查看: 5494|回复: 5
[MPC] 求教mpc5604b can通信问题
发表于 2014-3-25 15:48:23 | 显示全部楼层 |阅读模式
关于CAN,官方例程如下:
/* main.c: FlexCAN program */
/* Description: Transmit one message from FlexCAN 0 buf. 0 to FlexCAN C buf. 1 */
/* Rev 0.1 Jan 16, 2006 S.Mihalik, Copyright Freescale, 2006. All Rights Reserved */
/* Rev 0.2 Jun 6 2006 SM - changed Flexcan A to C & enabled 64 msg buffers */
/* Rev 0.3 Jun 15 2006 SM - 1. Made globals uninitialized */
/*         2. RecieveMsg function:  read CANx_TIMER, removed setting buffer's CODE*/
/*         3. added idle loop code for smoother Nexus trace */
/*         4. modified for newer Freescale header files (r 16) */
/* Rev 0.4 Aug 11 2006 SM - Removed redundant CAN_A.MCR init */
/* Rev 0.5 Jan 31 2007 SM - Removed other redundant CAN_C.MCR init */
/* Rev 0.6 Mar 08 2007 SM - Corrected init of MBs- cleared 64 MBs, instead of 63 */
/* Rev 0.7 Jul 20 2007 SM - Changes for MPC5510 */
/* Rev 0.8 May 15 2008 SM - Changes for new header file symbols */
/* Rev 0.9 May 22 2009 SM - Changes for MPC56xxB/P/S */
/* Rev 1.0 Jul 10 2009 SM - Simplified, cleared CAN Msg Buf flag by writing to reg */
/*   not bit, increased Tx pads slew rate, changed RxCODE, RxLENGTH, dummy data types*/
/*   & init receiving CAN first to allow CAN bus sync time before receiving 1st msg*/
/* Rev 1.1 Mar 14 2010 SM - modified initModesAndClock, updated header file */
/*  NOTE!! structure canbuf_t in header file modified to allow byte addressing*/
#include "MPC5604B_0M27V_0102.h" /* Use proper include file */
uint32_t  RxCODE;              /* Received message buffer code */
uint32_t RxID;                 /* Received message ID */
uint32_t  RxLENGTH;            /* Recieved message number of data bytes */
uint8_t  RxDATA[8];            /* Received message data string*/
uint32_t RxTIMESTAMP;          /* Received message time */
void initModesAndClks(void) {
  ME.MER.R = 0x0000001D;          /* Enable DRUN, RUN0, SAFE, RESET modes */
                                  /* Initialize PLL before turning it on: */
/* Use 1 of the next 2 lines depending on crystal frequency: */
  CGM.FMPLL_CR.R = 0x02400100;    /* 8 MHz xtal: Set PLL0 to 64 MHz */
/*CGM.FMPLL_CR.R = 0x12400100;*/  /* 40 MHz xtal: Set PLL0 to 64 MHz */
  ME.RUN[0].R = 0x001F0074;       /* RUN0 cfg: 16MHzIRCON,OSC0ON,PLL0ON,syclk=PLL */
  ME.RUNPC[1].R = 0x00000010;    /* Peri. Cfg. 1 settings: only run in RUN0 mode */
  ME.PCTL[16].R = 0x01;           /* MPC56xxB/P/S FlexCAN0: select ME.RUNPC[1] */
  ME.PCTL[17].R = 0x01;           /* MPC56xxB/S FlexCAN1:  select ME.RUNPC[1] */
  ME.PCTL[68].R = 0x01;           /* MPC56xxB/S SIUL:  select ME.RUNPC[1] */
                                  /* Mode Transition to enter RUN0 mode: */
  ME.MCTL.R = 0x40005AF0;         /* Enter RUN0 Mode & Key */
  ME.MCTL.R = 0x4000A50F;         /* Enter RUN0 Mode & Inverted Key */
  while (ME.GS.B.S_MTRANS) {}     /* Wait for mode transition to complete */
                                  /* Note: could wait here using timer and/or I_TC IRQ */
  while(ME.GS.B.S_CURRENTMODE != 4) {} /* Verify RUN0 is the current mode */
void initPeriClkGen(void) {
  CGM.SC_DC[1].R = 0x80;     /* MPC56xxB/S: Enable peri set 2 sysclk divided by 1 */
void disableWatchdog(void) {
  SWT.SR.R = 0x0000c520;     /* Write keys to clear soft lock bit */
  SWT.SR.R = 0x0000d928;
  SWT.CR.R = 0x8000010A;     /* Clear watchdog enable (WEN) */
void initCAN_1 (void) {
  uint8_t   i;
  CAN_1.MCR.R = 0x5000003F;       /* Put in Freeze Mode & enable all 64 msg bufs */
  CAN_1.CR.R = 0x04DB0006;        /* Configure for 8MHz OSC, 100KHz bit time */
  for (i=0; i
我知道答案 目前已有5人回答
发表于 2014-3-26 13:06:57 | 显示全部楼层
回复:求教mpc5604b can通信问题
你好,关于CAN的硬件连接,你芯片的TX和RX出来之后需要接一个CAN的收发器,周立功有这样的收发器:https://wenku.baidu.com/view/eef6b4030740be1e650e9afc.html
如果是两块芯片的CAN通信,他们的TX,RX出来都要先接收发器,然后收发器出来之后的CAN总线上CANH接一起,CANL接一起,在总线两端,需要加上120欧的电阻。
还有关于程序,如果你芯片功能是CAN双向通信,那么程序肯定是收发都有的。
希望我的回答能帮到你。
发表于 2014-5-25 19:50:10 | 显示全部楼层
RE:求教mpc5604b can通信问题
在MC_ME模块里也需要配置一下,另外收发器的RS脚也需要定义一下
发表于 2014-11-27 20:22:40 来自手机 | 显示全部楼层
你会弄Flashmemory的东西么
发表于 2015-8-31 12:26:10 | 显示全部楼层
程序貌似不完整啊
发表于 2015-9-17 23:18:12 | 显示全部楼层
同求此问题
GMT+8, 2025-11-5 09:14 , Processed in 0.096414 second(s), 27 queries , MemCache On.
