIM_CLKDIV1 = (uint32_t)0x00010000UL; /* Update system prescalers */
      /* PORTA_PCR3: ISF=0,MUX=0 */
      PORTA_PCR(3) &= (uint32_t)~0x01000700UL;
      /* PORTA_PCR4: ISF=0,MUX=0 */
      PORTA_PCR(4) &= (uint32_t)~0x01000700UL;
      /* Switch to FBE Mode */
      /* OSC0_CR: ERCLKEN=1,??=0,EREFSTEN=0,??=0,SC2P=1,SC4P=0,SC8P=0,SC16P=1 */
      OSC0_CR = (uint8_t)0x89U;
      /* MCG_C2: LOCRE0=0,??=0,RANGE0=2,HGO0=0,EREFS0=1,LP=0,IRCS=0 */
      MCG_C2 = (uint8_t)0x24U;
      /* MCG_C1: CLKS=2,FRDIV=3,IREFS=0,IRCLKEN=1,IREFSTEN=0 */
      MCG_C1 = (uint8_t)0x1AU;
      /* MCG_C4: DMX32=0,DRST_DRS=01 */
      MCG_C4 &= (uint8_t)~(uint8_t)0xE0U;
      MCG_C4 |= (1
    无聊
    2018-2-11 10:31
     楼主| 发表于 2013-12-19 14:05:13 | 显示全部楼层
    RE:MKL05Z32VLC4问题求教
    帮帮忙啊,很是麻烦啊!
    发表于 2013-12-19 14:05:19 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    复位电路也可以参考FRDM-KL05Z板子原理图。
    无聊
    2018-2-11 10:31
     楼主| 发表于 2013-12-19 14:17:24 | 显示全部楼层
    RE:MKL05Z32VLC4问题求教
    恩,现在没加复位电路,复位引脚现在是悬空的。就是程序下进去进步了main,用了好几个官网例程,都是          if (MCG_S & MCG_S_OSCINIT0_MASK) break; // jump out early if OSCINIT sets before loop finishes感觉不管哪个例程,都是在这样的地方等着,不知道怎么回事?就是我的电路图的晶振接法不知道对不对。
    发表于 2013-12-19 16:38:59 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    回复第 15 楼 于2013-12-19 14:17:24发表:
    能否测下你的复位引脚电平状态?
    无聊
    2018-2-11 10:31
     楼主| 发表于 2013-12-19 19:01:54 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    回复第 16 楼 于2013-12-19 16:38:59发表:
    能否测下你的复位引脚电平状态?
     恩,是不是和复位引脚有关系啊,我现在这个引脚是悬空的,是不是要接一个高电平啊!还有我的板子都是2.5V供电,接2.5V应该没有问题吧!
    发表于 2013-12-20 09:03:08 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    回复第 17 楼 于2013-12-19 19:01:54发表:
    能否测下你的复位引脚电平状态?
    参考14楼电路,没问题。
    无聊
    2018-2-11 10:31
     楼主| 发表于 2013-12-23 08:34:10 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    恩,我量了rst脚是高电平,但是网上的例程下载进我的板子程序就是停留在外部时钟那里,怎么晶振总是不起振啊!
    无聊
    2018-2-11 10:31
     楼主| 发表于 2013-12-23 08:39:16 | 显示全部楼层
    回复:MKL05Z32VLC4问题求教
    现在我量出来晶振是8MHz,是起振了,但是我的程序还是停留在
    while((MCG_S & 0x0CU) != 0x08U) {    /* Wait until external reference clock is selected as MCG output */
    这个函数的等待中,不知道怎么回事,这个到底是什么情况啊,从一开始执行程序就一直停留在这里,现在我量晶振8MHZ(用的是8MHZ)的是起振了,RST管教是高电平,但是程序一直这样,用的是官方的例程,都停留在这里。
    GMT+8, 2025-9-7 15:09 , Processed in 0.088950 second(s), 30 queries , MemCache On.
