查看: 4736|回复: 3
[MQX] 在mqx操作系统下,k64如何实现利用RTS控制RS485收发数据
发表于 2014-10-16 17:14:36 | 显示全部楼层 |阅读模式
你好:
下面是我的测试程序,大家帮看看有何问题?
本串口通过RS485转RS232转换器接到电脑的串口,测试版发送的数据电脑接收不到,测试版能够接收到电脑的发送数据。难道我还得通过程序控制RTS。
void mian_task
      uint32_t initial_data
   MQX_FILE_PTR rs485_dev = NULL;
   char  data_buffer[] = "RS485 send example";
   bool disable_rx = TRUE;
   uint32_t result;
     rs485_dev = fopen( RS485_CHANNEL, (char const *)IO_SERIAL_HW_485_FLOW_CONTROL );
   if( rs485_dev == NULL )
      /* device could not be opened */
      _task_block();
   /* half duplex, two wire. use only if disable receiver in transmit is desired */
   result = ioctl( rs485_dev, IO_IOCTL_SERIAL_DISABLE_RX, &disable_rx );
   if( result == IO_ERROR_INVALID_IOCTL_CMD )
      /* ioctl not supported, use newer MQX version */
      _task_block();
   /* write data */
   write( rs485_dev, data_buffer, strlen(data_buffer) );
   /* empty queue - not needed for polled mode */
   fflush( rs485_dev );
   /* wait for transfer complete flag */
   result = ioctl( rs485_dev, IO_IOCTL_SERIAL_WAIT_FOR_TC, NULL );
      _task_block();
   /* half duplex, two wire */
   /* if receiver was disabled before, enable receiver again */
   disable_rx = FALSE;
   ioctl( rs485_dev, IO_IOCTL_SERIAL_DISABLE_RX, &disable_rx ) ;
   while(1)
        i=  fread(data_buffer, 1, 10,rs485_dev);
        if(i !=0)
            for(j =0; j<i;j++)
                buffer[readlen+j] = data_buffer[j];
            readlen += i;
        if(readlen ==10)
            break;
   _task_block();
 楼主| 发表于 2014-10-20 15:49:57 | 显示全部楼层
顶一下,FAE大侠们,能否帮解决一下!
 楼主| 发表于 2014-10-22 11:12:10 | 显示全部楼层
顶一下,FAE大侠们,能否帮解决一下!
发表于 2014-11-27 11:29:07 | 显示全部楼层
我是在init_gpio里面指定引脚功能,指定好后就正常了!程序无需对其进行操作!  param =  IO_SERIAL_NON_BLOCKING|IO_SERIAL_HW_485_FLOW_CONTROL;
  if(MQX_OK != ioctl(com_fd[com_no], IO_IOCTL_SERIAL_SET_FLAGS, &param))
        printf("Set Flags faild!\n");
        //return false;
GMT+8, 2026-4-8 00:43 , Processed in 0.102414 second(s), 25 queries , Redis On.
