查看: 21480|回复: 19
[已解决] android启动不起来(已解决)
发表于 2014-1-9 15:44:01 | 显示全部楼层 |阅读模式
我使用imx6dl,使用JB4.3.3-1.1.0版本,但在启动的时候最后停在了Freeing init memory: 232K,就没了动静,各位大侠帮忙分析一下吧:
 以下是log:
U-Boot 2009.08 ( 1��月 08 2014 - 15:47:46)
CPU: Freescale i.MX6 family TO1.1 at 792 MHz
Thermal sensor with ratio = 190
Temperature:   39 C, calibration data 0x5b251d69
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-IGSBOARD: unknown-board Board: 0x61011[ POR]
Boot Device: SPI NOR
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1
JEDEC ID: 0xc2:0x20:0x14
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
----enet_board_init: phy reset
FEC0 [PRIME]
Hit any key to stop autoboot:  0
kernel   @ 10808000 (4628336)
ramdisk  @ 11800000 (233540)
kernel cmdline:
        use uboot command line:
        console=ttymxc1,115200 init=/init rw video=mxcfb0:dev=lcd,VGA,if=RGB24 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24 fbmem=10M vmallo
Starting kernel ...
Initializing cgroup subsys cpu
Linux version 3.0.35 (hibernate@ThinkPad-T410) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #6 SMP PREEMPT Wed Jan 8 01:22:48 CST4
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite Igs Board
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6DL/SOLO, silicon rev 1.1
PERCPU: Embedded 7 pages/cpu @c128a000 s6592 r8192 d13888 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 208128
Kernel command line: console=ttymxc1,115200 init=/init rw video=mxcfb0:dev=lcd,VGA,if=RGB24 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24 fbm1
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 767MB 54MB = 821MB total
Memory: 821028k/821028k available, 227548k reserved, 431104K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
    vmalloc : 0xd9800000 - 0xf2000000   ( 392 MB)
    lowmem  : 0xc0000000 - 0xd9000000   ( 400 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0042000   ( 232 kB)
      .text : 0xc0042000 - 0xc0870f84   (8380 kB)
      .data : 0xc0872000 - 0xc08f91e8   ( 541 kB)
       .bss : 0xc08f920c - 0xc0a80c08   (1567 kB)
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
Set periph_clk's parent to pll2_pfd_400M!
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x21e8000 (options '115200')
bootconsole [ttymxc1] enabled
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys cpuacct
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (3162.11 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725  1300 mV at 700 mV fast normal
print_constraints: vddcore: 725  1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725  1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000  2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800  1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625  3400 mV at 3000 mV fast normal
ram_console: got buffer at 3ff00000, size 100000
ram_console: no valid data in buffer (sig = 0x00000000)
console [ram-1] enabled
the clko_clk=688128000
igsboard_add_device_gpio_out
the clko2_clk=24000000
the ssi2_clk=12288000
the clko2_clk=12288000
the init clko_clk=12288000
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32050000, Cache size: 524288 B
bio: create slab  at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
spi_imx imx6q-ecspi.1: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
Unpacking initramfs...
Freeing initrd memory: 228K
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = d9820000 suspend_iram_base=d9894000
PM driver module loaded
IMX usb wakeup probe
the wakeup pdata is 0xd617a5a0
add wake up source irq 75
the wakeup pdata is 0xd617a360
cpu regulator mode:ldo_enable
i.MXC CPU frequency driver
highmem bounce pool size: 64 pages
ashmem: initialized
NTFS driver 2.1.30 [Flags: R/O].
