在线时间120 小时
UID2008616
注册时间2013-5-8
NXP金币27
- 3279
- 1970-1-1
发表于 2014-4-22 16:17:10
显示全部楼层
回复:i.mx28 NAND flash问题
回复第 19 楼 于2014-04-22 16:03:36发表:
1 mfg下载后,不修改任何文件直接烧
串口显示:
MXS RTC driver v1.0 hardware v2.3.0
mxs-rtc mxs-rtc.0: rtc core: registered mxs-rtc as rtc0
mxs-mmc: MXS SSP Controller MMC Interface driver
mxs-kbd mxs-kbd.0: Invalid button: raw = 1395, normalized = 1424, vddio = 3675
mxs-kbd mxs-kbd.0: Invalid button: raw = 1415, normalized = 1452, vddio = 3657
__mxs_reset_block(f0010000): timeout when resetting
mxs-mmc mxs-mmc.0: mmc0: MXS SSP MMC DMAIRQ 82 ERRIRQ 96
mxs-rtc mxs-rtc.0: setting system clock to 1970-01-01 00:00:10 UTC (10)
mxs-kbd mxs-kbd.0: Invalid button: raw = 1437, normalized = 1464, vddio = 3683
Freeing init memory: 124K
Starting UTP
disable turn off display
uuc 0.4 [built Dec 26 2010 23:10:08]
UTP: Waiting for device to appear
utp_mk_devnode: creating node '/dev/utp' with 10+222
cpu_id is 28
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SU04G 3.69 GiB
mmcblk0: p1 p2 p3
g_file_storage gadget: high speed config #1
UTP: received command 'mknod clautp_exec: exit with status -22
ss/mtd,mtd0,/dev/mtd0'
class = 'class/mtd'
item = 'mtd0'
node = /dev/mtd0
type = (null)
UTP: running utp_mk_devnode(class/mtd,mtd0,/dev/mtd0,0x2000)
UTP: sending Non-success
mfglog 文件显示:
Tuesday, April 22, 2014 16:00:35
1 - Panel A Start processing Singlechip NAND.
Panel A Start type="boot" body="Recovery" file="updater_ivt.sb" timeout="60" onError="" text="Booting Update Firmware.".
1 - Panel A Finished type="boot" body="Recovery" file="updater_ivt.sb" timeout="60" onError="" text="Booting Update Firmware." SUCCESS code=0x0.
Panel A Start type="find" body="Updater" file="" timeout="180" onError="" text="".
Panel A UtpUpdate Event: DeviceRemoval Msg: (null) DevState: Disconnected OpState: WAITING_FOR_DEVICE
Panel A UtpUpdate Event: VolumeArrival Msg: (null) DevState: Updater OpState: WAITING_FOR_DEVICE
1 - Panel A Finished type="find" body="Updater" file="" timeout="180" onError="" text="" SUCCESS code=0x0.
Panel A Start type="push" body="mknod class/mtd,mtd0,/dev/mtd0" file="" timeout="10" onError="" text="".
1 - Panel A Finished type="push" body="mknod class/mtd,mtd0,/dev/mtd0" file="" timeout="10" onError="" text="" FAIL code=0xffffffea.
Panel A: Command is not supported by device.,failed to run command: type="push" body="mknod class/mtd,mtd0,/dev/mtd0" file="" timeout="10" onError="" text=""
2 - Panel A Finished processing Singlechip NAND: FAIL code=-22.
Panel A: Reason is unknown,
请问你是要烧写到NAND还是SD卡上?烧写到SD卡上的话是可以直接烧写的,烧写的NAND上的话,是不可以直接使用MFGTool来烧写的。 |
