在线时间0 小时
UID2072757
注册时间2014-2-8
NXP金币0
- 5
- 1970-1-1
手上的是客户提供的imx6dq板子,板子是客户自己画的,一开始USB功能都没有问题。前一阵子手贱了下,不知道改了什么东西,现在只能在刷机模式识别usb接口,正常启动android系统后,Ubuntu识别不了板子上的usb设备。下面是串口log,还望帮帮忙,着急累了,谢谢了!!!!
kernel cmdline:
use boot.img command line:
console=ttymxc3,115200 init=/init video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB24,bpp=32 video=mxcfb1 ff video=mxcfb2 ff fbme
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.35-06124-g6298bd2 (inuyasha@inuyasha-Aspire-4741) (gcc version 4.6.x-google 20120106 (prerelea4
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] CPU identified as i.MX6DL/SOLO, silicon rev 1.1
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c10c4000 s6592 r8192 d13888 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 208384
[ 0.000000] Kernel command line: console=ttymxc3,115200 init=/init video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB24,bpp=32 video=mxcfe
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 379MB 203MB 240MB = 822MB total
[ 0.000000] Memory: 823920k/823920k available, 224656k reserved, 442368K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xfbe00000 - 0xffe00000 ( 64 MB)
[ 0.000000] vmalloc : 0xd9800000 - 0xf2000000 ( 392 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd9000000 ( 400 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc003e000 ( 216 kB)
[ 0.000000] .text : 0xc003e000 - 0xc06d9f38 (6768 kB)
[ 0.000000] .data : 0xc06da000 - 0xc0743e90 ( 424 kB)
[ 0.000000] .bss : 0xc0743eb4 - 0xc08baf88 (1501 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:624
[ 0.000000] MXC GPIO hardware
[ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
[ 0.000000] Set periph_clk's parent to pll2_pfd_400M!
[ 0.000000] arm_max_freq=1GHz
[ 0.000000] MXC_Early serial console at MMIO 0x21f0000 (options '115200')
[ 0.000000] bootconsole [ttymxc3] enabled
[ 0.226533] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
[ 0.319264] pid_max: default: 32768 minimum: 301
[ 0.324132] Mount-cache hash table entries: 512
[ 0.329416] Initializing cgroup subsys debug
[ 0.333707] Initializing cgroup subsys cpuacct
[ 0.338209] Initializing cgroup subsys freezer
[ 0.342737] CPU: Testing write buffer coherency: ok
[ 0.347937] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 0.468563] CPU1: Booted secondary processor
[ 0.527930] Brought up 2 CPUs
[ 0.535190] SMP: Total of 2 processors activated (3162.11 BogoMIPS).
[ 0.567036] print_constraints: dummy:
[ 0.571075] NET: Registered protocol family 16
[ 0.580584] print_constraints: vddpu: 725 1300 mV at 700 mV fast normal
[ 0.588153] print_constraints: vddcore: 725 1300 mV at 1150 mV fast normal
[ 0.595997] print_constraints: vddsoc: 725 1300 mV at 1200 mV fast normal
[ 0.603735] print_constraints: vdd2p5: 2000 2775 mV at 2400 mV fast normal
[ 0.611558] print_constraints: vdd1p1: 800 1400 mV at 1100 mV fast normal
[ 0.619309] print_constraints: vdd3p0: 2625 3400 mV at 3000 mV fast normal
[ 0.636605] the rate in mxc_cs4344_init=22579200
[ 0.650066] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.656880] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
[ 0.664255] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.670152] L310 cache controller enabled
[ 0.674180] l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B
[ 0.707617] bio: create slab at 0
[ 0.715215] mxs-dma mxs-dma-apbh: initialized
[ 0.720021] print_constraints: vmmc: 3300 mV
[ 0.726081] SCSI subsystem initialized
[ 0.730525] usbcore: registered new interface driver usbfs
[ 0.736179] usbcore: registered new interface driver hub
[ 0.741772] usbcore: registered new device driver usb
[ 0.746845] Freescale USB OTG Driver loaded, $Revision: 1.55 $
[ 0.947909] mc_pfuze 1-0008: recv failed!:-5,0
[ 0.952380] mc_pfuze: probe of 1-0008 failed with error -1
[ 0.959787] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
[ 0.966253] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
[ 0.974001] MIPI CSI2 driver module loaded
[ 0.978373] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.985858] i2c-core: driver [max17135] using legacy suspend method
[ 0.992161] i2c-core: driver [max17135] using legacy resume method
[ 0.998391] Switching to clocksource mxc_timer1
[ 1.013329] NET: Registered protocol family 2
[ 1.017877] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.025411] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.033729] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 1.041519] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.048085] TCP reno registered
[ 1.051242] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.057124] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.063794] NET: Registered protocol family 1
[ 1.068332] Unpacking initramfs...