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 762
NET: Registered protocol family 38
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
gpio_out_drv: gpio_out_init
gpio_out_drv: gpio_out_probe
gpio_out_drv: (null),ngpios=-702828532 is on
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver lcd
imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver hdmi
mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0x1a:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
console [ttymxc1] enabled, bootconsole disabled
imx-uart.4: ttymxc4 at MMIO 0x21f4000 (irq = 62) is a IMX
loop: module loaded
m25p80 spi0.0: found m25p05-nonjedec, expected mx25l8005
m25p80 spi0.0: m25p05-nonjedec (64 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000040000 : "bootloader"
mtd: partition "bootloader" extends beyond the end of device "m25p80" -- size truncated to 0x10000
0x000000010000-0x000000010000 : "kernel"
mtd: partition "kernel" is out of reach -- disabled
GPMI NAND driver registered. (IMX)
vcan: Virtual CAN interface driver
CAN device driver interface
flexcan netdevice driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPTP driver version 0.8.5
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for Qualcomm USB modem
usbcore: registered new interface driver qcserial
ARC USBOTG Device Controller driver (1 August 2005)
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
 lun0: LUN: removable file: (no medium)
Gadget Android: controller 'fsl-usb2-udc' not recognized
android_usb gadget: android_usb ready
Suspend udc for OTG auto detect
USB Host suspend begins
will suspend roothub and its children
ehci_fsl_bus_suspend begins, DR
ehci_fsl_bus_suspend ends, DR
host suspend ends
USB Gadget resume begins
fsl_udc_resume, Wait for wakeup thread finishes
dr_controller_run: udc out low power mode
USB Gadget resume ends
fsl-usb2-udc: bind to driver android_usb
mousedev: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: no vmmc regulator found
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
sdhci sdhci-esdhc-imx.1: no write-protect pin available!
mmc1: no vmmc regulator found
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.9754
revserved_memory_account:viv_gpu registerd
Thermal calibration data is 0x5b251d69
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
android_work: did not send uevent (0 0   (null))
mmc0: new high speed DDR MMC card at address 0001
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
mmcblk0: mmc0:0001 M8G1WA 7.28 GiB
[mxc_dac]:mxc_dac_init
mmcblk0boot0: mmc0:0001 M8G1WA partition 1 2.00 MiB
ssi->clk_rate = 12288000
asoc: mxc-hdmi-soc  imx-hdmi-soc-dai.0 mapping ok
1DCR: 00002000
PTCR: 8c400800
2DCR: 00004000
PTCR: 00000800
the clko_clk=12288000
asoc: mxc_dac  imx-ssi.1 mapping ok
ALSA device list:
  #0: imx-hdmi-soc
  #1: imx-dac-audio
oprofile: using arm/armv7-ca9
GACT probability NOT on
Mirror/redirect action on
mmcblk0boot1: mmc0:0001 M8G1WA partition 2 2.00 MiB
u32 classifier
    Actions configured
android_work: sent uevent USB_STATE=CONNECTED
Netfilter messages via NETLINK v0.30.
android_work: sent uevent USB_STATE=DISCONNECTED
nf_conntrack version 0.5.0 (12832 buckets, 51328 max)
 mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
ctnetlink v0.93: registering with nfnetlink.
mmcblk0: p4 size 13090816 extends beyond EOD, truncated
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
IPv4 over IPv4 tunneling driver
GRE over IPv4 demultiplexor driver
ip_tables: (C) 2000-2006 Netfilter Core Team
 mmcblk0boot1: unknown partition table
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
 mmcblk0boot0: unknown partition table
NET: Registered protocol family 10
Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
L2TP IP encapsulation support (L2TPv3)
L2TP netlink interface
L2TP ethernet pseudowire support (L2TPv3)
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
lib80211_crypt: registered algorithm 'WEP'
lib80211_crypt: registered algorithm 'CCMP'
lib80211_crypt: registered algorithm 'TKIP'
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: vmmc: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
我知道答案 目前已有18人回答
发表于 2014-1-9 16:39:18 | 显示全部楼层
RE:android启动不起来
楼主你好,请问你u-boot设置是什么?是否可以提供在u-boot中的print信息?
发表于 2014-1-9 16:42:56 | 显示全部楼层
RE:android启动不起来
另外楼主是通过什么方式启动的?SD还是eMMC?
