查看: 3249|回复: 2
[求助] code warrior 10.5 中使用processor expert _LDD疑问?
发表于 2014-1-17 10:41:23 | 显示全部楼层 |阅读模式
 code warrior 10.5 中使用processor expert 生成代码时,有一部分模块名以_LDD,例如DMA_LDD,请问带_LDD和不带LDD有什么区别?在使用上,有什么不同?
我知道答案 目前已有1人回答
    发表于 2014-1-17 11:02:24 | 显示全部楼层
    回复: code warrior 10.5 中使用processor expert _LDD疑问?
    暂时我用下来 带LDD的类似库,并附带典型应用等。
    蓝色小图标那种更偏向于手动修改寄存器。
    发表于 2014-1-17 11:21:30 | 显示全部楼层
    最主要的区别是,带LDD的可以用于RTOS, 不带LDD的不可以。 kinetis系列的一般都支持带LDD的
    这时从help里抓来的:
    ·         LDD components - Logical Device Drivers. The LDD components are efficient set of components that are ready to be used together with RTOS. They provide a unified hardware access across MCUs allowing to develop simpler and more portable RTOS drivers or bare board application. See chapter Logical Device Drivers for details.
    还有个图
    Features of Components at Different Level of Abstraction
                Feature
    LDD components
    High level
    Low level
    Peripheral Init
                High-level settings   portable between different MCU families
    partially
    yes
    partially
    no
                Portable method   interface for all CPU families
    yes
    yes
    partially
    (usually direct access   to control registers)
    Init method only
                CPU specific   peripheral features support
    mostly yes
    partially
    mostly yes
    full
                Low-level peripheral   initialization settings
    partially
    no
    partially
    yes
                Speed mode independent   timing
    yes
    yes
    mostly yes
    no
                Events support
    yes
    yes
    yes
    no
    (direct interrupt   handling)
                Software emulation of   a component function (if the specific hardware is not present)
    no
    yes
    no
    no
                Support for RTOS   drivers creation
    yes
    no
    no
    no
    Copyright 2011 Freescale Semiconductor, Inc.
    GMT+8, 2025-10-12 17:45 , Processed in 0.087757 second(s), 23 queries , MemCache On.
