楼主: gogogogo
[已解决] imx6q sdp的板子怎么实现多屏显示(已解决)
发表于 2014-9-11 17:46:39 | 显示全部楼层
gogogogo 发表于 2014-9-10 17:09
最好能4屏,hdmi+2xlvds+lcd。应该是支持4屏显示的。
楼主你好,关于四个屏显示的你可以查看一下我们英文论坛上的帖子:http://community.freescale.com/message/299154#299154
发表于 2014-9-11 17:48:14 | 显示全部楼层
并且关于最新的BSP3.10.17_1.0.0的话,关于四个屏的显示,我们这边的工程师写了个patch,你可以查看参考一下。
L3.10.17_GA1.0.0_Four_display.patch.txt.zip (461 Bytes, 下载次数: 8)
发表于 2014-9-11 17:48:38 | 显示全部楼层
The default BSP will assign both HDMI and CLAA-WVGA LCD to IPU1 DI0, so only one of them can work at the same time. To enable the four display case, the similar modification was needed.
You can apply the attached patch to 3.10.17_1.0.0 kernel. Then use the followed uboot parameters to boot up from SD card:
setenv loadaddr 0x12000000
setenv fdt_addr 0x18000000
setenv fdt_high 0xffffffff
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200'
setenv bootargs_mmc 'setenv bootargs ${bootargs} root=/dev/mmcblk0p1 rootwait rw video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb2:dev=lcd,CLAA-WVGA,if=RGB565 video=mxcfb3:dev=ldb,LDB-XGA,if=RGB666'
setenv bootcmd_mmc 'run bootargs_base bootargs_mmc;mmc dev 1;mmc read ${loadaddr} 0x800 0x3000;mmc read ${fdt_addr} 0x5000 0x800;bootm ${loadaddr} - ${fdt_addr}'
setenv bootcmd 'run bootcmd_mmc'
saveenv
run bootcmd
By the way, before using the four frame buffers, please unblank them first:
# echo 0 > /sys/class/graphics/fb0/blank
# echo 0 > /sys/class/graphics/fb2/blank
# echo 0 > /sys/class/graphics/fb4/blank
# echo 0 > /sys/class/graphics/fb5/blank
With the above uboot video mode setting, fb0 and fb1 are the two layer frame buffer for LVDS1 panel; fb2 and fb3 are the two layer frame buffer for HDMI display; fb4 is the one layer frame buffer for CLAA WVGA LCD; fb5 is the one layer frame buffer for LVDS0 panel.
发表于 2014-9-11 17:49:41 | 显示全部楼层
以上供你参考。
 楼主| 发表于 2014-9-12 09:27:49 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-9-11 17:48
The default BSP will assign both HDMI and CLAA-WVGA LCD to IPU1 DI0, so only one of them can work at ...
Rita,lvds1和lvds0不用设置ldb=sin1之类的吗?能否像安卓一样,不输入命令,直接开机就多显?
发表于 2014-9-12 14:57:34 | 显示全部楼层
gogogogo 发表于 2014-9-12 09:27
Rita,lvds1和lvds0不用设置ldb=sin1之类的吗?能否像安卓一样,不输入命令,直接开机就多显? ...
你就按照我上述发给你帖子中的命令操作哈~~
发表于 2014-9-12 14:57:53 | 显示全部楼层
因为有人那么做成功了的,你试一下哈~~
 楼主| 发表于 2014-9-12 15:16:03 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-9-12 14:57
因为有人那么做成功了的,你试一下哈~~
主要我的核心不是3.10.17_1.0.0 的,ltib4.1.0编译是3.0.35的吧
发表于 2014-9-12 15:18:25 | 显示全部楼层
u-boot设置是一样的。
 楼主| 发表于 2014-9-12 15:20:50 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-9-12 15:18
u-boot设置是一样的。
哦,好的,我按照MCIMX6DL-SDP双显(LVDS+HDMI).pdf试了能够出现四只小企鹅,我主要是认为imx6q有两个ipu,我觉得应该可以直接显示两个桌面才对。
GMT+8, 2025-10-30 16:54 , Processed in 0.102902 second(s), 30 queries , MemCache On.