 楼主| 发表于 2014-1-9 16:48:56 | 显示全部楼层
回复:android启动不起来
printenv打印的log如下:
bootdelay=3
baudrate=115200
ipaddr=192.168.1.103
serverip=192.168.1.101
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=0x11000000
netdev=eth0
ethprime=FEC0
clearenv=sf probe 0 && sf erase 0xc0000 0x2000 && echo restored environment to factory default
ethact=FEC0
bootargs=console=ttymxc1,115200 androidboot.console=ttymxc1 vamalloc=400M init=/init video=mxcfb0:dev=lcd,VGA fbmem=28M
bootcmd=booti mmc1
stdin=serial
stdout=serial
stderr=serial
Environment size: 461/8188 bytes
关于bootargs部分好像打印的是不全的,我在代码中的设置是:
#define CONFIG_EXTRA_ENV_SETTINGS                                       \
                "netdev=eth0\0"                                         \
                "ethprime=FEC0\0"                                       \
                "clearenv=sf probe 0 && sf erase 0xc0000 0x2000 && "    \
                        "echo restored environment to factory default\0" \
                "bootargs=console=ttymxc1,115200 init=/init rw video=mxcfb0:dev=lcd,VGA,if=RGB24 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24 fbmem=10M vmalloc=400M androidboot.console=ttymxc1\0"                     \
                "bootcmd=booti mmc1\0"
 楼主| 发表于 2014-1-9 16:57:12 | 显示全部楼层
回复:android启动不起来
启动的方式是想做成uboot存储在spi nor中,android系统存储在emmc中。
另外,刚才发的printenv的log与代码中设置的不一样的原因是我人重新用setenv设置过,但我不明白的一点是我看到网上别人发的这些log中的bootargs是全的,我的却是打印不全?
发表于 2014-1-10 16:41:11 | 显示全部楼层
RE:android启动不起来
楼主你好,请问您用的板子是i.mx6dl sdp么?
 楼主| 发表于 2014-1-13 09:18:14 | 显示全部楼层
回复:android启动不起来
我的6dl的型号是MCIMX6U5DVM10AB,我只知道这是6dl,并不太清楚"sdp"是什么版本,另外,我在另外一个帖子里面问的,关于ubuntu下的双显使用的也是这个型号(双显这个可否有验证??)
 楼主| 发表于 2014-1-13 09:27:39 | 显示全部楼层
回复:android启动不起来
sorry,刚才没有看清楚,我用的并不是imx6dl sdp的板子,是自己layout的一个板,这个板已经用ubuntu跑过,除了双显之外基本都是OK的,稳定性也还不错并没有出现过死机的现象。另外,那天看你说了uboot的启动参数后我有重新修改了一下uboot的参数,现在android是可以启动了,可以进入到android的动画logo,此时报了一个没有网络的error,所以现在还不能进入系统(我使用的是android_jb4.3_1.1.0-ga_source,linux-2.6-imx-jb4.3_1.1.0-ga,uboot-imx-jb4.3_1.1.0-ga,其中kernel使用的是默认的imx6_android_defconfig)。
发表于 2014-1-13 21:41:45 | 显示全部楼层
回复:android启动不起来
楼主你好,我也碰到了同样的问题,也是自己Layout的板子,不过是参照SABRELITE的板子做的,也是到Freeing init memory: 224K就停了,请问楼主,你修改了uboot的什么配置?多谢了,我现在的uboot命令是console=ttymxc1,115200 init=/init rw video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 fbmem=10M vmalloc=400M androidboot.console=ttymxc1
发表于 2014-1-14 14:49:41 | 显示全部楼层
回复:android启动不起来
回复第 7 楼 于2014-01-13 09:18:14发表:
楼主你好,i.mx6dl关于ubuntu下的双显是可以实现的,你可以参考一下飞思卡尔官网论坛上的http://community.freescale.com/docs/DOC-1471 i.mx6dl和i.mx53类似,都是只有一个IPU。
GMT+8, 2025-10-23 11:06 , Processed in 0.117117 second(s), 30 queries , MemCache On.