[ 1.084631] Freeing initrd memory: 176K
[ 1.089376] PMU: registered new PMU device of type 0
[ 1.094536] Static Power Management for Freescale i.MX6
[ 1.099780] wait mode is enabled for i.MX6
[ 1.104117] cpaddr = d9820000 suspend_iram_base=d98b8000
[ 1.109536] PM driver module loaded
[ 1.113332] IMX usb wakeup probe
[ 1.117086] add wake up source irq 75
[ 1.124477] IMX usb wakeup probe
[ 1.128026] cpu regulator mode:ldo_enable
[ 1.132273] i.MXC CPU frequency driver
[ 1.146154] highmem bounce pool size: 64 pages
[ 1.150904] ashmem: initialized
[ 1.154641] NTFS driver 2.1.30 [Flags: R/O].
[ 1.158988] fuse init (API version 7.16)
[ 1.163193] msgmni has been set to 745
[ 1.168033] NET: Registered protocol family 38
[ 1.172674] cryptodev: driver loaded.
[ 1.176392] io scheduler noop registered
[ 1.180328] io scheduler deadline registered
[ 1.184677] io scheduler cfq registered (default)
[ 1.190813] mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
[ 1.197166] MIPI DSI driver module loaded
[ 1.201389] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver lcd
[ 1.208535] mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
[ 1.215717] imx-sdma imx-sdma: loaded firmware 1.1
[ 1.225525] imx-sdma imx-sdma: initialized
[ 1.366772] Serial: IMX driver
[ 1.369953] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
[ 1.376931] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
[ 1.383435] console [ttymxc3] enabled, bootconsole disabled
[ 1.401210] loop: module loaded
[ 1.405460] PPP generic driver version 2.4.2
[ 1.410213] PPP Deflate Compression module registered
[ 1.415297] PPP BSD Compression module registered
[ 1.420455] PPP MPPE Compression module registered
[ 1.425274] NET: Registered protocol family 24
[ 1.429746] PPTP driver version 0.8.5
[ 1.433724] tun: Universal TUN/TAP device driver, 1.6
[ 1.438784] tun: (C) 1999-2004 Max Krasnyansky
[ 1.445509] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.452264] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[ 1.458929] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[ 1.493011] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
[ 1.512990] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[ 1.519281] hub 1-0:1.0: USB hub found
[ 1.523069] hub 1-0:1.0: 1 port detected
[ 1.527188] add wake up source irq 72
[ 1.530893] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
[ 1.537542] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
[ 1.573005] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
[ 1.592991] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
[ 1.599220] hub 2-0:1.0: USB hub found
[ 1.603004] hub 2-0:1.0: 1 port detected
[ 1.607337] usbcore: registered new interface driver cdc_acm
[ 1.613018] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.621025] Initializing USB Mass Storage driver...
[ 1.626109] usbcore: registered new interface driver usb-storage
[ 1.632161] USB Mass Storage support registered.
[ 1.637096] usbcore: registered new interface driver usbserial
[ 1.642937] usbserial: USB Serial Driver core
[ 1.647431] USB Serial support registered for GSM modem (1-port)
[ 1.653654] usbcore: registered new interface driver option
[ 1.659229] option: v0.7.2:USB Driver for GSM modems
[ 1.664328] USB Serial support registered for Qualcomm USB modem
[ 1.670482] usbcore: registered new interface driver qcserial
[ 1.676247] ARC USBOTG Device Controller driver (1 August 2005)
[ 1.685981] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.692867] android_usb gadget: Number of LUNs=1
[ 1.697523] lun0: LUN: removable file: (no medium)
[ 1.703048] Gadget Android: controller 'fsl-usb2-udc' not recognized
[ 1.709415] android_usb gadget: android_usb ready
[ 1.714137] Suspend udc for OTG auto detect
[ 1.718328] fsl-usb2-udc: bind to driver android_usb
[ 1.723937] mousedev: PS/2 mouse device common for all mice
[ 1.730014] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.738855] using rtc device, snvs_rtc, for alarms
[ 1.743506] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
[ 1.750382] i2c /dev entries driver
[ 1.754813] Linux video capture interface: v2.00
[ 1.759932] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[ 1.768190] device-mapper: uevent: version 1.0.3
[ 1.773173] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 1.781977] sdhci: Secure Digital Host Controller Interface driver
[ 1.788181] sdhci: Copyright(c) Pierre Ossman
[ 1.792952] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
[ 1.800441] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 1.808652] VPU initialized
[ 1.812087] mxc_asrc registered
[ 1.835701] revserved_memory_account:viv_gpu registerd
[ 1.846809] Thermal calibration data is 0x59350469
[ 1.851604] Thermal sensor with ratio = 185
[ 1.873024] Anatop Thermal registered as thermal_zone0
[ 1.880216] anatop_thermal_probe: default cooling device is cpufreq!
