查看: 11282|回复: 8
[已解决] imx28 uboot烧写ubifs问题(已解决)
发表于 2014-9-16 21:49:14 | 显示全部楼层 |阅读模式
我已经可以使用uboot启动,然后通过nand write烧写ubifs,如下:
MX28 U-Boot > tftp 42000000 ubi.img
Using FEC0 device
TFTP from server 192.168.10.101; our IP address is 192.168.10.100
Filename 'ubi.img'.
Load address: 0x42000000
Loading: FEC: Link is down 7809
T #################################################################
done
Bytes transferred = 17432576 (10a0000 hex)
MX28 U-Boot > nand erase 0x1400000 0x1400000
NAND erase: device 0 offset 0x1400000, size 0x1400000
Erasing at 0x27e000005000000 --   0% complete.
OK
MX28 U-Boot > nand write 0x42000000 0x1400000 0x1400000
NAND write: device 0 offset 0x1400000, size 0x1400000
20971520 bytes written: OK
MX28 U-Boot >
并且第一次可以启动文件系统。但是第二次启动的时候,重新下载也是第二次在加载文件系统的时候出现如下错误:
UBI error: ubi_io_read: error -74 while reading 126976 bytes from PEB 3:4096, read 126976 bytes
UBI error: ubi_io_read: error -74 while reading 126976 bytes from PEB 4:4096, read 126976 bytes
UBI error: ubi_io_read: error -74 while reading 11 bytes from PEB 9:6144, read 11 bytes
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 80000005 [#1] PREEMPT
last sysfs file:
Modules linked in:
CPU: 0    Not tainted  (2.6.35.3-670-g914558e #128)
PC is at 0x0
LR is at my_read_page+0x60/0xa8
pc : [<00000000>]    lr : [<c0263234>]    psr: 40000013
sp : c7c27b18  ip : 00000020  fp : c7c27d4c
r10: c06000bd  r9 : 00000000  r8 : c0027a14
r7 : c0027a24  r6 : c04f05b8  r5 : c7c27d2c  r4 : c7c27d50
r3 : 00000000  r2 : 00000000  r1 : 00000000  r0 : c7dfc400
Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 0005317f  Table: 40004000  DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc7c26270)
Stack: (0xc7c27b18 to 0xc7c28000)
请问imx28  nandflash启动,在uboot下write ubifs时候如何操作,目前我操作命令如下,但感觉需要修改nand write成nand write.ubi,请问如何实现?
tftp 42000000 uImage
nand erase 0x300000 0x300000
nand write 0x42000000 0x300000 0x300000
我知道答案 目前已有8人回答
 楼主| 发表于 2014-9-17 10:11:22 | 显示全部楼层
看到我问题了吗,谢谢
发表于 2014-9-17 10:48:30 | 显示全部楼层
eleganthuman 发表于 2014-9-17 10:11
看到我问题了吗,谢谢
一会I.MX工程师会过来统一处理I.MX的题,放心,肯定看到你的题的。
发表于 2014-9-17 17:05:39 | 显示全部楼层
楼主你好,请问你使用的是官网的i.mx28的开发板吗?
 楼主| 发表于 2014-9-18 22:34:09 | 显示全部楼层
你好,是啊。请问你们那的UBOOT模式下下载命令式怎么样的?另外你们有针对nandflash的uboot,并且支持ubifs命令的uboot吗
发表于 2014-9-19 15:26:18 | 显示全部楼层
eleganthuman 发表于 2014-9-18 22:34
你好,是啊。请问你们那的UBOOT模式下下载命令式怎么样的?另外你们有针对nandflash的uboot,并且支持ubifs ...
楼主你好,在i.mx28的文档中应该是有说明的,建议你看一下哈。
发表于 2014-9-19 15:28:37 | 显示全部楼层
还有u-boot是一样的。不一样的是文件系统的格式。
发表于 2014-10-9 17:54:47 | 显示全部楼层
楼主你好,请问你帖中的问题已经解决了吗?如果没有的话,欢迎继续在这里讨论哈~~
 楼主| 发表于 2014-10-10 08:48:17 | 显示全部楼层
你好,文档中是介绍烧写到SD卡的,如下
7.3   Boot commands
Boot application image from memory
        bootm [addr [arg ...]]
Boot image via network using TFTP protocol
         tftpboot [loadAddress] [[hostIPaddr:]bootfilename]
Boot image via network using DHCP/TFTP protocol
         dhcp [loadAddress] [[hostIPaddr:]bootfilename]
Boot image via network using RARP/TFTP protocol
         rarpboot [loadAddress] [[hostIPaddr:]bootfilename]
Format MMC device
        mxs_mmc format <dev num>
Install image to MMC card
mxs_mmc install <dev num> addr size [sbImage|uImage|rootfs]
我现在的需求是烧写到NANDFLASH。我目前没有关于在uboot下烧写uImage和ubi.img。我使用的烧写命令式:
但是这样写的话有问题,如下:
Using FEC0 device
Filename 'ubi.img'.
done
OK
MX28 U-Boot >
pgd = c0004000
last sysfs file:
Modules linked in:
PC is at 0x0
GMT+8, 2026-4-10 02:18 , Processed in 0.097650 second(s), 30 queries , Redis On.
