查看: 4224|回复: 3
[已解决] flexcan 测试(已解决)
发表于 2014-7-25 17:39:56 | 显示全部楼层 |阅读模式
 参考sdp layout的一片板子添加了一个flexcan,想在linux下测试一下功能,不知道哪位有好的测试方法没有?用cantest can0 1F334455#1122334455667788测试发现有波形输出,想在两个can之间用cansend测试,提示command not found。一下是can的一些信息,
root@freescale ~$ dmesg | grep can
vcan: Virtual CAN interface driver
flexcan netdevice driver
flexcan imx6q-flexcan.0: device registered (reg_base=c09e8000, irq=142)
flexcan imx6q-flexcan.1: device registered (reg_base=c09f0000, irq=143)
can: controller area network core (rev 20090105 abi 8)
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
root@freescale ~$ ip link set can0 up type can bitrate 125000
flexcan imx6q-flexcan.0: writing ctrl=0x0e312005
root@freescale ~$ ip link set can1 up type can bitrate 125000
flexcan imx6q-flexcan.1: writing ctrl=0x0e312005
root@freescale ~$ ifconfig can0 up
root@freescale ~$ ifconfig can1 up
can1      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          UP RUNNING NOARP  MTU:16  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:10
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:143
can0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          Interrupt:142
root@freescale ~$ ip -details link show can0
2: can0:  mtu 16 qdisc pfifo_fast state UNKNOWN qlen 10
    link/can
    can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
    bitrate 125000 sample-point 0.875
    tq 500 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
    flexcan: tseg1 4..16 tseg2 2..8 sjw 1..4 brp 1..256 brp-inc 1
    clock 30000000
root@freescale ~$ ip -details link show can1
3: can1:  mtu 16 qdisc pfifo_fast state UNKNOWN qlen 10
    link/can
    clock 30000000
我知道答案 目前已有2人回答
发表于 2014-8-5 14:12:08 | 显示全部楼层
回复:flexcan 测试
找不到Library,編譯成static-linked
发表于 2014-8-5 14:42:26 | 显示全部楼层
RE:flexcan 测试
楼主你好,关于flexcan的测试,这里我发给你一个文档,你可以参考一下: How to enable CAN bus on i.MX6Q SabreSD.pdf (482.87 KB, 下载次数: 40)
发表于 2014-8-8 13:14:04 | 显示全部楼层
回复:flexcan 测试(已解决)
 看看是什么原因,我也出现问题了
GMT+8, 2025-10-13 12:56 , Processed in 0.086934 second(s), 25 queries , MemCache On.
