楼主: rivita
[求助] i.mx6 ubootping不通网络
 楼主| 发表于 2014-10-13 18:57:54 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-10-13 12:57
跟着步骤操作就OK的,我文档中写的比较详细。
以下是我U-BOOT ping PC的信息
U-Boot 2009.08 (Oct 11 2014 - 12:02:42)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 186
Temperature:   29 C, calibration data 0x5984f47d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: SD
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
Net:   got MAC address from IIM: 00:04:9f:02:e3:ea
FEC0 [PRIME]
MX6Q SABRESD U-Boot > print
bootdelay=3
baudrate=115200
netmask=255.255.255.0
rd_loadaddr=(0x1300000)
netdev=eth0
ethprime=FEC0
uboot=u-boot.bin
kernel=uImage
nfsroot=/opt/eldk/arm
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp nfsroot=${serverip}{nfsroot},v3,tcp
bootcmd_net=run bootargs_base bootargs_nfs; tftpboot ${loadaddr} ${kernel}; bootm
ethact=FEC0
bootargs=console=ttymxc0,115200 root=/dev/mmcblk1p1 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
loadaddr=0x10800000
bootargs_base=setenv bootargs console=ttymxc0,115200
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk1p1 rootwait rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
bootcmd_mmc=run bootargs_base bootargs_mmc;mmc dev 2;mmc read ${loadaddr} 0x800 0x2000;bootm
bootcmd=run bootcmd_mmc
ethaddr=00:04:9f:02:e3:ea
ipaddr=192.168.1.11
serverip=192.168.1.110
stdin=serial
stdout=serial
stderr=serial
Environment size: 953/8188 bytes
MX6Q SABRESD U-Boot > ping 192.168.1.110
PHY indentify @ 0x1 = 0x004dd074
FEC: Link is Up 796d
Using FEC0 device
ping failed; host 192.168.1.110 is not alive
Using FEC0 device
 楼主| 发表于 2014-10-13 18:58:16 | 显示全部楼层
我在WIN7下关了IPV6,所有都设置在一个网段内
发表于 2014-10-16 10:44:50 | 显示全部楼层
楼主你好,你这里应该是网络配置有问题的。建议查看我之前让你看的那个文档。
发表于 2014-10-16 10:46:48 | 显示全部楼层
还有我看到你发给我你u-boot中的参数,设置也是有问题的,因为是从NFS启动,uImage要编译为是从NFS启动下编译出来的,另外,bootcmd即启动模式是从网络启动,而不是mmc。
发表于 2014-10-16 10:47:04 | 显示全部楼层
建议楼主先仔细查看一下文档哈~~
 楼主| 发表于 2014-10-16 21:36:27 | 显示全部楼层
我没有设置NFS启动,我只想通过U-BOOT把程序下载到内存的,我们的用法不一样,我只想咨询为什么我在U-BOOT中PING PC不通,也就是网络不通。
发表于 2014-10-20 17:24:50 | 显示全部楼层
rivita 发表于 2014-10-16 21:36
我没有设置NFS启动,我只想通过U-BOOT把程序下载到内存的,我们的用法不一样,我只想咨询为什么我在U-BOOT ...
楼主你好,关于通过u-boot下载程序的话,在我们的文档中也有详细介绍的,你可以先看一下文档。
 楼主| 发表于 2014-10-21 20:40:46 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-10-20 17:24
楼主你好,关于通过u-boot下载程序的话,在我们的文档中也有详细介绍的,你可以先看一下文档。 ...
我想咨询的是通过U-BOOT ping命令测试网络。
发表于 2014-10-23 14:44:20 | 显示全部楼层
就是ping 后面跟着IP就可以的啊~~
 楼主| 发表于 2014-10-23 20:38:08 | 显示全部楼层
真的ping不通,这个应该没有交叉直连之分嘛,应该自适应对吧。到linux下就通啦。
GMT+8, 2026-4-16 19:20 , Processed in 0.104385 second(s), 29 queries , Redis On.
