查看: 2133|回复: 1
[CodeWarrior] CW10.6的编译错误,求助(已解决)
发表于 2014-7-4 12:57:46 | 显示全部楼层 |阅读模式
是我定义的变量太多了么?怎么解决这个问题?
'Invoking: ARM Ltd Windows GCC C Linker'
"E:/Freescale/CW MCU v10.6/Cross_Tools/arm-none-eabi-gcc-4_7_3/bin/arm-none-eabi-gcc"    @"MKE02VLC2PE.args" -o"MKE02VLC2PE.elf"
e:/freescale/cw mcu v10.6/cross_tools/arm-none-eabi-gcc-4_7_3/bin/../lib/gcc/arm-none-eabi/4.7.3/../../../../arm-none-eabi/bin/ld.exe: MKE02VLC2PE.elf section `._user_heap_stack' will not fit in region `m_data'
e:/freescale/cw mcu v10.6/cross_tools/arm-none-eabi-gcc-4_7_3/bin/../lib/gcc/arm-none-eabi/4.7.3/../../../../arm-none-eabi/bin/ld.exe: region `m_data' overflowed by 108 bytes
collect2.exe: error: ld returned 1 exit status
mingw32-make: *** [MKE02VLC2PE.elf] Error 1
我知道答案 目前已有0人回答
发表于 2014-7-4 14:06:29 | 显示全部楼层
RE:CW10.6的编译错误,求助
楼主定义的变量太多也太大,超出了RAM的容量。
只能想办法减少,要不就只能换别的片子。
你可以参考一下生成的.map文件,看看有什么地方可以调整
GMT+8, 2025-10-31 05:50 , Processed in 0.073506 second(s), 22 queries , MemCache On.