[ 1.888376] usbcore: registered new interface driver usbhid
[ 1.893972] usbhid: USB HID core driver
[ 1.898469] logger: created 256K log 'log_main'
[ 1.903293] logger: created 256K log 'log_events'
[ 1.908227] logger: created 256K log 'log_radio'
[ 1.913091] logger: created 256K log 'log_system'
[ 1.918606] usbcore: registered new interface driver snd-usb-audio
[ 1.925509] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
[ 1.931373] here run in cs4344_probe in cs4344.c
[ 1.936051] usb 2-1: new high speed USB device number 2 using fsl-ehci
[ 1.949954] mmc0: new high speed DDR MMC card at address 0001
[ 1.956382] mmcblk0: mmc0:0001 MMC04G 3.57 GiB
[ 1.956498] imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
[ 1.958363] asoc: cs4344-hifi imx-ssi.1 mapping ok
[ 1.959228] here run in imx_asoc_init in imx-cs4344.c
[ 1.959678] Initialize HDMI-audio failed. Load HDMI-video first!
[ 1.959685] ALSA device list:
[ 1.959691] #0: cs4344-audio
[ 1.960075] oprofile: using arm/armv7-ca9
[ 1.994500] Netfilter messages via NETLINK v0.30.
[ 1.999287] mmcblk0boot0: mmc0:0001 MMC04G partition 1 2.00 MiB
[ 1.999319] nf_conntrack version 0.5.0 (12876 buckets, 51504 max)
[ 2.011528] mmcblk0boot1: mmc0:0001 MMC04G partition 2 2.00 MiB
[ 2.011544] ctnetlink v0.93: registering with nfnetlink.
[ 2.011590] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.011597] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.036117] xt_time: kernel timezone is -0000
[ 2.040521] IPv4 over IPv4 tunneling driver
[ 2.043027] mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
[ 2.043287] mmcblk0: p4 size 5308416 extends beyond EOD, truncated
[ 2.056853] GRE over IPv4 demultiplexor driver
[ 2.059264] mmcblk0boot1: unknown partition table
[ 2.066487] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.071957] arp_tables: (C) 2002 David S. Miller
[ 2.076747] TCP cubic registered
[ 2.078635] mmcblk0boot0: unknown partition table
[ 2.084983] NET: Registered protocol family 10
[ 2.090228] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.096293] IPv6 over IPv4 tunneling driver
[ 2.101897] NET: Registered protocol family 17
[ 2.106403] NET: Registered protocol family 15
[ 2.110854] L2TP core driver, V2.0
[ 2.114302] PPPoL2TP kernel driver, V2.0
[ 2.118226] L2TP IP encapsulation support (L2TPv3)
[ 2.123118] L2TP netlink interface
[ 2.126546] L2TP ethernet pseudowire support (L2TPv3)
[ 2.131599] lib80211: common routines for IEEE802.11 drivers
[ 2.137307] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 2.145437] Bus freq driver module loaded
[ 2.149457] Bus freq driver Enabled
[ 2.154964] mxc_dvfs_core_probe
[ 2.158390] DVFS driver module loaded
[ 2.163169] GTP driver install.
[ 2.167724] GTP Driver Version:V1.0
[ 2.173593] GTP Driver build@15:39:31,Jan 27 2014
[ 2.293315] input: Goodix Capacitive TouchScreen as /devices/virtual/input/input1
[ 2.301412] GTP works in interrupt mode.
[ 2.502988] GTP chip version:f811_2010
[ 2.508045] Applied memory size:2562.
[ 2.513044] Create proc entry success!
[ 2.518778] Freeing init memory: 216K
[ 2.522442] kernel_init done
[ 3.131507] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 3.214108] android_usb: already disabled
[ 3.219485] android_usb: already disabled
[ 3.223912] mtp_bind_config
[ 3.226758] adb_bind_config
[ 3.246743] warning: `adbd' uses 32-bit capabilities (legacy support in use)
[ 3.258771] adb_open
root@android:/ # [ 3.865360] imx-ipuv3 imx-ipuv3.0: Warning: channel already initialized 9
[ 3.865408] imx-ipuv3 imx-ipuv3.0: Warning: channel already enabled 9
[ 8.932873] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 10.992478] request_suspend_state: wakeup (3->0) at 10759510336 (1970-01-02 00:00:01.817049000 UTC)
[ 11.001878] cpufreq_interactive_input_connect: connect to Goodix Capacitive TouchScreen
[ 11.376761] acc_open
[ 11.378967] acc_release
