查看: 3338|回复: 5
[已解决] K60FX512VLQ15 WDOG(已解决)
发表于 2014-5-27 09:48:19 | 显示全部楼层 |阅读模式
 能帮我看一下,为什么调用后还是COP复位?
#define EnableInterrupts asm(" CPSIE i");
#define DisableInterrupts asm(" CPSID i");
 * Watchdog timer disable routine
 * Parameters:
 * none
void wdog_disable(void)
        /* First unlock the watchdog so that we can write to registers */
        wdog_unlock();
        /* Clear the WDOGEN bit to disable the watchdog */
        WDOG_STCTRLH &= ~WDOG_STCTRLH_WDOGEN_MASK;
void wdog_enable(void)
        wdog_unlock();
        WDOG_STCTRLH |= WDOG_STCTRLH_WDOGEN_MASK;
 * Watchdog timer unlock routine. Writing 0xC520 followed by 0xD928
 * will unlock the write once registers in the WDOG so they are writable
 * within the WCT period.
 * Parameters:
 * none
void wdog_unlock(void)
  /* NOTE: DO NOT SINGLE STEP THROUGH THIS FUNCTION!!! */
  /* There are timing requirements for the execution of the unlock. If
   * you single step through the code you will cause the CPU to reset.
        /* This sequence must execute within 20 clock cycles, so disable
         * interrupts will keep the code atomic and ensure the timing.
        DisableInterrupts;
        /* Write 0xC520 to the unlock register */
        WDOG_UNLOCK = 0xC520;
        /* Followed by 0xD928 to complete the unlock */
        WDOG_UNLOCK = 0xD928;
        /* Re-enable interrupts now that we are done */
               EnableInterrupts;
void wdog_init(void)
    // 解锁
    wdog_unlock();
    // 预分频 PRESCVAL = 4, Wdog colck = BUS/(4+1) = 15M
    WDOG_PRESC = 0x0400;
    // 2秒
    WDOG_TOVALH = 0x01C9;
    WDOG_TOVALL = 0xC380;
    // 使能总线,静止窗口模式,禁止看门口中断,开启开门狗
    WDOG_STCTRLH = 0x01D3;
void wdog_feed(void)
    // 解锁
    wdog_unlock();
    // PRESCVAL = 4, Wdog colck = BUS/(4+1) = 15M
    WDOG_REFRESH = 0xA602;
    WDOG_REFRESH = 0xB480;
我知道答案 目前已有4人回答
    发表于 2014-5-27 14:25:39 | 显示全部楼层
    回复:K60FX512VLQ15 WDOG
    楼主你好
    请参考这个网友的操作方法试一下:
    (Kinetis K60)WDOG看门狗测试
    发表于 2014-5-27 14:39:18 | 显示全部楼层
    楼主你有经常喂狗吗?
    你这样设置2、3秒就需要喂一次狗了。
     楼主| 发表于 2014-5-27 14:58:45 | 显示全部楼层
    回复:K60FX512VLQ15 WDOG【已解决】
    回复第 2 楼 于2014-05-27 14:25:39发表:
    楼主你好
    请参考这个网友的操作方法试一下:
     多谢!
     楼主| 发表于 2014-5-27 14:59:33 | 显示全部楼层
    回复第 3 楼 于2014-05-27 14:39:18发表:
    楼主你有经常喂狗吗?
    你这样设置2、3秒就需要喂一次狗了。
    多谢,已经解决。按二楼例程可用:) 我在循环判断是否喂狗,测试时基本上所有时间都在喂狗
    发表于 2014-5-27 15:42:45 | 显示全部楼层
    回复第 5 楼 于2014-05-27 14:59:33发表:
    楼主你有经常喂狗吗?
    你这样设置2、3秒就需要喂一次狗了。
    和二楼程序区别不大嘛,问题出在哪呢? 是喂狗操作中解锁、分频步骤多余导致的?
    如果要谢我,就在我参与活动的帖子【我眼中的FTF2014】Kinetis二代K2产品里回复一下,帮我获个奖呗!
    GMT+8, 2025-11-2 04:56 , Processed in 0.119318 second(s), 26 queries , MemCache On.
