12
返回列表 发新帖
楼主: qchwu
[其他] ADC_INIT_CHANNEL_STRUCT 疑问
 楼主| 发表于 2014-7-29 16:05:37 | 显示全部楼层
回复:ADC_INIT_CHANNEL_STRUCT 疑问
 adc_kadc.c中的_adc_hw_ioctl(MQX_FILE_PTR f, _mqx_uint cmd, pointer param_ptr)关于硬件平均还有个问题,应该进行修改。
        case ADC_IOCTL_SET_HW_AVERAGING:
            /* sets sample averaging by hardware; param_ptr = (uint_32) cycles - see AVGE bit in Reference Manual */
            if (adc_ch_bundle != NULL)
                return ADC_ERROR_ONLY_DEVICE; /* averaging must be set on device file, not on channel file */
            adc_ptr = (ADC_MemMapPtr) _bsp_get_adc_base_address(adc_num);
            if (*(uint_32*) param_ptr == 0)
                adc_ptr->SC3 &= ~ADC_SC3_AVGE_MASK; /* if zero cycles, disable averaging */
            else {
//                                                        qch 20140729
        adc_ptr->SC3 &= ~ADC_SC3_AVGS_MASK;
        if (*(uint_32*) param_ptr == 32)
        adc_ptr->SC3 |= ADC_SC3_AVGS_32 | ADC_SC3_AVGE_MASK;
        else if (*(uint_32*) param_ptr == 16)
        adc_ptr->SC3 |= ADC_SC3_AVGS_16 | ADC_SC3_AVGE_MASK;
        else if (*(uint_32*) param_ptr == 8)
        adc_ptr->SC3 |= ADC_SC3_AVGS_8 | ADC_SC3_AVGE_MASK;
        else if (*(uint_32*) param_ptr == 4)
        adc_ptr->SC3 |= ADC_SC3_AVGS_4 | ADC_SC3_AVGE_MASK;
        else
        return ADC_ERROR_BAD_PARAM; /* invalid parameter for ioctl command */
//end
//                 adc_ptr->SC3 &= ~ADC_SC3_AVGS_MASK;
//                 if (*(uint_32*) param_ptr == 32)
//                     adc_ptr->SC3 |= ADC_SC3_AVGS_32 | ADC_SC3_AVGE_MASK | ADC_SC3_ADCO_MASK;
//                 else if (*(uint_32*) param_ptr == 16)
//                     adc_ptr->SC3 |= ADC_SC3_AVGS_16 | ADC_SC3_AVGE_MASK | ADC_SC3_ADCO_MASK;
//                 else if (*(uint_32*) param_ptr == 8)
//                     adc_ptr->SC3 |= ADC_SC3_AVGS_8 | ADC_SC3_AVGE_MASK | ADC_SC3_ADCO_MASK;
//                 else if (*(uint_32*) param_ptr == 4)
//                     adc_ptr->SC3 |= ADC_SC3_AVGS_4 | ADC_SC3_AVGE_MASK | ADC_SC3_ADCO_MASK;
//                 else
//                     return ADC_ERROR_BAD_PARAM; /* invalid parameter for ioctl command */
            break;
GMT+8, 2025-10-31 05:37 , Processed in 0.081109 second(s), 19 queries , MemCache On.
