查看: 5792|回复: 2
[已解决] 使用iar软件,jlink连上后异常-求助飞思卡尔FAE线上技术支持(已解决)
发表于 2014-2-24 13:41:51 | 显示全部楼层 |阅读模式
 使用了 fresscale的tower的板子,用的是k21芯片。
demo代码编好后,download and debug后,
出现的log:
疑问
1.为什么load进去是k60的mac文件。
2.为什么jlink连不上呢?是不是因为第一个原因烧坏了tower板子?
Thu Apr 25, 2013 13:38:44: Loaded macro file: C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Xxxx64K.mac
Thu Apr 25, 2013 13:38:45: JLINK command: ProjectFile = C:\god\Freescale_MQX_4_0\mqx\examples\hello\iar\hello_twrk21d50m\settings\hello_twrk21d50m_Int Flash Debug.jlink, return = 0
Thu Apr 25, 2013 13:38:45: Device "MK21DN512XXX5" selected (512 KB flash, 64 KB RAM).
Thu Apr 25, 2013 13:38:45: DLL version: V4.68a, compiled Apr 12 2013 13:26:50
Thu Apr 25, 2013 13:38:45: Firmware: J-Link V9 compiled Jan 11 2013 12:33:03
Thu Apr 25, 2013 13:38:45: Selecting SWD as current target interface.
Thu Apr 25, 2013 13:38:45: JTAG speed is initially set to: 32 kHz
Thu Apr 25, 2013 13:38:45: Found SWD-DP with ID 0x2BA01477
Thu Apr 25, 2013 13:39:05: Found SWD-DP with ID 0x2BA01477
Thu Apr 25, 2013 13:39:05: TPIU fitted.
Thu Apr 25, 2013 13:39:05: ETM fitted.
Thu Apr 25, 2013 13:39:05: ETB present.
Thu Apr 25, 2013 13:39:05: CSTF present.
Thu Apr 25, 2013 13:39:05: FPUnit: 6 code (BP) slots and 2 literal slots
Thu Apr 25, 2013 13:39:05: Found Cortex-M4 r0p1, Little endian.
Thu Apr 25, 2013 13:39:06: Hardware reset with strategy 0 was performed
Thu Apr 25, 2013 13:39:06: Initial reset was performed
Thu Apr 25, 2013 13:39:06: ----- Prepare hardware for Flashloader -----
Thu Apr 25, 2013 13:39:06: 1536 bytes downloaded (16.13 Kbytes/sec)
Thu Apr 25, 2013 13:39:06: Loaded debugee: C:\Program Files (x86)\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashK60Dxxx64K.out
Thu Apr 25, 2013 13:39:06: Target reset
Thu Apr 25, 2013 13:39:06: The flash loader program reported an error.
我知道答案 目前已有1人回答
发表于 2014-2-24 15:51:24 | 显示全部楼层
RE: 使用iar软件,jlink连上后异常-求助飞思卡尔FAE线上技术支持
请问你用的RTOS 是 专门针对K21F20M的rtos吗?
发表于 2014-3-4 16:24:55 | 显示全部楼层
应该不会烧坏,你的flash loader选的什么呢?
这个最新的.board不知道你那边有没有,这个你可以和IAR公司的人联系看看有没有更新上来。
GMT+8, 2025-9-17 07:18 , Processed in 0.086216 second(s), 23 queries , MemCache On.
