查看: 16366|回复: 11
[已解决] [i.MX] mfgtoolsRel-4.1.0修改从norflash启动,write U-boot to spi nor失败(已解决)
发表于 2014-5-28 09:47:56 | 显示全部楼层 |阅读模式
            原来是从emmc启动,现在需要修改为从norflash启动,不知道该如何修改,模仿修改了下,
            出现上述问题,板子是公司的,芯是imx6s,
我知道答案 目前已有10人回答
 楼主| 发表于 2014-5-28 09:48:53 | 显示全部楼层
RE:[i.MX] mfgtoolsRel-4.1.0修改从norflash启动,write U-boot to spi nor失败
log如下:
DLL version: 2.2.3
Tuesday, May 27, 2014 18:58:56   Start new logging
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[10]: DeviceTypeDisk--_devices size: 2
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:2, Volume->_diskNumber:2
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 01D9A070
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 5
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:2, Volume->_diskNumber:1
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:1, Volume->_diskNumber:1
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 01DA2040
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 6
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 1
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ flash_erase /dev/mtd0 0 0
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ mount
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is send
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ dd if=$FILE of=/dev/mtd0 bs=512
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MSCDevice--Command Push(no file) excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: CCmdOpreation[0] thread is Closed
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - EVENT_KILL
ModuleID[2] LevelID[10]: CMyExceptionHandler::OnMsgExceptionEvent() - KillExceptionHandlerThread
ModuleID[2] LevelID[10]: Exception Handler thread is closed
ModuleID[2] LevelID[1]: delete MxHidDeviceClass
ModuleID[2] LevelID[10]: Device Manager thread is closed
 楼主| 发表于 2014-5-28 09:49:11 | 显示全部楼层
            ucl.xml配置如下:
                    Loading uboot.
                    Doing Kernel.
                    Doing Initramfs.
                     Jumping to OS image.
                    Erasing Boot partition
                    Sending U-Boot
                    write U-Boot to SPI-NOR
                    Sending partition shell
                     Partitioning...
                     Partitioning...
                    Formatting sd partition
                    Sending kernel uImage
                    write boot.img
                    flush the memory.
                    Formatting data partition
                    Sending data partition shell
                    Extracting data partition shell
                    Making data encryptable
                    Formatting system partition
                    Formatting cache partition
                    flush the memory.
                    Formatting device partition
                    Sending and writting system.img
                    flush the memory.
                    Sending and writting recovery.img
                    Finishing rootfs write
                    Done
 楼主| 发表于 2014-5-28 09:49:34 | 显示全部楼层
Jumping to OS image之前的配置不知道用哪个,随便用不行吧??????之前emmc启动使用的是如下,是OK的。
Loading U-boot
    Loading Kernel.
    Loading Initramfs.
 楼主| 发表于 2014-5-28 09:54:22 | 显示全部楼层
非常感谢各位!!!
    发表于 2014-5-28 10:14:55 | 显示全部楼层
    楼主你好
    我们i.mx工程师稍后会与你讨论这个问题
     楼主| 发表于 2014-5-28 11:33:50 | 显示全部楼层
    回复:[i.MX] mfgtoolsRel-4.1.0修改从norflash启动,write U-boot to spi nor失败
    回复第 6 楼 于2014-05-28 10:14:55发表:
    楼主你好
    谢谢!在线等啊,希望可以快一点。
    发表于 2014-5-28 14:11:44 | 显示全部楼层
    回复第 7 楼 于2014-05-28 11:33:50发表:
    楼主你好
    谢谢!在线等啊,希望可以快一点。
    由于i.mx题较多所以我们的工程师需要一些时间处理,你可以先做处理其他事务不必在线等那么浪费时间。
     楼主| 发表于 2014-5-29 16:35:28 | 显示全部楼层
    回复第 8 楼 于2014-05-28 14:11:44发表:
    楼主你好
    谢谢!在线等啊,希望可以快一点。
    版主啊,什么时候能有消息啊,烧不进去没法调试啊。
    发表于 2014-5-29 17:57:45 | 显示全部楼层
    你好,请问你是用的飞思卡尔的板子还是你们公司自己design的?
    GMT+8, 2025-11-2 04:56 , Processed in 0.100732 second(s), 30 queries , MemCache On.
