查看: 6754|回复: 6
[MQX] MQX UDP如何接收特定端口的广播信息
发表于 2014-10-8 13:58:43 | 显示全部楼层 |阅读模式
需要k60使用UDP接收广播信息,建立链接。
比如k60接收从192.168.1.255 5055端口接收广播信息
怎样配置?
我的配置只能接收到点对点的udp信息报
附上代码
int connect_UDP()
        uint_32                        cmd_reply_len;
    uint_32                sock,sendsock;
        uint_16                        rlen;
    IPCFG_IP_ADDRESS_DATA    ip_data;
    _enet_address            enet_addr = ENET_MAC;
    sockaddr_in            addr;
    sockaddr_in                dest_addr;
    uint_32                error, option;
    MQX_FILE_PTR           sockfd, telnetfd;
    _mqx_uint              echoflag = IO_SERIAL_ECHO;
    char                 senddata[128] = "mesh gate connected!\r\n";
    char        recvdata[512];
    int                         count;
    int             num,pRcv;
//    _RTCSPCB_init          = 3;
//    _RTCS_msgpool_init     = 3;
//    _RTCS_socket_part_init = 3;
    memset(recvdata,0,sizeof(recvdata));
    error = RTCS_create();
    if (error != RTCS_OK)
       fputs("Fatal Error: RTCS initialization failed.", stderr);
       _task_block();
    ip_data.ip = ENET_IPADDR;
    ip_data.mask = ENET_IPMASK;
    ip_data.gateway = ENET_IPGATEWAY;
    ENET_get_mac_address (BSP_DEFAULT_ENET_DEVICE, ENET_IPADDR, enet_addr);
    error = ipcfg_init_device(BSP_DEFAULT_ENET_DEVICE, enet_addr);
    if (error != IPCFG_OK)
        fprintf(stderr, "Fatal Error 0x%X: Network device initialization failed.\n", error);
        _task_block();
    error = ipcfg_bind_staticip(BSP_DEFAULT_ENET_DEVICE, &ip_data);
        fprintf(stderr, "Fatal Error 0x%X: IP address binding failed.", error);
        _task_block();
    /* Install device drivers for socket and telnet I/O */
    //_io_socket_install("socket:");
        sendsock = socket(PF_INET, SOCK_DGRAM, 0);
    /* Bind the socket to the Telnet port */
    addr.sin_family      = AF_INET;
    addr.sin_port        = 5055;
    //addr.sin_addr.s_addr = ENET_IPADDR;                   //INADDR_BROADCAST
        addr.sin_addr.s_addr = INADDR_ANY;
    dest_addr.sin_family        = AF_INET;
    dest_addr.sin_port        = 5055;
    dest_addr.sin_addr.s_addr = IPADDR(192,168,1,112);
        option = 1;
        //setsockopt(sendsock,SOL_SOCKET,OPT_RECEIVE_PUSH,&option,sizeof(option));
    error = bind(sendsock, &addr, sizeof(addr)); //return_error_if(error != RTCS_OK)
        _time_delay(100);
        rlen = sizeof(dest_addr);
        //sendto(sendsock, senddata, strlen(senddata), 0,&dest_addr, rlen);
        while(1)
                count = recvfrom(sendsock, recvdata, 512, 0, (struct sockaddr *) &dest_addr,&rlen);
                if(count == RTCS_ERROR)
                else
                        if(count>0)
                                //_io_write(serial4_fd, recvdata, count);
                                //_time_delay(1000);
                                //memset(recvdata,0,sizeof(recvdata));
                                //count = 0;
                                //cmd_reply_len = phone_cmd_analsys((uint_8*)recvdata,count);
                                //sendto(sendsock, phone_reply, cmd_reply_len, 0,&dest_addr, rlen);
                                sendto(sendsock, "123", 3, 0,&dest_addr, rlen);                              //随便测试
                                memset(phone_reply,0,PHONE_REPLY_LEN);
                                count = 0;
http://blog.csdn.net/robertkun/article/details/8475843#comments
这个是linux的一个实例,但是他的配置中有个  nb = setsockopt(sock, SOL_SOCKET, SO_BROADCAST, (char *)&opt, sizeof(opt)); 这个操作
但是在MQX中源码中并没有找到和
SO_BROADCAST相关的配置参数,怎么办。
我知道答案 目前已有6人回答
发表于 2014-10-9 09:49:54 | 显示全部楼层
你好,楼主!
我会将你的转告给MQX工程师,他稍后会回复你的!
发表于 2014-10-9 09:50:13 | 显示全部楼层
还有一点楼主!
以后有关飞思卡尔产品的问题,请在【飞思卡尔FAE线上技术支持 】板块提出。
 楼主| 发表于 2014-10-9 10:43:07 | 显示全部楼层
FSL_TICS_ZP 发表于 2014-10-9 09:50
还有一点楼主!
以后有关飞思卡尔产品的问题,请在【飞思卡尔FAE线上技术支持 】板块提出。 ...
嗯  好的,谢谢关注。
发表于 2014-10-9 11:35:11 | 显示全部楼层
vc66vcc 发表于 2014-10-9 10:43
嗯  好的,谢谢关注。
不客气,有其他问题,咱们再交流。
 楼主| 发表于 2014-10-9 11:39:54 | 显示全部楼层
问题已确认,这个是解决通信邮件地址
http://community.freescale.com/thread/332161
总的来说
1.mqx 不知为什么会认为192.168.1.255的广播信息的目的地址不合法,会自动的丢弃。
2.mqx可以成功的接收来自255.255.255.255的广播信息。
3.我的网络调试助手在win7的电脑上发出的255.255.255.255的广播信息会被PC屏蔽掉,导致广播信息到达不了mqx。
4.我使用android手机上的网络调试助手成功的发出了255.255.255.255的广播信息,并且被mqx成功的接收了。
谢谢FSL_TICS_ZP的关注。
    无聊
    2019-4-1 22:48
  • 签到天数: 302 天
    发表于 2014-10-28 00:16:02 | 显示全部楼层
    广播的信息总会去对应一个地址的吧
    1、Client 需要 Bind 端口.
    2、广播分很多种,除了受限广播,还有指向子网的广播等。(INADDR_BROADCAST不是必须)
    GMT+8, 2026-4-16 05:06 , Processed in 0.098032 second(s), 26 queries , Redis On.
