查看: 3380|回复: 7
[S12] S12G64在STOP模式下的复位电压是多少?
发表于 2014-10-11 10:34:38 | 显示全部楼层 |阅读模式
想问一下,S12G64在STOP模式下的复位电压是多少?
实测在1.4V左右,但是数据手册没有找到相数据。
在标准模式下实测为3V左右,这个和数据手册上的数据是相同的。
我知道答案 目前已有7人回答
    发表于 2014-10-11 11:17:07 | 显示全部楼层
    手册上没有说当进入STOP模式以后复位的电压范围。从正常的复位电压范围来对比,在STOP模式下,应该是看内核电压的范围,这个应该查S12内核手册,不过我暂时未找到对应的手册。
     楼主| 发表于 2014-10-11 13:11:52 | 显示全部楼层
    版主能帮我找一下手册吗,现在急需要确认这个电压,没果没有数据依据就需改PCB了。
    改PCB EMC实验就要重新做了,估计老板  时间上也不允许。
    谢谢!
    发表于 2014-10-14 11:15:37 | 显示全部楼层
    改PCB EMC实验就要重新 ...
    Sorry,我没找到那个文档。
    我建议你提交SR寻求技术支持, 创建SR流程请参考此链接。
    https://www.nxpic.org.cn/module/forum/thread-578569-1-1.html
     楼主| 发表于 2014-10-15 11:06:50 | 显示全部楼层
    已经提交了,有了结果的话,我贴上来。
     楼主| 发表于 2014-10-15 12:40:19 | 显示全部楼层
    zhao123ou 发表于 2014-10-15 11:06
    已经提交了,有了结果的话,我贴上来。
    飞思卡尔的回复如下:
    Power on reset level (VPORD) is approximately 1V (0.9…1.1V). MCU will start working (left low voltage reset state) at VDDX Low Voltage Reset Deassert value VLVRXD = 3.05V. Operating range for power supply is 3.13 … 5.5V.
    According to design, below 3V the period of the ACLK could be affected (comment for the S12VR; but I think both (S12G and S12VR) use the same ACLK block). This may also affect the period of the COP when clocked from the ACLK.
    For the S12G64, I measured (at room temperature) that around 2.3V, the period of the API starts to change. The part I tested continued to operate (in stop mode with no RESET) up to 1.45V. At such voltage (1.45V) the API period had changed from 1.97ms to ~1.5ms. Around 23% variation from the original period.
    Below 1.45V (at room temperature) the part I was testing RESET. However, I understand that the POR threshold is a function of temperature and part variation. Not Cz’d.
    Some OEMs may have requirements that will force tier ones to use an external POR circuit to assure the MCU will be RESET when VDDR is below 3.13V. Let’s say the external POR will de assert reset above 3.25V and assert reset below 3.15V.
    无聊
    2019-4-1 22:48
  • 签到天数: 302 天
    发表于 2014-10-28 00:33:55 | 显示全部楼层
    在STOP模式下仍会持续运行吧, 但有时也有可能不运行
    发表于 2014-10-28 08:52:50 | 显示全部楼层
    zhao123ou 发表于 2014-10-15 12:40
    飞思卡尔的回复如下:
    Power on reset level (VPORD) is approximately 1V (0.9…1.1V). MCU will start ...
    好的,谢谢!
    GMT+8, 2026-4-15 19:36 , Processed in 0.109714 second(s), 29 queries , Redis On.
