查看: 3340|回复: 2
[已解决] KL46Z的SW1和SW2在调试外部中断设置(已解决)
发表于 2014-2-27 11:01:46 | 显示全部楼层 |阅读模式
KL46ZSW1SW2在调试外部中断,配置成下降沿触发。出现按一次按键,进入两次中断,也就是按键按下去时进一次,按键抬起时又进一次。该问题怎么解决。
代码如下:
void PTC12_Init(void)
  unsigned long tempReg;
  SIM_SCGC5 |= SIM_SCGC5_PORTC_MASK ;    //开启PORTC端口
  tempReg = PORTC_PCR12;
  //清除对应位域的值
  tempReg &= ~( PORT_PCR_ISF_MASK | PORT_PCR_IRQC_MASK | PORT_PCR_MUX_MASK );
  //配置 上升沿中断 GPIO 口, 上拉使能
  tempReg |= PORT_PCR_MUX(1) | PORT_PCR_IRQC(10) | PORT_PCR_PE_MASK | PORT_PCR_PS_MASK;
  PORTC_PCR12 = tempReg ;
  GPIOC_PDDR &=  ~GPIO_PIN_12_MASK;  //输入
  enable_irq(31); //使能中断
我知道答案 目前已有1人回答
    发表于 2014-2-27 11:15:54 | 显示全部楼层
    回复:KL46Z的SW1和SW2在调试外部中断设置
    楼主你好,如果你需要将引脚配置成上升沿中断,应该将PORTx_PCRn寄存器的IRQC配置成1001如图:
    发表于 2014-2-27 11:39:07 | 显示全部楼层
    另外PORTx_PCRn寄存器的中断标志ISF位,是写1清除的。
    请阅读参考手册:
    Configured interrupt is detected. If the pin is configured to generate a DMA request, then the corresponding flag will be cleared automatically at the completion of the requested DMA transfer. Otherwise, the flag remains set until a logic one is written to the flag. If the pin is configured for a level sensitive interrupt and the pin remains asserted, then the flag is set again immediately after it is
    cleared.
    GMT+8, 2025-10-12 20:01 , Processed in 0.088644 second(s), 24 queries , MemCache On.
