查看: 8088|回复: 13
[求助] imx28 uboot烧写ubifs问题
发表于 2014-10-13 10:25:10 | 显示全部楼层 |阅读模式
你好,文档中是介绍烧写到SD卡的,如下
7.3   Boot commands
Boot application image from memory
        bootm [addr [arg ...]]
Boot image via network using TFTP protocol
         tftpboot [loadAddress] [[hostIPaddr:]bootfilename]
Boot image via network using DHCP/TFTP protocol
         dhcp [loadAddress] [[hostIPaddr:]bootfilename]
Boot image via network using RARP/TFTP protocol
         rarpboot [loadAddress] [[hostIPaddr:]bootfilename]
Format MMC device
        mxs_mmc format <dev num>
Install image to MMC card
mxs_mmc install <dev num> addr size [sbImage|uImage|rootfs]
我现在的需求是烧写到NANDFLASH。我目前没有关于在uboot下烧写uImage和ubi.img。我使用的烧写命令式:
tftp 42000000 uImage
nand erase 0x300000 0x300000
nand write 0x42000000 0x300000 0x300000
tftp 42000000 ubi.img
nand erase 0x1400000 0x1400000
nand write 0x42000000 0x1400000 0x1400000
但是这样写的话有问题,如下:
我已经可以使用uboot启动,然后通过nand write烧写ubifs,如下:
MX28 U-Boot > tftp 42000000 ubi.img
Using FEC0 device
TFTP from server 192.168.10.101; our IP address is 192.168.10.100
Filename 'ubi.img'.
Load address: 0x42000000
Loading: FEC: Link is down 7809
T #################################################################
done
Bytes transferred = 17432576 (10a0000 hex)
MX28 U-Boot > nand erase 0x1400000 0x1400000
NAND erase: device 0 offset 0x1400000, size 0x1400000
Erasing at 0x27e000005000000 --   0% complete.
OK
MX28 U-Boot > nand write 0x42000000 0x1400000 0x1400000
NAND write: device 0 offset 0x1400000, size 0x1400000
20971520 bytes written: OK
MX28 U-Boot >
并且第一次可以启动文件系统。但是第二次启动的时候,重新下载也是第二次在加载文件系统的时候出现如下错误:
UBI error: ubi_io_read: error -74 while reading 126976 bytes from PEB 3:4096, read 126976 bytes
UBI error: ubi_io_read: error -74 while reading 126976 bytes from PEB 4:4096, read 126976 bytes
UBI error: ubi_io_read: error -74 while reading 11 bytes from PEB 9:6144, read 11 bytes
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 80000005 [#1] PREEMPT
last sysfs file:
Modules linked in:
CPU: 0    Not tainted  (2.6.35.3-670-g914558e #128)
PC is at 0x0
LR is at my_read_page+0x60/0xa8
pc : [<00000000>]    lr : [<c0263234>]    psr: 40000013
sp : c7c27b18  ip : 00000020  fp : c7c27d4c
r10: c06000bd  r9 : 00000000  r8 : c0027a14
r7 : c0027a24  r6 : c04f05b8  r5 : c7c27d2c  r4 : c7c27d50
r3 : 00000000  r2 : 00000000  r1 : 00000000  r0 : c7dfc400
Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 0005317f  Table: 40004000  DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc7c26270)
Stack: (0xc7c27b18 to 0xc7c28000)
我知道答案 目前已有13人回答
 楼主| 发表于 2014-10-13 10:25:42 | 显示全部楼层
请协助帮忙解决,比较急啊
发表于 2014-10-13 13:03:32 | 显示全部楼层
楼主你好,请问你用的板子是自己设计的还是官网的开发板?使用的BSP是哪个版本的?
 楼主| 发表于 2014-10-13 13:23:41 | 显示全部楼层
官网的,L2.6.35_1.1.0_130130_source.tar.gz
 楼主| 发表于 2014-10-14 09:01:17 | 显示全部楼层
你们有电话吗?我跟你们说说,比较急的项目呢
 楼主| 发表于 2014-10-14 09:01:58 | 显示全部楼层
我的手机是13794450318,我可以简单说下
禁止发言
发表于 2014-10-14 11:19:12 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2014-10-15 17:13:51 | 显示全部楼层
我跟他们呢沟通过,之前跟他们买了4块开发板,他们的板子是可以uboot启动,他们也发了uboot和uImage给我,我在他们的开发板上下载好了可以启动的,现在就是在他们的uboor下载,不知道他们的下载命令是怎么样的?我们由于没有采购他们的核心版,所以他们不会告诉我怎么下载的。
1.你们能够跟他们要到如何在ubbot下下载uImage不会用问题的步骤?
发表于 2014-10-16 10:35:26 | 显示全部楼层
eleganthuman 发表于 2014-10-15 17:13
我跟他们呢沟通过,之前跟他们买了4块开发板,他们的板子是可以uboot启动,他们也发了uboot和uImage给我, ...
楼主你好,请问你使用的是哪块板子呢?
 楼主| 发表于 2014-10-16 13:42:25 | 显示全部楼层
myzr-imx28  v2.1
GMT+8, 2026-4-14 02:27 , Processed in 0.115860 second(s), 31 queries , Redis On.
