查看: 2526|回复: 1
[其他] 设置中断
发表于 2013-12-25 16:43:22 | 显示全部楼层 |阅读模式
 我想设置两个定时中断,可是中断没有响应 ,大家帮我看一下哈:
void INTC_vInit(void)
  EXCEP_InitExceptionHandlers();        // Exception Interrupt Handler Intilization
  INTC_InitINTCInterrupts();            // Extenal Interrupt Handler Intilization
  INTC.MCR.B.HVEN = 0;                  // Initialize INTC For Software Vector Mode
  INTC.MCR.B.VTES = 0;                  // Use The Default Vector Table Entry OffSets Of 4 Bytes
  INTC.CPR.B.PRI = 0;                   // Low The PRI Field To Allow Other Interrupt To Be Served
  INTC_InstallINTCInterruptHandler(ISR059_vPIT0, 59, 1);
  INTC.CPR.B.PRI = 1;
  INTC_InstallINTCInterruptHandler(ISR059_vPIT1, 59, 2);
int main(void)
  volatile int i = 0;
   closeWatchdog();
   initSystem();
   SIUL_vInit();
   INTC_vInit();
   PIT_vInit();
  /* Loop forever */
  for (;;) {
    i++;
我知道答案 目前已有0人回答
 楼主| 发表于 2013-12-26 15:37:15 | 显示全部楼层
RE:设置中断
这里面太冷清了,我自己回答吧!注意向量表就oK
GMT+8, 2025-10-29 12:13 , Processed in 0.099178 second(s), 22 queries , MemCache On.
