查看: 3415|回复: 3
基于freescaleMC9S08DZ60IC的中断向量重定向后进不了中断(已解决)
发表于 2014-4-28 15:21:04 | 显示全部楼层 |阅读模式
            Dear all,
            问题点:
            我现在在做基于MC9S08DZ60的CAN bootloader程序,因为bootloader占用的flash地址是从0xF400-0xFFFF,所以我想把用户中断向量从默认的0xFFC0-0xFFFF重定向到0xF3C0-0xF3FF。MC9S08DZ60 datasheet上面说只要给@0xFFBF第7位写0 and @0xFFBD设置0xF400-0xFFFF保护,中断向量就会重定向到0xF3C0-0xF3FF,我增加代码如下:
            const unsigned char NVOPT_INIT @0xFFBF = 0x02; // vector redirect, flash unsecure
            const unsigned char NVPROT_INIT @0x0000FFBD = 0xFA; // 0xFC00-0xFFFF are protected= 0x02; // vector redirect, flash unsecure
            extern interrupt void Dummy_ISR();
            extern interrupt void TPM2_10ms ();
            // redirect vector 0xFFC0-0xFFFD to 0xFBC0-0xFBFD
            void (* volatile const _Usr_Vector[])()@0xF3C0= {
            TPM2_10ms, // Int.no.31 RTC (at F3C0) (at FFC4)
            Dummy_ISR, // Int.no.30 RTC (at F3C2) (at FFC4)
            Dummy_ISR, // Int.no.29 RTC (at F3C4) (at FFC4)
            Dummy_ISR, // Int.no.28 IIC (at F3C6) (at FFC6)
            Dummy_ISR, // Int.no.27 ACMP (at F3C8) (at FFC8)
            Dummy_ISR, // Int.no.26 ADC (at F3CA) (at FFCA)
            Dummy_ISR, // Int.no.25 KBI (at F3CC) (at FFCC)
            Dummy_ISR, // Int.no.24 SCI2 Transmit (at F3CE) (at FFCE)
            Dummy_ISR, // Int.no.23 SCI2 Receive (at F***0) (at FFD0)
            Dummy_ISR, // Int.no.22 SCI2 Error (at F***2) (at FFD2)
            Dummy_ISR, // Int.no.21 SCI1 Transmit (at F***4) (at FFD4)
            Dummy_ISR, // Int.no.20 SCI1 Receive (at F***6) (at FFD6)
            Dummy_ISR, // Int.no.19 SCI1 error (at F***8) (at FFD8)
            Dummy_ISR, // Int.no.18 TPM2 Overflow (at F***A) (at FFDA)
            Dummy_ISR, // Int.no.17 TPM2 CH1 (at F***C) (at FFDC)
            Dummy_ISR, // Int.no.16 TPM2 CH0 (at F***E) (at FFDE)
            Dummy_ISR, // Int.no.15 TPM1 Overflow (at F3E0) (at FFE0)
            TPM2_10ms, // Int.no.14 TPM1 CH5 (at F3E2) (at FFE2)
            Dummy_ISR, // Int.no.13 TPM1 CH4 (at F3E4) (at FFE4)
            Dummy_ISR, // Int.no.12 TPM1 CH3 (at F3E6) (at FFE6)
            Dummy_ISR, // Int.no.11 TPM1 CH2 (at F3E8) (at FFE8)
            Dummy_ISR, // Int.no.10 TPM1 CH1 (at F3EA) (at FFEA)
            Dummy_ISR, // Int.no.9 TPM1 CH0 (at F3EC) (at FFEC)
            Dummy_ISR, // Int.no.8 Reserved (at F3EE) (at FFEE)
            Dummy_ISR, // Int.no.7 USB Statue (at F3F0) (at FFF0)
            Dummy_ISR, // Int.no.6 SPI2 (at F3F2) (at FFF2)
            Dummy_ISR, // Int.no.5 SPI1 (at F3F4) (at FFF4)
            Dummy_ISR, // Int.no.4 Loss of lock (at F3F6) (at FFF6)
            Dummy_ISR, // Int.no.3 LVI (at F3F8) (at FFF8)
            Dummy_ISR, // Int.no.2 IRQ (at F3FA) (at FFFA)
            Dummy_ISR, // Int.no.1 SWI (at F3FC) (at FFFC)
            interrupt void TPM2_10ms(){
                PTDD_PTDD2=!PTDD_PTDD2;
                   TPM2SC_TOF=0;
                  // PTDD_PTDD0=!PTDD_PTDD0;
                   PTDD_PTDD3=!PTDD_PTDD3;
            interrupt void Dummy_ISR(){
            //#pragma CODE_SEG DEFAULT
            生成的S19文件中,中断向量是被重定向到0xF3C0-0xF3FD了,但是程序进不了中断服务程序
            请高手指点下我的问题出在哪?
            thanks for your help。
 楼主| 发表于 2014-4-28 16:58:20 | 显示全部楼层
回复:基于freescaleMC9S08DZ60IC的中断向量重定向后进不了中断
 已解决,谢谢
  • 签到天数: 49 天
    发表于 2014-5-8 14:07:38 | 显示全部楼层
    RE:基于freescaleMC9S08DZ60IC的中断向量重定向后进不了中断(已解决)
    怎么解决的?我现在也是遇到了相同的问题,我是还想用中断向量号来编写中断函数,不想用你上面的写的那么方式,
    还是先说说你是怎么解决的吧,
     楼主| 发表于 2014-5-16 12:40:47 | 显示全部楼层
    回复:基于freescaleMC9S08DZ60IC的中断向量重定向后进不了中断(已解决)
    回复第 3 楼 于2014-05-08 14:07:38发表:
    因为中断向量表中写错了啊,写了两次TPM2的中断,删掉最上面的一个就对了
    GMT+8, 2026-2-6 01:38 , Processed in 0.087098 second(s), 21 queries , Redis On.
